previous
Configuration - Profile Changes (cf_profilechanges with GENREPPAR.FMX)
The Configuration report Profile Changes will display all changes made to profiles for the date range specified. This information is pulled from the User Activity Log.
Date Range
From Date. Manually enter, or select the calendar button, for the beginning date of the report data.
To Date. Manually enter, or select the calendar button, for the ending date of the report data.
