previous
Configuration - Rate Class (cf_rateclass with GENREPPAR.FMX)
The Configuration report Rate Class will display all Rate Classes that have been configured. If the license code for multi property functionality is activated (OPP_MHOT), this report will represent all codes on the template form.
Note: When the OPR <version number> ORS license code is active, the Select Property screen appears prior to the Report Parameters screen.  Choose the property you want to view and select the OK button.  The Report Parameters screen appears.
In PMS, Rate Classes are configured in Configuration>Rate Management>Rate Classes. In ORS, Rate Classes are configured in System Configuration>Rate Management>Rate Classifications>Rate Classes.
Rate Class
Rate Class. Single Select LOV to display a specific rate class. Leave this field blank to display all of the rate classes.
