previous
Folio Tax - Style 04 (foliotax_04 with FOL1.FMX)
This report was developed to meet reporting requirements for properties located in Turkey.
The report will NOT refer to the Cashiering>Reports Tax Buckets application setting. If there are net/ tax amounts in all the 20 buckets then report will include all the 1-20 tax and net buckets irrespective of what is selected in the setting. It will not include the net / tax groups for which values do not exist.
The name column on the report is the Payee name.
Selection Criteria
Date Range
From Date. Manually enter, or select the Calendar button to choose, the beginning date for the date range used in the results of the report.
To Date. Manually enter, or select the Calendar button to choose, the ending date for the date range used in the results of the report.
Status. Select the status of the tax.
Sort Order. Chronological, Folio No., Room No.
