previous
MAX SNAPSHOTS IN PACE CUBE Application Setting
Group.  OBI
Type.  Setting
Application.
ORS
Description. Maximum Snapshot Days that can be RUNNING or BUILDING at once when rebuilding PACE and Monthly PACE Cubes. 0 means all Snapshot days.
Example: If the Pace Cube has 40 snapshots to build and this application setting is set to 5, once the first 5 snapshots start to build, OPERA will start loading the data for the next set of 5 snapshots. This will reduce the wait time between builds.
Internal Name. OBI_MAX_SNAPSHOT_IN_PACE
Property Determination.
Activation / Inactivation Rules.
<none>
Available Values.
Select a value from 1 to 366.
Add On Licenses/Country Specifics.
<none>
Other Application Settings.
This is a resource intensive operation. Ensure that the OBI>OBI_DAILY_SNAPSHOT_TYPE setting is set to a reasonable value.
Affected Areas
Menus / Screens / Fields.
<none>
Reports & Report Forms.
<none>
Permissions.
<none>
Notes.
<none>
