MOBILE AUDIO KEY CHECK IN Application Setting
Group. IFC |
Type. Setting |
Application. |
PMS |
Description. Determines when the reservation will be checked in.
Internal Name. MOBILE_AUDIO_KEY_CHECK_IN
Property Determination. Based on the MAK vendor the property is using, the ability may exist to determine when the reservation check in should be performed. The check in usually occurs with the successful answer to the Send Key Request from the Pre Register Check In screen. However, with specific vendors it may be possible to communicate and conduct the check in for the reservation upon initial use of the guest’s mobile device.
Activation / Inactivation Rules. |
<none> |
Available Values. |
KEY REQUEST - Check in occurs with successful answer to the Send Key Request. KEY USE - Check in occurs with successful Mobile Audio Key entry to room. |
Add On Licenses/Country Specifics. |
<none> |
Other Application Settings. |
Available when the IFC>Mobile Audio Key application parameter is set to Y. |
Affected Areas
Menus / Screens / Fields. |
Front Desk>Pre Register Arrivals>Send Key |
Reports & Report Forms. |
<none> |
Permissions. |
<none> |
Notes. |
<none> |
