MOBILE AUDIO KEY Application Setting
Group. IFC |
Type. Parameter |
Application. |
PMS |
Description. Enable the use of a Mobile Audio Key for Guest Room Access.
Internal Name. MOBILE_AUDIO_KEY
Property Determination. For properties that want to allow their guests access to the room by use of their mobile device.
Activation / Inactivation Rules. |
In order for this application parameter to be available, a MAK Interface Type must be configured and running along with an active DLS Interface that is compatible with OpenWays. IFC>Multiple Guest Room Key application parameter must be set to N. |
Available Values. |
Y-Yes N-No |
Add On Licenses/Country Specifics. |
<none> |
Other Application Settings. |
Reservations>Pre-Registration Check In application parameter must be set to Y. Reservations>Do Not Move Room application function must be set to Y. Reservations>CC Pre Check In Authorization application parameter must be set to Y. IFC>Multiple Guest Room Key application parameter must be set to N. |
Affected Areas
Menus / Screens / Fields. |
Configuration>Setup>Property Interfaces>Interface Configuration Configuration>Reservations>Mobile Audio Key Rules Shift+F8 (IFC Menu) Miscellaneous>Interfaces>Interfaces Front Desk>Pre Register Arrivals>Send Key Reservations>Options>Key Opt-In New Reservation Screen Painting Opt In for the Reservation Main and More tabs |
Reports & Report Forms. |
<none> |
Permissions. |
Front Desk>Pre-Register Check In Front Desk>Send Key |
Notes. |
<none> |
