OEDS Configuration Editor Settings for EQC Installations
As part of a new installation or an upgrade, the OEDS Configuration Editor launches and takes you through the configurations required to complete the installation and ensure Opera runs smoothly. These configurations may include information about the Oracle connection, Opera application login, rate updates, reservation configurations, interface configurations, and so on. Select the Next > button or the < Back button to navigate through the various configuration screens. Verify that all of the configuration settings are accurate, and select the Finish button save and apply any changes.
Note: If you ever need to change the configuration files after the original installation or an upgrade, launch the OEDS Configuration Editor by selecting the icon on your desktop and refer to the information in this section. If you made changes to the OEDS Configuration Editor that you do not want to save, select the Cancel button. For additional information on cancelling within the OEDS Configuration Editor, see Cancelling Within the OWS Configuration Editor.
Depending on the features selected during the EQC installation, the following Configuration Editor settings may be available:
