previous
Multiple Subscription Report (ors_mul_subscr with GENREPPAR.FMX)
The Multiple Subscription report identifies the profiles which have multiple subscriptions, such as one ACTIVE and one INACTIVE for the same property.  This gives the PMS users the information to be able to perform the merge properly on PMS and ultimately delete the INACTIVE subscription in ORS.
The report displays the property(s) selected and the ORS Name Id, PMS Name Id, Client Id/IATA#, Corp Id, name of the person, and if the subscription is currently active or inactive.
Selection Criteria
Property. Select the property or multiple properties you want to view.
Profile Type. Select the profile(s) you want to view: Company, Guest, Hotel, Source, and/or Travel Agent.
