ORS ResReserved (orsresreserved with ORSRES3.FMX)
This report displays reservation information grouped by reservation type. Other information includes: Arrival/Departure Dates, Rate Code, Rate Amount, Nights, Room Type, Market Code, Source Code, and Company.
Property. Select the property and origin code you want to filter the report by.
Origin Code. Select the channel(s) (through which the reservation was made) you want to view, or leave the default to ALL.
From/To Date. Enter the beginning and ending date range you want to view.
Booked. Select this radio button if you want the booked date in this date range to display.
Arrival. Select this radio button if you want the arrival date in this date range to display.
Departure. Select this radio button if you want the departure date in this date range to display.
