Promotions Summary (promotions_sum with ORSPROM1.FMX)
The Promotions Summary report provides a view of the number of stays associated with a promotion code, at a property, within a time range.
The report reads data from the Stay Records table and displays the property(s) associated with the promotion code, the promotion code, the start and end dates of the promotion, number of stays, and the number of nights.
The report can be filtered by the following: property, begin/end dates, promotion code, and membership card number.
Property. Property(s) to which the promotion (promotion code) belongs. Select one, multiple, or all from the Property LOV.
Begin Date/End Date. Start and end dates range of the promotion.
Promotion Code. The code identifying the promotion. Select one, multiple, or all from the Promotion Code LOV.
Membership Card No. If desired, enter the membership card number for the amount of stays.
