Reservation by Rate Code (resvratecode with GENREPPAR.FMX)
Reservation by Rate Code is a past-date report that displays the number of reservations per reservation date, property and rate code.
Property. Select the property(s) you want to view.
From Date/To Date. Select the beginning and end date range for the reservations you want to view.
Rate Code. Select the rate codes(s) for the reservations you want to view.
