previous
Turnaway DMY (turnaway_dmy with RES15.FMX)
The report shows how many rooms have been turned away for a selected stay date and the MTD and YTD values, i.e. how many rooms have been turned away between the beginning of the month/year and the selected stay date. The report does NOT show when those reservations have been turned away.
Selection Criteria
Turnaway Stay Date
Date. Select the date to print the report for.
Turnaway Taken From
Turnaway Date Range. Select to display all of the Turnaways that occurred for the dates that fall between the specified From and To Dates.
Filter
Turnaway Code. Select the down-arrow to select one or more codes to print on the report.
Display
Graph. Select to also display a graph for the results of the report.
Group By
Subgroup By. Market Code, Rate Code, Room Type, Country, Region, State, District, City, Postal Code, User.
Sort Order. Alphabetical, Sequence.
