RMS Rate Code (yield_rate_code with GEN1.FMX)
The RMS Rate Code Report can be used to determine the Rate Strategies that have been set for indicated rate codes. This report is parameter driven by Rate Code or Dates Range. By default, you can view one month of data. In addition, you can view data for the entire period (50 weeks). The rate codes to be printed are determined by a multi select pick box allowing any number of rates to be included.
Note: The data included in this report applies to rate strategies that are configured using the If Times Sold Reaches Condition. See Configuration>Rate Management>Rate Strategy Setup for details.)
Rate Code. Select the down arrow to choose the rate code(s) to be covered by the report. The default is all rate codes.
