previous
BUSINESS BLOCK OFFSET TYPES Permission
Permission Group. Reservations Config
Description. Allows the user to create Block Offset Types for use in block offsets bookings and revenue calculations.
Internal Name. BUSINESS_BLOCK_OFFSET_TYPES
Application Used In. PMS, S&C, ORS/SFA
Path. Configuration>Reservations>Business Blocks>Block Offset Types
Other Permissions.
BLOCKS>BLOCK OFFSET EDIT
Application Settings.
Only available when the application function BLOCKS>BUSINESS BLOCKS OFFSET is active.
Licenses/Add On Licenses.
Notes.
