previous
ALLOW BLOCK BOOKING FOR GDS USING RPC Application Setting
Group. OEDS
Type.  Parameter
Application. PMS
ORS
Description. This parameter is used to sell Room Types from a Block via the GDS only when the Block Code is mapped as a Channel Rate Code.
Property Determination.
Activation / Inactivation Rules.
<none>
Available Values.
Y-Yes
N-No
Add On Licenses/Country Specifics.
<none>
Other Application Settings.
<none>
Affected Areas
Menus / Screens / Fields.
<none>
Reports & Report Forms.
<none>
Permissions.
<none>
Other Areas.
<none>
