Configuration - Routing Codes (cf_billinginstructions with GENREPPAR.FMX)
Note: When printing this Report help topic, we recommend printing with Portrait page orientation.
The Configuration report for Routing Codes will display all Routing Codes that have been configured for your property.
Routing Codes are configured in System Configuration>Cashiering>Routing Codes.
When the OPP_GCA Comp Accounting license code is active, the configured Comp Routing Codes will also be displayed on the report output.
Comp Routing Codes are configured in System Configuration>Comp Accounting>Comp Routing Codes.
The report output will display all Transaction Codes attached to the Routing Code. If a Routing Code is attached to another Routing Code, the report will display the Routing Code and the corresponding Transaction Codes that make up that Routing Code.
Routing Code |
Transaction Codes |
REST |
1000, 1001, 1002, (FB - 2001, 2002, 2003) |
Preview. Select to preview the report in a PDF format.
Print. select to print the report.
File. Select to save the report as a file.
Close. Select to exit the specific report.
