previous
Configuration - Market Codes (cf_marketcodes with CFG4.FMX)
Note: When printing this Report help topic, we recommend printing with Portrait page orientation.
The Configuration report for Market Codes will display all Market Codes that have been configured in the application. When the OPP_MHOT Opera Property Management Multi Property Base add-on license code is active, this report will represent Market Codes for the selected Property only.
Market Codes are configured in System Configuration>Rate Management>Codes>Market Codes.
Selection Criteria
Include
Active. Select the check box to include active market codes in the report.
Inactive. Select the check box to include inactive market codes in the report.
Button Functions
Preview. Select to preview the report in a PDF format.
Print. Select to print the report.
File. Select to save the report as a file.
Close. Select to exit the specific report.
