previous
Configuration - Package Codes (cf_packagecodes with GENREPPAR.FMX)
Note: When printing this Report help topic, we recommend printing with Landscape page orientation.
The Configuration report Package Codes will display all Packages that have been configured in the application.
Packages are configured in Configuration>Rate Management>Packages>Package Codes.
Note: When the Rates>Package Pricing and Availability Attributes application function is set to Y, this report will display the Package detail records and will include the Min/Max attributes that have been configured.
Note: Prices and allowances displayed for packages will be the price and allowance from the configuration of the package when it was attached to the reservation. Since the package price and allowance is stored at the reservation level, package prices and allowances can be different from reservation to reservation and from within the Package configuration to the reservation.
Button Functions
Preview. Select to preview the report in a PDF format.
Print. Select to print the report.
File. Select to save the report as a file.
Close. Select to exit the specific report.
Report Data
When the Rates>Multi Currency application parameter is set to Y, then a Currency column is displayed in the report output.
