Configuration - Cities and Postal Codes (cf_postal_codes with CFG7.FMXs)
Note: When printing this Report help topic, we recommend printing with Portrait page orientation.
The Configuration report for Cities and Postal Codes will display Cities and Postal Codes that have been configured in the application.
States are configured in Configuration>Profile>Geographical Data>Cities and Postal Codes.
Country. Multi-select LOV to select a specific Country, but the default is ALL.
State. Multi-select LOV to select a specific State, but the default is ALL.
District. Multi-select LOV to select a specific District, but the default is ALL.
City. Enter the city name to display in the report results.
Postal Code From/To. Enter the From and To Postal Code numbers to narrow down the postal codes of a specific city.
Preview. Select to preview the report in a PDF format.
Print. Select to print the report.
File. Select to save the report as a file.
Close. Select to exit the specific report.
