previous
Configuration - Preferences (cf_preferences with GENREPPAR.FMX)
Note: When printing this Report help topic, we recommend printing with Landscape page orientation.
The Configuration Preferences report will display all preferences that have been configured in the application.
Preferences are configured in Configuration>Profile>Preferences>Preferences.
Function Buttons
Preview. Select to preview the report in a PDF format.
Print. Select to print the report.
File. Select to save the report as a file.
Close. Select to exit the specific report.
Report Output
When the report is displayed, the Preference Groups are displayed in alphabetical order and then the preferences are listed in alphabetical order by Preference Code within each Preference Group.
cf_preferencespdf_1
