Configuration - Rate Class (cf_rateclass with GENREPPAR.FMX)
Note: When printing this Report help topic, we recommend printing with Portrait page orientation.
The Configuration report Rate Class will display all Rate Classes that have been configured. If the license code for multi property functionality is activated (OPP_MHOT), this report will represent all codes on the template form.
Note: When the OPR <version number> ORS license code is active, the Select Property screen appears prior to the Report Parameters screen. Choose the property you want to view and select the OK button. The Report Parameters screen appears.
In PMS, Rate Classes are configured in Configuration>Rate Management>Rate Classes. In ORS, Rate Classes are configured in System Configuration>Rate Management>Rate Classifications>Rate Classes.
Rate Class. Single Select LOV to display a specific rate class. Leave this field blank to display all of the rate classes.
Preview. Select to preview the report in a PDF format.
Print. select to print the report.
File. Select to save the report as a file.
Close. Select to exit the specific report.
