previous
Configuration - Source Codes (cf_sourcecodes with GENREPPAR.FMX)
Note: When printing this Report help topic, we recommend printing with Portrait page orientation.
The Configuration report for Source Codes will display all Source Codes that have been configured in the application. When the OPP_MHOT Opera Property Management Multi-Property Base add-on license code is active, this report will represent all codes on the template form.
Source Codes are configured in Configuration>Rate Management>Codes>Source Codes.
Search Criteria
Include
Active. Select the check box to include active source codes in the report.
Inactive. Select the check box to include the inactive source codes in the report.
Button Functions
Preview. Select to preview the report in a PDF format.
Print. select to print the report.
File. Select to save the report as a file.
Close. Select to exit the specific report.
