previous
Configuration - State Codes (cf_statescodes with GENREPPAR.FMX)
Note: When printing this Report help topic, we recommend printing with Portrait page orientation.
The Configuration report for State Codes will display States that have been configured in the application.
States are configured in Configuration>Profile>Geographical Data>States.
Button Functions
Preview. Select to preview the report in a PDF format.
Print. Select to print the report.
File. Select to save the report as a file.
Close. Select to exit the specific report.
