MAX SNAPSHOTS IN PACE CUBE Application Setting
Group. OBI |
Type. Setting |
Application. |
ORS |
Description. Maximum Snapshot Days that can be RUNNING or BUILDING at once when rebuilding PACE and Monthly PACE Cubes. 0 means all Snapshot days.
Example: If the Pace Cube has 40 snapshots to build and this application setting is set to 5, once the first 5 snapshots start to build, OPERA will start loading the data for the next set of 5 snapshots. This will reduce the wait time between builds.
Internal Name. OBI_MAX_SNAPSHOT_IN_PACE
Property Determination.
Activation / Inactivation Rules. |
<none> |
Available Values. |
Select a value from 1 to 366. |
Add On Licenses/Country Specifics. |
<none> |
Other Application Settings. |
This is a resource intensive operation. Ensure that the OBI>OBI_DAILY_SNAPSHOT_TYPE setting is set to a reasonable value. |
Affected Areas
Menus / Screens / Fields. |
<none> |
Reports & Report Forms. |
<none> |
Permissions. |
<none> |
Notes. |
<none> |
