MAXIMUM BLOCK RATES Application Setting
Group. Blocks |
Type. Setting |
Application. PMS S&C ORS |
Description. Parameter to control the maximum number of rates that can be attached to a business block.
Property Determination. If multiple rate codes are selected for a block header, the background of this field is yellow. In addition, the Rate Codes indicator lamp is displayed. If you select one or more rate codes here, one rate code must be selected as the primary rate code. The primary rate you select will be displayed in this field and carried over to the Room Grid. If the Elastic check box is selected, or if the Inventory Control value is Elastic or Sell Limits, you may select rate codes to apply to Allotments, Begin and End Shoulder periods, as applicable.
Activation / Inactivation Rules. |
<none> |
Available Values. |
<none> |
Add On Licenses/Country Specifics. |
<none> |
Other Application Settings. |
<none> |
Affected Areas
Menus / Screens / Fields. |
Blocks>Business Blocks>Edit>Rooms Tab |
Reports & Report Forms. |
<none> |
Permissions. |
<none> |
Other Areas. |
<none> |
