MULTI BLOCK RATES Application Setting
Group. Blocks |
Type. Parameter |
Application. PMS S&C ORS (Global) |
Description. When the parameter is active (Y), users can select the Rate Code(s) for the business block from a multi-select Rate LOV on the Business Block New or Edit screen. The multiple selected rates display on the Rooming List Pickup screen. If the parameter is set to N, the Rate Code LOV only provides a single rate code selection.
Property Determination.
Activation / Inactivation Rules. |
<none> |
Available Values. |
Y- Yes N- No |
Add On Licenses/Country Specifics. |
<none> |
Other Application Settings. |
<none> |
Affected Areas
Menus / Screens / Fields. |
Reservations>Business Blocks>Edit
Reservations>Business Blocks>Rate Code lamp
Reservations>Business Blocks>Edit>Options>Rooming List |
Reports & Report Forms. |
<none> |
Permissions. |
<none> |
Other Areas. |
<none> |
