previous
Oracle Connection Information for OXI Schema
Refer to the following image and the table below for information on configuring the Oracle connection information for the OXI schema.
Field
Description
User Name
Enter the schema name that you are connecting to. Typically OXI.
Password
Enter the password of the schema you are connecting to.
Note: When an existing OXI Schema password is changed, MICROS Data Centers can access the utility "mfPasswordUpdater.exe" in Opera/Tools/OXI/Utilities on the application server to update the password, instead of using the wizard.
Connection String
Enter the Oracle alias as defined in the TNSNAMES file. Typically OXI.
Check Oracle Connection
Initially, this field displays one of two buttons; either Connected or Not Connected. Select the appropriate button to connect to or disconnect from Oracle.
When you have entered all of the information, select the Next > button. The wizard attempts to connect to the Oracle database.
See Also
