Primary Membership Activity Log (ors_mem_act with GENREPPAR.FMX)
Note: When printing this Report help topic, we recommend printing with Portrait page orientation.
The Primary Membership Activity Log displays information showing changes to a Profile’s Primary Membership, based on a filtered date range.
Change Type. Select the change type you want to view: Current Points, Enrollment Code, Expiration Date, Grace Period Indicator, Member Indicator, Inactive Date, Joined Date, Membership Card No., Membership Level, Membership Status, Name on Card, Name Id.
Membership Level. Select the membership level you want to view.
User (Application User). Select the users who were involved in the membership change activities.
New Value. Manually enter the new value you want to search. The value format must match the standard format of the parameter you want to search.
From/To Date. Enter the date range of when the change occurred.
