previous
OXI DATAMART Parameters OXI_HUB
Parameter Name
Parameter Value
Direction of transmission which parameter applies.
Parameter Description
Recommended Setting
BYPASS CONVERSION DM
(see description)
-> Direction: Data from external system to OPERA
Valid values are RMNSTCYVD and X. RMNSTCYVD means that when conversion fails for a particular field the record is not staged and the value from the external system is inserted in the OPERA Datamart record. Mapping for each field is
R : RATE CODE
M : MARKET CODE
N : CHANNEL CODE
S : SOURCE CODE
T : ROOM TYPE
C : COUNTRY CODE
Y : NATIONALITY
V : VIP CODE
D : TRX CODE
For example if the parameter has values MS then
if no conversion for the incoming market code (M) is found the record is not staged and external value gets inserted.
if no conversion for Channel (N) is found then the record is staged until conversion is created or external value is changed to a convertible value.
