previous
Sample of Export Conversion Codes and Defaults OXI HUB
RESORT,OXI- INTERFACE,CONVERSION_CODE,DESCRIPTION,CC_LABEL,CC_ACTIVE,DTL_ACTIVE,DTL_PMS_VAL,DTL_EXT_VAL,DTL_PMS_DFL,DTL_CRS_DFL,DFLT_PMS, DFLT_EXTERNAL,DFLT_GLOBAL_ACTIVE,
SID-RESORT,OXI-OPERA,ACTION_TYPE,Cancel,Reservation Action Type,Y,Y,CANCEL,CANCEL,Y,Y,,,,
SID-RESORT,OXI-OPERA,ACTION_TYPE,Check In,Reservation Action Type,Y,Y,CHECK IN,CHECKIN,Y,Y,,,,
SID-RESORT,OXI-OPERA,ACTION_TYPE,Check Out,Reservation Action Type,Y,Y,CHECK OUT,CHECKOUT,Y,Y,,,,
SID-RESORT,OXI-OPERA,ACTION_TYPE,Delete Reservation,Reservation Action Type,Y,Y,DELETE RESERVATION,DELETE,Y,Y,,,,
SID-RESORT,OXI-OPERA,ACTION_TYPE,Delete Routing,Reservation Action Type,Y,Y,DELETE ROUTING,DELETE ROUTING,Y,Y,,,,
SID-RESORT,OXI-OPERA,ACTION_TYPE,Delete Trace,Reservation Action Type,Y,Y,DELETE TRACE,DELETE TRACE,Y,Y,,,,
SID-RESORT,OXI-OPERA,ACTION_TYPE,Join Guest,Reservation Action Type,Y,Y,JOIN GUEST,SHARE,Y,Y,,,,
SID-RESORT,OXI-OPERA,ACTION_TYPE,New Reservation,Reservation Action Type,Y,Y,NEW RESERVATION,ADD,Y,Y,,,,
SID-RESORT,OXI-OPERA,ACTION_TYPE,New Routing,Reservation Action Type,Y,Y,NEW ROUTING,NEW ROUTING,Y,Y,,,,
SID-RESORT,OXI-OPERA,ACTION_TYPE,New Trace,Reservation Action Type,Y,Y,NEW TRACE,NEW TRACE ADDED,Y,Y,,,,
SID-RESORT,OXI-OPERA,ACTION_TYPE,No Show,Reservation Action Type,Y,Y,NO SHOW,NOSHOW,Y,Y,,,,
SID-RESORT,OXI-OPERA,ACTION_TYPE,Reactivate No Show,Reservation Action Type,Y,Y,REACTIVATE NO SHOW,REINSTATE,Y,Y,,,,
SID-RESORT,OXI-OPERA,ACTION_TYPE,Reactivate Waitlist,Reservation Action Type,Y,Y,REACTIVATE WAITLIST,WAITLISTTOACTIVE,Y,Y,,,,
SID-RESORT,OXI-OPERA,ACTION_TYPE,Resync Share,Reservation Action Type,Y,Y,RESYNC SHARE,RESYNC SHARE,Y,Y,,,,
SID-RESORT,OXI-OPERA,ACTION_TYPE,Resync,Reservation Action Type,Y,Y,RESYNC,SYNCH,Y,Y,,,,
SID-RESORT,OXI-OPERA,ACTION_TYPE,Reverse Check In,Reservation Action Type,Y,Y,REVERSE CHECK IN,CNXCHECKIN,Y,Y,,,,
SID-RESORT,OXI-OPERA,ACTION_TYPE,Reverse Check Out,Reservation Action Type,Y,Y,REVERSE CHECK OUT,REVERSE CHECK OUT,Y,Y,,,,
SID-RESORT,OXI-OPERA,ACTION_TYPE,Rollback Cancel,Reservation Action Type,Y,Y,ROLLBACK CANCEL,REINSTATE,N,Y,,,,
SID-RESORT,OXI-OPERA,ACTION_TYPE,Separate Guest From Share,Reservation Action Type,Y,Y,SEPARATE GUEST FROM SHARE,ADD,N,Y,,,,
SID-RESORT,OXI-OPERA,ACTION_TYPE,Turnaways,Reservation Action Type,Y,Y,TURNAWAYS,TURNAWAYS,Y,Y,,,,
SID-RESORT,OXI-OPERA,ACTION_TYPE,Update Certificates,Reservation Action Type,Y,Y,UPDATE CERTIFICATES,UPDATE CERTIFICATES,Y,Y,,,,
SID-RESORT,OXI-OPERA,ACTION_TYPE,Update Reservation,Reservation Action Type,Y,Y,UPDATE RESERVATION,EDIT,Y,Y,,,,
SID-RESORT,OXI-OPERA,ACTION_TYPE,Update Routing,Reservation Action Type,Y,Y,UPDATE ROUTING,UPDATE ROUTING,Y,Y,,,,
SID-RESORT,OXI-OPERA,ACTION_TYPE,Update Trace,Reservation Action Type,Y,Y,UPDATE TRACE,UPDATE TRACE,Y,Y,,,,
SID-RESORT,OXI-OPERA,ADDRESS_TYPES,AKDENIZ ADDRESS,Address Type,Y,Y,AKADD,AKADD,Y,Y,,,,
SID-RESORT,OXI-OPERA,ADDRESS_TYPES,Billing Address,Address Type,Y,Y,BILLING,BILLING,Y,Y,,,,
SID-RESORT,OXI-OPERA,ADDRESS_TYPES,Business Address,Address Type,Y,Y,B,BUSINESS,Y,Y,,,,
SID-RESORT,OXI-OPERA,ADDRESS_TYPES,Business,Address Type,Y,Y,B,BUSINESS,Y,Y,,,,
SID-RESORT,OXI-OPERA,ADDRESS_TYPES,Contract Address,Address Type,Y,Y,CONTRACT,CONTRACT,Y,Y,,,,
SID-RESORT,OXI-OPERA,ADDRESS_TYPES,Email Address,Address Type,Y,Y,E,EMAIL,Y,Y,,,,
SID-RESORT,OXI-OPERA,ADDRESS_TYPES,Home Address,Address Type,Y,Y,H,HOME,Y,Y,,,,
SID-RESORT,OXI-OPERA,ADDRESS_TYPES,Home,Address Type,Y,Y,H,HOME,Y,Y,,,,
SID-RESORT,OXI-OPERA,ADDRESS_TYPES,Native Address,Address Type,Y,Y,N,N,Y,Y,,,,
SID-RESORT,OXI-OPERA,ADDRESS_TYPES,Other,Address Type,Y,Y,O,O,Y,Y,,,,
SID-RESORT,OXI-OPERA,ADDRESS_TYPES,P.O. BOX,Address Type,Y,Y,POBOX,POBOX,Y,Y,,,,
SID-RESORT,OXI-OPERA,ADDRESS_TYPES,P.O. Box,Address Type,Y,Y,P,P,Y,Y,,,,
SID-RESORT,OXI-OPERA,ADDRESS_TYPES,Protected Address,Address Type,Y,Y,PROTECTED,PROTECTED,Y,Y,,,,
SID-RESORT,OXI-OPERA,ADDRESS_TYPES,Shipping Address,Address Type,Y,Y,S,S,Y,Y,,,,
SID-RESORT,OXI-OPERA,ADDRESS_TYPES,Shipping Address,Address Type,Y,Y,SHIPPING,SHIPPING,Y,Y,,,,
SID-RESORT,OXI-OPERA,ADDRESS_TYPES,This is the address,Address Type,Y,Y,EMERGENCY CONTACT,EMERGENCY CONTACT,Y,Y,,,,
SID-RESORT,OXI-OPERA,ADDRESS_TYPES,Web Address,Address Type,Y,Y,W,WEBPAGE,Y,Y,,,,
SID-RESORT,OXI-OPERA,ADDRESS_TYPES,address1,Address Type,Y,Y,ADD1,ADD1,Y,Y,,,,
SID-RESORT,OXI-OPERA,ADDRESS_TYPES,address2,Address Type,Y,Y,ADD2,ADD2,Y,Y,,,,
SID-RESORT,OXI-OPERA,ADDRESS_TYPES,t,Address Type,Y,Y,T,T,Y,Y,,,,
SID-RESORT,OXI- OPERA,BLOCK_CANCELLATION_CODES,Cancel - Agent lost business,Block Cancel/Turn/Lost Code,Y,Y,AGT,AGT,Y,Y,,,,
SID-RESORT,OXI- OPERA,BLOCK_CANCELLATION_CODES,Cancel - BB Cancellation Reason,Block Cancel/Turn/Lost Code,Y,Y,BCAN,BCAN,Y,Y,,,,
SID-RESORT,OXI- OPERA,BLOCK_CANCELLATION_CODES,Cancel - Better rates found elsewhere,Block Cancel/Turn/Lost Code,Y,Y,COMP,COMP,Y,Y,,,,
SID-RESORT,OXI- OPERA,BLOCK_CANCELLATION_CODES,Cancel - Broke down in Texas on a tiny back road in the middle of absolutely nowhere and met with a,Block Cancel/Turn/Lost Code,Y,Y,BROKEDOWN,BROKEDOWN,Y,Y,,,,
SID-RESORT,OXI- OPERA,BLOCK_CANCELLATION_CODES,Cancel - Change of plan,Block Cancel/Turn/Lost Code,Y,Y,PLC,PLC,Y,Y,,,,
SID-RESORT,OXI- OPERA,BLOCK_CANCELLATION_CODES,Cancel - Client preferred local competition,Block Cancel/Turn/Lost Code,Y,Y,GPC,GPC,Y,Y,,,,
SID-RESORT,OXI- OPERA,BLOCK_CANCELLATION_CODES,Cancel - Client preferred other destination,Block Cancel/Turn/Lost Code,Y,Y,GPD,GPD,Y,Y,,,,
SID-RESORT,OXI- OPERA,BLOCK_CANCELLATION_CODES,Cancel - Convention/Meeting cancelled,Block Cancel/Turn/Lost Code,Y,Y,CON,CON,Y,Y,,,,
SID-RESORT,OXI- OPERA,BLOCK_CANCELLATION_CODES,Cancel - Date changed,Block Cancel/Turn/Lost Code,Y,Y,DATE,DATE,Y,Y,,,,
SID-RESORT,OXI- OPERA,BLOCK_CANCELLATION_CODES,Cancel - Dates Changed - No Accommadation,Block Cancel/Turn/Lost Code,Y,Y,DATA,DATA,Y,Y,,,,
SID-RESORT,OXI- OPERA,BLOCK_CANCELLATION_CODES,Cancel - Dates Changed - No Func Space,Block Cancel/Turn/Lost Code,Y,Y,DATC,DATC,Y,Y,,,,
SID-RESORT,OXI- OPERA,BLOCK_CANCELLATION_CODES,Cancel - Deposit Conditions not met,Block Cancel/Turn/Lost Code,Y,Y,DEP,DEP,Y,Y,,,,
SID-RESORT,OXI- OPERA,BLOCK_CANCELLATION_CODES,Cancel - Deposit embezzled by Group Leader test cancellation reason,Block Cancel/Turn/Lost Code,Y,Y,EMBZ,EMBZ,Y,Y,,,,
SID-RESORT,OXI- OPERA,BLOCK_CANCELLATION_CODES,Cancel - Distance to Airport,Block Cancel/Turn/Lost Code,Y,Y,AWAY,AWAY,Y,Y,,,,
SID-RESORT,OXI- OPERA,BLOCK_CANCELLATION_CODES,Cancel - Extreme weather related cancellation,Block Cancel/Turn/Lost Code,Y,Y,911WEATHER,911WEATHER,Y,Y,,,,
SID-RESORT,OXI- OPERA,BLOCK_CANCELLATION_CODES,Cancel - Fear of a pending hurricane,Block Cancel/Turn/Lost Code,Y,Y,HURRICANE,HURRICANE,Y,Y,,,,
SID-RESORT,OXI- OPERA,BLOCK_CANCELLATION_CODES,Cancel - Function cancelled,Block Cancel/Turn/Lost Code,Y,Y,FUN,FUN,Y,Y,,,,
SID-RESORT,OXI- OPERA,BLOCK_CANCELLATION_CODES,Cancel - Limited Meeting Space,Block Cancel/Turn/Lost Code,Y,Y,LMS,LMS,Y,Y,,,,
SID-RESORT,OXI- OPERA,BLOCK_CANCELLATION_CODES,Cancel - No Reason given,Block Cancel/Turn/Lost Code,Y,Y,NOR,NOR,Y,Y,,,,
SID-RESORT,OXI- OPERA,BLOCK_CANCELLATION_CODES,Cancel - Number of participants dropped,Block Cancel/Turn/Lost Code,Y,Y,NUMB,NUMB,Y,Y,,,,
SID-RESORT,OXI- OPERA,BLOCK_CANCELLATION_CODES,Cancel - Numbers Dropped - XXLD,Block Cancel/Turn/Lost Code,Y,Y,NUMD,NUMD,Y,Y,,,,
SID-RESORT,OXI- OPERA,BLOCK_CANCELLATION_CODES,Cancel - Numbers Increase - Cannot Accommadate,Block Cancel/Turn/Lost Code,Y,Y,NUMI,NUMI,Y,Y,,,,
SID-RESORT,OXI- OPERA,BLOCK_CANCELLATION_CODES,Cancel - ORS CLIFF TEST,Block Cancel/Turn/Lost Code,Y,Y,ORS,ORS,Y,Y,,,,
SID-RESORT,OXI- OPERA,BLOCK_CANCELLATION_CODES,Cancel - Rate to High,Block Cancel/Turn/Lost Code,Y,Y,RATE,RATE,Y,Y,,,,
SID-RESORT,OXI- OPERA,BLOCK_CANCELLATION_CODES,Cancel - Room Type not available,Block Cancel/Turn/Lost Code,Y,Y,RMT,RMT,Y,Y,,,,
SID-RESORT,OXI- OPERA,BLOCK_CANCELLATION_CODES,Cancel - User Error,Block Cancel/Turn/Lost Code,Y,Y,USERR,USERR,Y,Y,,,,
SID-RESORT,OXI- OPERA,BLOCK_CANCELLATION_CODES,Lost - #'s Outgrew Function Space Available,Block Cancel/Turn/Lost Code,Y,Y,FS,FS,Y,Y,,,,
SID-RESORT,OXI- OPERA,BLOCK_CANCELLATION_CODES,Lost - BB Lost Reason,Block Cancel/Turn/Lost Code,Y,Y,BBLOS,BBLOS,Y,Y,,,,
SID-RESORT,OXI- OPERA,BLOCK_CANCELLATION_CODES,Lost - Change of plan,Block Cancel/Turn/Lost Code,Y,Y,PLC,PLC,Y,Y,,,,
SID-RESORT,OXI- OPERA,BLOCK_CANCELLATION_CODES,Lost - Client preferred local competition,Block Cancel/Turn/Lost Code,Y,Y,GPC,GPC,Y,Y,,,,
SID-RESORT,OXI- OPERA,BLOCK_CANCELLATION_CODES,Lost - Client preferred other destination,Block Cancel/Turn/Lost Code,Y,Y,GPD,GPD,Y,Y,,,,
SID-RESORT,OXI- OPERA,BLOCK_CANCELLATION_CODES,Lost - Convention/Meeting cancelled,Block Cancel/Turn/Lost Code,Y,Y,CON,CON,Y,Y,,,,
SID-RESORT,OXI- OPERA,BLOCK_CANCELLATION_CODES,Lost - Extreme conditions prevent guest from being able to travel,Block Cancel/Turn/Lost Code,Y,Y,911 UNABLE,911 UNABLE,Y,Y,,,,
SID-RESORT,OXI- OPERA,BLOCK_CANCELLATION_CODES,Lost - Group arrested due to scandal Test lost booking reason,Block Cancel/Turn/Lost Code,Y,Y,SCND,SCND,Y,Y,,,,
SID-RESORT,OXI- OPERA,BLOCK_CANCELLATION_CODES,Lost - Lost Budgeted Funding for Event(s),Block Cancel/Turn/Lost Code,Y,Y,LF,LF,Y,Y,,,,
SID-RESORT,OXI- OPERA,BLOCK_CANCELLATION_CODES,Lost - ORS CLIFF TEST,Block Cancel/Turn/Lost Code,Y,Y,ORS,ORS,Y,Y,,,,
SID-RESORT,OXI- OPERA,BLOCK_CANCELLATION_CODES,Lost - Price to high,Block Cancel/Turn/Lost Code,Y,Y,PH,PH,Y,Y,,,,
SID-RESORT,OXI- OPERA,BLOCK_CANCELLATION_CODES,Lost - Rate Too High,Block Cancel/Turn/Lost Code,Y,Y,RATE,RATE,Y,Y,,,,
SID-RESORT,OXI- OPERA,BLOCK_CANCELLATION_CODES,Lost - Rate Too High,Block Cancel/Turn/Lost Code,Y,Y,RTH,RTH,Y,Y,,,,
SID-RESORT,OXI- OPERA,BLOCK_CANCELLATION_CODES,Turn Down - BB Refused Reason,Block Cancel/Turn/Lost Code,Y,Y,BBREF,BBREF,Y,Y,,,,
SID-RESORT,OXI- OPERA,BLOCK_CANCELLATION_CODES,Turn Down - Budget Restriction,Block Cancel/Turn/Lost Code,Y,Y,BUD,BUD,Y,Y,,,,
SID-RESORT,OXI- OPERA,BLOCK_CANCELLATION_CODES,Turn Down - Changed locations,Block Cancel/Turn/Lost Code,Y,Y,REL,REL,Y,Y,,,,
SID-RESORT,OXI- OPERA,BLOCK_CANCELLATION_CODES,Turn Down - Company has gone out of business and event cancelled,Block Cancel/Turn/Lost Code,Y,Y,OUTOFBUS,OUTOFBUS,Y,Y,,,,
SID-RESORT,OXI- OPERA,BLOCK_CANCELLATION_CODES,Turn Down - Data Entry Error,Block Cancel/Turn/Lost Code,Y,Y,ERR,ERR,Y,Y,,,,
SID-RESORT,OXI- OPERA,BLOCK_CANCELLATION_CODES,Turn Down - Dates Unavailable\Inflexable,Block Cancel/Turn/Lost Code,Y,Y,DAT,DAT,Y,Y,,,,
SID-RESORT,OXI- OPERA,BLOCK_CANCELLATION_CODES,Turn Down - Decision Maker did not sign Contract,Block Cancel/Turn/Lost Code,Y,Y,DM,DM,Y,Y,,,,
SID-RESORT,OXI- OPERA,BLOCK_CANCELLATION_CODES,Turn Down - Facilities too small for Request,Block Cancel/Turn/Lost Code,Y,Y,SML,SML,Y,Y,,,,
SID-RESORT,OXI- OPERA,BLOCK_CANCELLATION_CODES,Turn Down - Group too big,Block Cancel/Turn/Lost Code,Y,Y,BIG,BIG,Y,Y,,,,
SID-RESORT,OXI- OPERA,BLOCK_CANCELLATION_CODES,Turn Down - Guests have bad attitudes,Block Cancel/Turn/Lost Code,Y,Y,ATTITUDE,ATTITUDE,Y,Y,,,,
SID-RESORT,OXI- OPERA,BLOCK_CANCELLATION_CODES,Turn Down - Message Light Attitude,Block Cancel/Turn/Lost Code,Y,Y,MSG,MSG,Y,Y,,,,
SID-RESORT,OXI- OPERA,BLOCK_CANCELLATION_CODES,Turn Down - No Accommodation Available,Block Cancel/Turn/Lost Code,Y,Y,ACC,ACC,Y,Y,,,,
SID-RESORT,OXI- OPERA,BLOCK_CANCELLATION_CODES,Turn Down - No Catering Facilities Available,Block Cancel/Turn/Lost Code,Y,Y,CAT,CAT,Y,Y,,,,
SID-RESORT,OXI- OPERA,BLOCK_CANCELLATION_CODES,Turn Down - Not enough Capacity Rooms & Space,Block Cancel/Turn/Lost Code,Y,Y,NOC,NOC,Y,Y,,,,
SID-RESORT,OXI- OPERA,BLOCK_CANCELLATION_CODES,Turn Down - Not enough Function Space available,Block Cancel/Turn/Lost Code,Y,Y,NOF,NOF,Y,Y,,,,
SID-RESORT,OXI- OPERA,BLOCK_CANCELLATION_CODES,Turn Down - Not enough Room,Block Cancel/Turn/Lost Code,Y,Y,NOR,NOR,Y,Y,,,,
SID-RESORT,OXI- OPERA,BLOCK_CANCELLATION_CODES,Turn Down - ORS CLIFF TEST,Block Cancel/Turn/Lost Code,Y,Y,ORS,ORS,Y,Y,,,,
SID-RESORT,OXI- OPERA,BLOCK_CANCELLATION_CODES,Turn Down - Sleeping Rooms Limitation,Block Cancel/Turn/Lost Code,Y,Y,SRL,SRL,Y,Y,,,,
SID-RESORT,OXI- OPERA,BLOCK_CANCELLATION_CODES,Turn Down - staff members wish to vacation Test refusal reason,Block Cancel/Turn/Lost Code,Y,Y,VAC,VAC,Y,Y,,,,
SID-RESORT,OXI-OPERA,CANCELLATION_CODES,35 test,Reservation Cancellation Code,Y,Y,35,35,Y,Y,,,,
SID-RESORT,OXI-OPERA,CANCELLATION_CODES,ADS- CANCEL,Reservation Cancellation Code,Y,Y,ADS-CANCEL,ADS-CANCEL,Y,Y,,,,
SID-RESORT,OXI-OPERA,CANCELLATION_CODES,Airport Closed,Reservation Cancellation Code,Y,Y,APCLOS,APCLOS,Y,Y,,,,
SID-RESORT,OXI-OPERA,CANCELLATION_CODES,Broke down in Texas on a tiny back road in the middle of absolutely nowhere and met with a murderin,Reservation Cancellation Code,Y,Y,BROKEDOWN,BROKEDOWN,Y,Y,,,,
SID-RESORT,OXI-OPERA,CANCELLATION_CODES,Change of Business Event Place or Date,Reservation Cancellation Code,Y,Y,BUS,BUS,Y,Y,,,,
SID-RESORT,OXI-OPERA,CANCELLATION_CODES,Change of plan,Reservation Cancellation Code,Y,Y,PLC,PLC,Y,Y,,,,
SID-RESORT,OXI-OPERA,CANCELLATION_CODES,Convention cancelled,Reservation Cancellation Code,Y,Y,CON,CON,Y,Y,,,,
SID-RESORT,OXI-OPERA,CANCELLATION_CODES,Death in Family,Reservation Cancellation Code,Y,Y,DEATH,DEATH,Y,Y,,,,
SID-RESORT,OXI-OPERA,CANCELLATION_CODES,Doubl Booking,Reservation Cancellation Code,Y,Y,DBLBKG,DBLBKG,Y,Y,,,,
SID-RESORT,OXI-OPERA,CANCELLATION_CODES,Duplicate Booking,Reservation Cancellation Code,Y,Y,DUPE,DUPE,Y,Y,,,,
SID-RESORT,OXI-OPERA,CANCELLATION_CODES,Flight Cancelled,Reservation Cancellation Code,Y,Y,FLIGHT,FLIGHT,Y,Y,,,,
SID-RESORT,OXI-OPERA,CANCELLATION_CODES,Generic Cancel Rule,Reservation Cancellation Code,Y,Y,GCR,GCR,Y,Y,,,,
SID-RESORT,OXI-OPERA,CANCELLATION_CODES,Group Cancelled,Reservation Cancellation Code,Y,Y,GRP,GRP,Y,Y,,,,
SID-RESORT,OXI-OPERA,CANCELLATION_CODES,Guest Cahnged,Reservation Cancellation Code,Y,Y,CHGITI,CHGITI,Y,Y,,,,
SID-RESORT,OXI-OPERA,CANCELLATION_CODES,Guest decided to stay at home,Reservation Cancellation Code,Y,Y,HOME,HOME,Y,Y,,,,
SID-RESORT,OXI-OPERA,CANCELLATION_CODES,Guest found cheaper Hotel,Reservation Cancellation Code,Y,Y,OTHTL,OTHTL,Y,Y,,,,
SID-RESORT,OXI-OPERA,CANCELLATION_CODES,Guest illness,Reservation Cancellation Code,Y,Y,ILL,ILL,Y,Y,,,,
SID-RESORT,OXI-OPERA,CANCELLATION_CODES,Local competition preferred,Reservation Cancellation Code,Y,Y,GPC,GPC,Y,Y,,,,
SID-RESORT,OXI-OPERA,CANCELLATION_CODES,Natural Calamities,Reservation Cancellation Code,Y,Y,NATCAL,NATCAL,Y,Y,,,,
SID-RESORT,OXI-OPERA,CANCELLATION_CODES,No Reason,Reservation Cancellation Code,Y,Y,NOREAS,NOREAS,Y,Y,,,,
SID-RESORT,OXI-OPERA,CANCELLATION_CODES,No reason given,Reservation Cancellation Code,Y,Y,NONE,NONE,Y,Y,,,,
SID-RESORT,OXI-OPERA,CANCELLATION_CODES,ODS CANCEL,Reservation Cancellation Code,Y,Y,ODS-CANCEL,ODS-CANCEL,Y,Y,,,,
SID-RESORT,OXI-OPERA,CANCELLATION_CODES,Other destination preferred,Reservation Cancellation Code,Y,Y,GPD,GPD,Y,Y,,,,
SID-RESORT,OXI- OPERA,CANCELLATION_CODES,Others,Reservation Cancellation Code,Y,Y,OTHERS,OTHERS,Y,Y,,,,
SID-RESORT,OXI-OPERA,CANCELLATION_CODES,Rate Too High,Reservation Cancellation Code,Y,Y,RATE,RATE,Y,Y,,,,
SID-RESORT,OXI-OPERA,CANCELLATION_CODES,Reservation Cancel because of move.,Reservation Cancellation Code,Y,Y,MOVE_RESV,MOVE_RESV,Y,Y,,,,
SID-RESORT,OXI-OPERA,CANCELLATION_CODES,Reservation Cancel due to block cancellation received by OXI.,Reservation Cancellation Code,Y,Y,BLK_CNCL,BLK_CNCL,Y,Y,,,,
SID-RESORT,OXI-OPERA,CANCELLATION_CODES,Schedule Change of Business Meeting,Reservation Cancellation Code,Y,Y,SCHC,SCHC,Y,Y,,,,
SID-RESORT,OXI-OPERA,CANCELLATION_CODES,Testing numeric code vs. alpha,Reservation Cancellation Code,Y,Y,1234567890,1234567890,Y,Y,,,,
SID-RESORT,OXI-OPERA,CANCELLATION_CODES,Weather Conditions,Reservation Cancellation Code,Y,Y,WEATHER,WEATHER,Y,Y,,,,
SID-RESORT,OXI-OPERA,CANCELLATION_CODES,Web Cancellation,Reservation Cancellation Code,Y,Y,WEB,WEB,Y,Y,,,,
SID-RESORT,OXI-OPERA,CANCELLATION_CODES,transfer to,Reservation Cancellation Code,Y,Y,TSFRTO,TSFRTO,Y,Y,,,,
SID-RESORT,OXI-OPERA,CHANNEL_CODES,1A,Channel Code,Y,Y,1A,1A,Y,Y,,,,
SID-RESORT,OXI-OPERA,CHANNEL_CODES,1P,Channel Code,Y,Y,1P,1P,Y,Y,,,,
SID-RESORT,OXI-OPERA,CHANNEL_CODES,35 test,Channel Code,Y,Y,35,35,Y,Y,,,,
SID-RESORT,OXI-OPERA,CHANNEL_CODES,AA,Channel Code,Y,Y,AA,AA,Y,Y,,,,
SID-RESORT,OXI-OPERA,CHANNEL_CODES,ADS Interface,Channel Code,Y,Y,ADS,ADS,Y,Y,,,,
SID-RESORT,OXI-OPERA,CHANNEL_CODES,Amadeus,Channel Code,Y,Y,AMADEUS,AMADEUS,Y,Y,,,,
SID-RESORT,OXI-OPERA,CHANNEL_CODES,CRO,Channel Code,Y,Y,CRO,CRO,Y,Y,,,,
SID-RESORT,OXI-OPERA,CHANNEL_CODES,Company Direct,Channel Code,Y,Y,HCO,HCO,Y,Y,,,,
SID-RESORT,OXI- OPERA,CHANNEL_CODES,DEFAULT,Channel Code,Y,Y,DEFAULT,DEFAULT,Y,Y,,,,
SID-RESORT,OXI-OPERA,CHANNEL_CODES,E-Mail,Channel Code,Y,Y,EMAIL,EMAIL,Y,Y,,,,
SID-RESORT,OXI-OPERA,CHANNEL_CODES,Fax/Letter,Channel Code,Y,Y,FAX,FAX,Y,Y,,,,
SID-RESORT,OXI-OPERA,CHANNEL_CODES,GDS,Channel Code,Y,Y,GDS,GDS,Y,Y,,,,
SID-RESORT,OXI-OPERA,CHANNEL_CODES,Galileo,Channel Code,Y,Y,GALILEO,GALILEO,Y,Y,,,,
SID-RESORT,OXI-OPERA,CHANNEL_CODES,Generic Origin Code,Channel Code,Y,Y,GOC,GOC,Y,Y,,,,
SID-RESORT,OXI-OPERA,CHANNEL_CODES,Germany,Channel Code,Y,Y,DE,DE,Y,Y,,,,
SID-RESORT,OXI-OPERA,CHANNEL_CODES,Group Direct,Channel Code,Y,Y,HDG,HDG,Y,Y,,,,
SID-RESORT,OXI-OPERA,CHANNEL_CODES,Guest Direct/Walk- in,Channel Code,Y,Y,HDI,HDI,Y,Y,,,,
SID-RESORT,OXI-OPERA,CHANNEL_CODES,Guest Direct/Walk- in,Channel Code,Y,Y,HTO,HTO,Y,Y,,,,
SID-RESORT,OXI-OPERA,CHANNEL_CODES,Hong Kong Regional Reservation Center,Channel Code,Y,Y,HKRRC,HKRRC,Y,Y,,,,
SID-RESORT,OXI-OPERA,CHANNEL_CODES,Hotel Website,Channel Code,Y,Y,WWI,WWI,Y,Y,,,,
SID-RESORT,OXI-OPERA,CHANNEL_CODES,Internet Group,Channel Code,Y,Y,ING,ING,Y,Y,,,,
SID-RESORT,OXI-OPERA,CHANNEL_CODES,Internet Web Portals,Channel Code,Y,Y,INI,INI,Y,Y,,,,
SID-RESORT,OXI-OPERA,CHANNEL_CODES,Internet Web Site,Channel Code,Y,Y,INT,INT,Y,Y,,,,
SID-RESORT,OXI-OPERA,CHANNEL_CODES,Internet Wholesalers,Channel Code,Y,Y,IWS,IWS,Y,Y,,,,
SID-RESORT,OXI-OPERA,CHANNEL_CODES,Internet/E- Mail/Btx,Channel Code,Y,Y,WWW,WWW,Y,Y,,,,
SID-RESORT,OXI-OPERA,CHANNEL_CODES,Myfidelio cro,Channel Code,Y,Y,MYF/CRO,MYF/CRO,Y,Y,,,,
SID-RESORT,OXI-OPERA,CHANNEL_CODES,Naples CRO,Channel Code,Y,Y,NAPLES,NAPLES,Y,Y,,,,
SID-RESORT,OXI-OPERA,CHANNEL_CODES,ORS,Channel Code,Y,Y,ORS,ORS,Y,Y,,,,
SID-RESORT,OXI-OPERA,CHANNEL_CODES,Other,Channel Code,Y,Y,OTH,OTH,Y,Y,,,,
SID-RESORT,OXI-OPERA,CHANNEL_CODES,PMS,Channel Code,Y,Y,PMS,PMS,Y,Y,,,,
SID-RESORT,OXI-OPERA,CHANNEL_CODES,Pegasus Voice,Channel Code,Y,Y,CRI,CRI,Y,Y,,,,
SID-RESORT,OXI-OPERA,CHANNEL_CODES,RRC- Guangzhou,Channel Code,Y,Y,RGZ,RGZ,Y,Y,,,,
SID-RESORT,OXI-OPERA,CHANNEL_CODES,RRC-Hong Kong,Channel Code,Y,Y,RHK,RHK,Y,Y,,,,
SID-RESORT,OXI-OPERA,CHANNEL_CODES,RRC-Kuala Lumpur,Channel Code,Y,Y,RKL,RKL,Y,Y,,,,
SID-RESORT,OXI-OPERA,CHANNEL_CODES,RRC- London,Channel Code,Y,Y,RLO,RLO,Y,Y,,,,
SID-RESORT,OXI-OPERA,CHANNEL_CODES,RRC- Tokyo,Channel Code,Y,Y,RTO,RTO,Y,Y,,,,
SID-RESORT,OXI-OPERA,CHANNEL_CODES,RSO Group,Channel Code,Y,Y,RSG,RSG,Y,Y,,,,
SID-RESORT,OXI-OPERA,CHANNEL_CODES,RSO- Beijing,Channel Code,Y,Y,BJS,BJS,Y,Y,,,,
SID-RESORT,OXI-OPERA,CHANNEL_CODES,RSO- Dubai,Channel Code,Y,Y,DBX,DBX,Y,Y,,,,
SID-RESORT,OXI-OPERA,CHANNEL_CODES,RSO- Guangzhou,Channel Code,Y,Y,CAN,CAN,Y,Y,,,,
SID-RESORT,OXI-OPERA,CHANNEL_CODES,RSO-Hong Kong,Channel Code,Y,Y,HKG,HKG,Y,Y,,,,
SID-RESORT,OXI-OPERA,CHANNEL_CODES,RSO- London,Channel Code,Y,Y,LON,LON,Y,Y,,,,
SID-RESORT,OXI-OPERA,CHANNEL_CODES,RSO-Los Angeles,Channel Code,Y,Y,LAX,LAX,Y,Y,,,,
SID-RESORT,OXI-OPERA,CHANNEL_CODES,RSO- Melbourne,Channel Code,Y,Y,MEL,MEL,Y,Y,,,,
SID-RESORT,OXI-OPERA,CHANNEL_CODES,RSO-New York,Channel Code,Y,Y,NYC,NYC,Y,Y,,,,
SID-RESORT,OXI-OPERA,CHANNEL_CODES,RSO- Shanghai,Channel Code,Y,Y,SHA,SHA,Y,Y,,,,
SID-RESORT,OXI-OPERA,CHANNEL_CODES,RSO- Singapore,Channel Code,Y,Y,SIN,SIN,Y,Y,,,,
SID-RESORT,OXI-OPERA,CHANNEL_CODES,RSO- Sydney,Channel Code,Y,Y,SYD,SYD,Y,Y,,,,
SID-RESORT,OXI-OPERA,CHANNEL_CODES,RSO- Tokyo,Channel Code,Y,Y,TYO,TYO,Y,Y,,,,
SID-RESORT,OXI-OPERA,CHANNEL_CODES,Sabre,Channel Code,Y,Y,SABRE,SABRE,Y,Y,,,,
SID-RESORT,OXI-OPERA,CHANNEL_CODES,Shangri- La.com,Channel Code,Y,Y,ISG,ISG,Y,Y,,,,
SID-RESORT,OXI-OPERA,CHANNEL_CODES,Sister Hotels Group,Channel Code,Y,Y,SHG,SHG,Y,Y,,,,
SID-RESORT,OXI-OPERA,CHANNEL_CODES,Sister Hotels,Channel Code,Y,Y,SHI,SHI,Y,Y,,,,
SID-RESORT,OXI- OPERA,CHANNEL_CODES,Switzerland,Channel Code,Y,Y,CH,CH,Y,Y,,,,
SID-RESORT,OXI- OPERA,CHANNEL_CODES,Telephone,Channel Code,Y,Y,TEL,TEL,Y,Y,,,,
SID-RESORT,OXI-OPERA,CHANNEL_CODES,Travel Agent Direct,Channel Code,Y,Y,HTA,HTA,Y,Y,,,,
SID-RESORT,OXI-OPERA,CHANNEL_CODES,UA,Channel Code,Y,Y,UA,UA,Y,Y,,,,
SID-RESORT,OXI-OPERA,CHANNEL_CODES,USA,Channel Code,Y,Y,US,US,Y,Y,,,,
SID-RESORT,OXI-OPERA,CHANNEL_CODES,Utell Central Reservations,Channel Code,Y,Y,UTELL,UTELL,Y,Y,,,,
SID-RESORT,OXI-OPERA,CHANNEL_CODES,WC Web Site,Channel Code,Y,Y,WCWEB,WCWEB,Y,Y,,,,
SID-RESORT,OXI-OPERA,CHANNEL_CODES,Walk In Guest,Channel Code,Y,Y,WALK,WALK,Y,Y,,,,
SID-RESORT,OXI-OPERA,CHANNEL_CODES,Website,Channel Code,Y,Y,WEB,WEB,Y,Y,,,,
SID-RESORT,OXI-OPERA,CHANNEL_CODES,WestCoast Family of Hotels Website,Channel Code,Y,Y,WHCWEB,WHCWEB,Y,Y,,,,
SID-RESORT,OXI- OPERA,CHANNEL_CODES,Worldspan,Channel Code,Y,Y,WORLDSPAN,WORLDSPAN,Y,Y,,,,
SID-RESORT,OXI-OPERA,CHANNEL_CODES,myfidelio saber,Channel Code,Y,Y,MYF/AA,MYF/AA,Y,Y,,,,
SID-RESORT,OXI-OPERA,CHANNEL_CODES,test,Channel Code,Y,Y,SPOKANE,SPOKANE,Y,Y,,,,
SID-RESORT,OXI-OPERA,COMMENT_TYPE,ACCOUNT  21- 456789012345678901,Comment Type,Y,Y,12345678901234567890,12345678901234567890,Y,Y,,,,
SID-RESORT,OXI-OPERA,COMMENT_TYPE,ACCOUNT 5,Comment Type,Y,Y,5,5,Y,Y,,,,
SID-RESORT,OXI-OPERA,COMMENT_TYPE,ACCOUNT AKDENIZ NOTE TYPE,Comment Type,Y,Y,AKD,AKD,Y,Y,,,,
SID-RESORT,OXI-OPERA,COMMENT_TYPE,ACCOUNT Accounting Note Style 1,Comment Type,Y,Y,Accounting 1,Accounting 1,Y,Y,,,,
SID-RESORT,OXI-OPERA,COMMENT_TYPE,ACCOUNT  Central Comments,Comment Type,Y,Y,CCOMMENT,CCOMMENT,Y,Y,,,,
SID-RESORT,OXI-OPERA,COMMENT_TYPE,ACCOUNT Corporate History,Comment Type,Y,Y,HISTORY,HISTORY,Y,Y,,,,
SID-RESORT,OXI-OPERA,COMMENT_TYPE,ACCOUNT Financial Notes,Comment Type,Y,Y,FIN,FIN,Y,Y,,,,
SID-RESORT,OXI-OPERA,COMMENT_TYPE,ACCOUNT  General Notes,Comment Type,Y,Y,GEN,GEN,Y,Y,,,,
SID-RESORT,OXI-OPERA,COMMENT_TYPE,ACCOUNT Management Note,Comment Type,Y,Y,MGMT,MGMT,Y,Y,,,,
SID-RESORT,OXI-OPERA,COMMENT_TYPE,ACCOUNT Marketing Notes,Comment Type,Y,Y,MTG,MTG,Y,Y,,,,
SID-RESORT,OXI-OPERA,COMMENT_TYPE,ACCOUNT  Profile inactivated during IATA upload.,Comment Type,Y,Y,IATA-INACTIVE,IATA- INACTIVE,Y,Y,,,,
SID-RESORT,OXI-OPERA,COMMENT_TYPE,ACCOUNT Property Notes,Comment Type,Y,Y,PROPERTY,PROPERTY,Y,Y,,,,
SID-RESORT,OXI-OPERA,COMMENT_TYPE,ACCOUNT Reservation Notes,Comment Type,Y,Y,RES,RES,Y,Y,,,,
SID-RESORT,OXI-OPERA,COMMENT_TYPE,ACCOUNT  Stef's Note Type,Comment Type,Y,Y,Stef,Stef,Y,Y,,,,
SID-RESORT,OXI-OPERA,COMMENT_TYPE,ACCOUNT  Testing Notes,Comment Type,Y,Y,Test,Test,Y,Y,,,,
SID-RESORT,OXI-OPERA,COMMENT_TYPE,ACCOUNT  Web Notes,Comment Type,Y,Y,OWS,OWS,Y,Y,,,,
SID-RESORT,OXI-OPERA,COMMENT_TYPE,BOOKING  10 characters,Comment Type,Y,Y,1234567890,1234567890,Y,Y,,,,
SID-RESORT,OXI-OPERA,COMMENT_TYPE,BOOKING  11 characters,Comment Type,Y,Y,12345678901,12345678901,Y,Y,,,,
SID-RESORT,OXI-OPERA,COMMENT_TYPE,BOOKING  12 characters,Comment Type,Y,Y,123456789012,123456789012,Y,Y,,,,
SID-RESORT,OXI-OPERA,COMMENT_TYPE,BOOKING  20 characters,Comment Type,Y,Y,12345678901234567890,12345678901234567890,Y,Y,,,,
SID-RESORT,OXI-OPERA,COMMENT_TYPE,BOOKING  21- 456789012345678901,Comment Type,Y,Y,12345678901234567899,12345678901234567899,Y,Y,,,,
SID-RESORT,OXI-OPERA,COMMENT_TYPE,BOOKING Accommodations Notes,Comment Type,Y,Y,ACC,ACC,Y,Y,,,,
SID-RESORT,OXI-OPERA,COMMENT_TYPE,BOOKING Agreement Notes,Comment Type,Y,Y,AGR,AGR,Y,Y,,,,
SID-RESORT,OXI-OPERA,COMMENT_TYPE,BOOKING  Billing Instruction,Comment Type,Y,Y,BIL,BIL,Y,Y,,,,
SID-RESORT,OXI-OPERA,COMMENT_TYPE,BOOKING Cancellation Notes,Comment Type,Y,Y,CAN,CAN,Y,Y,,,,
SID-RESORT,OXI-OPERA,COMMENT_TYPE,BOOKING  Catering Notes,Comment Type,Y,Y,CAT,CAT,Y,Y,,,,
SID-RESORT,OXI-OPERA,COMMENT_TYPE,BOOKING  Deposit Notes,Comment Type,Y,Y,DEP,DEP,Y,Y,,,,
SID-RESORT,OXI-OPERA,COMMENT_TYPE,BOOKING  General Notes,Comment Type,Y,Y,GEN,GEN,Y,Y,,,,
SID-RESORT,OXI-OPERA,COMMENT_TYPE,BOOKING INTERFACE NOTES,Comment Type,Y,Y,OXI,OXI,Y,Y,,,,
SID-RESORT,OXI-OPERA,COMMENT_TYPE,BOOKING  Info Notes,Comment Type,Y,Y,INFO,INFO,Y,Y,,,,
SID-RESORT,OXI-OPERA,COMMENT_TYPE,BOOKING  Interface Notes,Comment Type,Y,Y,HOTEL,HOTEL,Y,Y,,,,
SID-RESORT,OXI-OPERA,COMMENT_TYPE,BOOKING  Interface Notes,Comment Type,Y,Y,LEA,LEA,Y,Y,,,,
SID-RESORT,OXI-OPERA,COMMENT_TYPE,BOOKING  Interface Notes,Comment Type,Y,Y,LRP,LRP,Y,Y,,,,
SID-RESORT,OXI-OPERA,COMMENT_TYPE,BOOKING  Liz Contract Notes,Comment Type,Y,Y,LIZ,LIZ,Y,Y,,,,
SID-RESORT,OXI-OPERA,COMMENT_TYPE,BOOKING  Meeting Agenda Notes,Comment Type,Y,Y,AGN,AGN,Y,Y,,,,
SID-RESORT,OXI-OPERA,COMMENT_TYPE,BOOKING Reservation Notes,Comment Type,Y,Y,RES,RES,Y,Y,,,,
SID-RESORT,OXI-OPERA,COMMENT_TYPE,BOOKING  Sofa Notes,Comment Type,Y,Y,sofa,sofa,Y,Y,,,,
SID-RESORT,OXI-OPERA,COMMENT_TYPE,CONTACT Background Notes,Comment Type,Y,Y,BKG,BKG,Y,Y,,,,
SID-RESORT,OXI-OPERA,COMMENT_TYPE,CONTACT  Central Comments,Comment Type,Y,Y,CCOMMENT,CCOMMENT,Y,Y,,,,
SID-RESORT,OXI-OPERA,COMMENT_TYPE,CONTACT Contact,Comment Type,Y,Y,Contact,Contact,Y,Y,,,,
SID-RESORT,OXI-OPERA,COMMENT_TYPE,CONTACT Employee Notes,Comment Type,Y,Y,EMP,EMP,Y,Y,,,,
SID-RESORT,OXI-OPERA,COMMENT_TYPE,CONTACT  General Notes,Comment Type,Y,Y,GEN,GEN,Y,Y,,,,
SID-RESORT,OXI-OPERA,COMMENT_TYPE,CONTACT  Outlook Note,Comment Type,Y,Y,OUT,OUT,Y,Y,,,,
SID-RESORT,OXI-OPERA,COMMENT_TYPE,CONTACT  Property Notes,Comment Type,Y,Y,PROPERTY,PROPERTY,Y,Y,,,,
SID-RESORT,OXI-OPERA,COMMENT_TYPE,CONTACT Reservation Notes,Comment Type,Y,Y,RES,RES,Y,Y,,,,
SID-RESORT,OXI-OPERA,COMMENT_TYPE,CONTACT  Sarah's Notes...,Comment Type,Y,Y,SARAH,SARAH,Y,Y,,,,
SID-RESORT,OXI-OPERA,COMMENT_TYPE,CONTACT  Slim test note type,Comment Type,Y,Y,SLIM,SLIM,Y,Y,,,,
SID-RESORT,OXI-OPERA,COMMENT_TYPE,CONTACT  Web Notes,Comment Type,Y,Y,OWS,OWS,Y,Y,,,,
SID-RESORT,OXI-OPERA,COMMENT_TYPE,CONTACT  a long note type,Comment Type,Y,Y,12345678901234567891,12345678901234567891,Y,Y,,,,
SID-RESORT,OXI-OPERA,COMMENT_TYPE,CONTRACT Blackout Period Notes,Comment Type,Y,Y,BLACKOUT,BLACKOUT,Y,Y,,,,
SID-RESORT,OXI-OPERA,COMMENT_TYPE,CONTRACT General Notes,Comment Type,Y,Y,GEN,GEN,Y,Y,,,,
SID-RESORT,OXI-OPERA,COMMENT_TYPE,Displayed after check in,Comment Type,Y,Y,IN HOUSE,IN HOUSE,Y,Y,,,,
SID-RESORT,OXI-OPERA,COMMENT_TYPE,Displayed on billing screen,Comment Type,Y,Y,CASHIER,CASHIER,Y,Y,,,,
SID-RESORT,OXI-OPERA,COMMENT_TYPE,Displayed prior to check in,Comment Type,Y,Y,RESERVATION,RESERVATION,Y,Y,,,,
SID-RESORT,OXI-OPERA,COMMENT_TYPE,EMPLOYEE  Profile Notes,Comment Type,Y,Y,PROFILE,PROFILE,Y,Y,,,,
SID-RESORT,OXI-OPERA,COMMENT_TYPE,EMPLOYEE Reservation Notes,Comment Type,Y,Y,RESERVATION,RESERVATION,Y,Y,,,,
SID-RESORT,OXI-OPERA,COMMENT_TYPE,EVENT  11 characters,Comment Type,Y,Y,12345678901,12345678901,Y,Y,,,,
SID-RESORT,OXI-OPERA,COMMENT_TYPE,EVENT  15 characters,Comment Type,Y,Y,123456789012345,123456789012345,Y,Y,,,,
SID-RESORT,OXI-OPERA,COMMENT_TYPE,EVENT  19 characters,Comment Type,Y,Y,1234567890123456789,1234567890123456789,Y,Y,,,,
SID-RESORT,OXI-OPERA,COMMENT_TYPE,EVENT  20 characters long long long longlonglonglonglonglonglonglonglonglonglgonglonglonglonglonglo,Comment Type,Y,Y,12345678901234567890,12345678901234567890,Y,Y,,,,
SID-RESORT,OXI-OPERA,COMMENT_TYPE,EVENT  20 characters,Comment Type,Y,Y,12345678901234567896,12345678901234567896,Y,Y,,,,
SID-RESORT,OXI-OPERA,COMMENT_TYPE,EVENT 20description1234567,Comment Type,Y,Y,12345678901234567899,12345678901234567899,Y,Y,,,,
SID-RESORT,OXI-OPERA,COMMENT_TYPE,EVENT  21- 456789012345678901,Comment Type,Y,Y,66665555555888888811,66665555555888888811,Y,Y,,,,
SID-RESORT,OXI-OPERA,COMMENT_TYPE,EVENT  25 4367890123456789012345,Comment Type,Y,Y,11111111111111111111,11111111111111111111,Y,Y,,,,
SID-RESORT,OXI-OPERA,COMMENT_TYPE,EVENT Change,Comment Type,Y,Y,CH,CH,Y,Y,,,,
SID-RESORT,OXI-OPERA,COMMENT_TYPE,EVENT  Event Set- Up Notes,Comment Type,Y,Y,Setup,Setup,Y,Y,,,,
SID-RESORT,OXI-OPERA,COMMENT_TYPE,EVENT Event,Comment Type,Y,Y,EV,EV,Y,Y,,,,
SID-RESORT,OXI-OPERA,COMMENT_TYPE,EVENT  Noise Level,Comment Type,Y,Y,noise,noise,Y,Y,,,,
SID-RESORT,OXI-OPERA,COMMENT_TYPE,EVENT  code should be in caps,Comment Type,Y,Y,fffffggggghhhhh,fffffggggghhhhh,Y,Y,,,,
SID-RESORT,OXI-OPERA,COMMENT_TYPE,FB_AGENDA General Notes,Comment Type,Y,Y,GEN,GEN,Y,Y,,,,
SID-RESORT,OXI-OPERA,COMMENT_TYPE,LEAD  Lead Notes,Comment Type,Y,Y,LEA,LEA,Y,Y,,,,
SID-RESORT,OXI-OPERA,COMMENT_TYPE,LEAD  Lead Reply Notes,Comment Type,Y,Y,LRP,LRP,Y,Y,,,,
SID-RESORT,OXI-OPERA,COMMENT_TYPE,POTENTIAL Confirmation,Comment Type,Y,Y,Confirmation,Confirmation,Y,Y,,,,
SID-RESORT,OXI-OPERA,COMMENT_TYPE,POTENTIAL General Notes,Comment Type,Y,Y,GEN,GEN,Y,Y,,,,
SID-RESORT,OXI-OPERA,COMMENT_TYPE,POTENTIAL Potential Notes,Comment Type,Y,Y,POT,POT,Y,Y,,,,
SID-RESORT,OXI-OPERA,COMMENT_TYPE,PROPERTY  A property Note,Comment Type,Y,Y,propNOte,propNOte,Y,Y,,,,
SID-RESORT,OXI-OPERA,COMMENT_TYPE,PROPERTY Direction to the Property,Comment Type,Y,Y,DIRECTION,DIRECTION,Y,Y,,,,
SID-RESORT,OXI-OPERA,COMMENT_TYPE,PROPERTY General Notes,Comment Type,Y,Y,GEN,GEN,Y,Y,,,,
SID-RESORT,OXI-OPERA,COMMENT_TYPE,PROPERTY Location of the Property,Comment Type,Y,Y,LOCATION,LOCATION,Y,Y,,,,
SID-RESORT,OXI-OPERA,COMMENT_TYPE,PROPERTY Passport Rules,Comment Type,Y,Y,PASSPORT,PASSPORT,Y,Y,,,,
SID-RESORT,OXI-OPERA,COMMENT_TYPE,PROPERTY Property Description,Comment Type,Y,Y,DESCRIPTION,DESCRIPTION,Y,Y,,,,
SID-RESORT,OXI-OPERA,COMMENT_TYPE,PROPERTY SARAH'S NOTE,Comment Type,Y,Y,SARAH,SARAH,Y,Y,,,,
SID-RESORT,OXI-OPERA,COMMENT_TYPE,PROPERTY  Visa Rules,Comment Type,Y,Y,VISA,VISA,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,ALOm,Country Code,Y,Y,ALO,ALO,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Afghanistan,Country Code,Y,Y,AF,AF,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Albania,Country Code,Y,Y,AL,AL,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Algeria,Country Code,Y,Y,DZ,DZ,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,American Samoa,Country Code,Y,Y,AS,AS,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Andorra,Country Code,Y,Y,AD,AD,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Angola,Country Code,Y,Y,AO,AO,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Anguilla/St Kitts,Country Code,Y,Y,AI,AI,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Antarctica,Country Code,Y,Y,AQ,AQ,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Antigua and Barbuda,Country Code,Y,Y,AG,AG,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Argentina,Country Code,Y,Y,AR,AR,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Armenia,Country Code,Y,Y,AM,AM,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Aruba,Country Code,Y,Y,AW,AW,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Australia,Country Code,Y,Y,AU,AU,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Austria,Country Code,Y,Y,AT,AT,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Azerbaijan,Country Code,Y,Y,AZ,AZ,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,BOR,Country Code,Y,Y,BOR,BOR,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Bahamas,Country Code,Y,Y,BS,BS,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Bahrain,Country Code,Y,Y,BH,BH,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Bangladesh,Country Code,Y,Y,BD,BD,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Barbados,Country Code,Y,Y,BB,BB,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Belarus,Country Code,Y,Y,BY,BY,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Belgium,Country Code,Y,Y,BE,BE,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Belize,Country Code,Y,Y,BZ,BZ,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Benin,Country Code,Y,Y,BJ,BJ,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Bermuda,Country Code,Y,Y,BM,BM,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Bhutan,Country Code,Y,Y,BT,BT,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Bolivia,Country Code,Y,Y,BO,BO,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Bora Batur,Country Code,Y,Y,BBB,BBB,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Bosnia Herzegovina,Country Code,Y,Y,BA,BA,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Botswana,Country Code,Y,Y,BW,BW,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Bouvet Island,Country Code,Y,Y,BV,BV,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Brazil,Country Code,Y,Y,BR,BR,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,British Indian Ocean Territory,Country Code,Y,Y,IO,IO,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Brunei Darussalam,Country Code,Y,Y,BN,BN,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Bulgaria,Country Code,Y,Y,BG,BG,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Burkina Fasa,Country Code,Y,Y,BF,BF,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Burundi,Country Code,Y,Y,BI,BI,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Cambodia,Country Code,Y,Y,KH,KH,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Cameroon,Country Code,Y,Y,CM,CM,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Canada,Country Code,Y,Y,CA,CA,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Cape Verde,Country Code,Y,Y,CV,CV,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Cayman Islands,Country Code,Y,Y,KY,KY,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Central African Republic,Country Code,Y,Y,CF,CF,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Chad,Country Code,Y,Y,TD,TD,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Chile,Country Code,Y,Y,CL,CL,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,China,Country Code,Y,Y,CN,CN,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Christmas Island,Country Code,Y,Y,CX,CX,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Cocos (Keeling) Islands,Country Code,Y,Y,CC,CC,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Colombia,Country Code,Y,Y,CO,CO,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Comoros,Country Code,Y,Y,KM,KM,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Congo  The Democratic Republic of the,Country Code,Y,Y,CD,CD,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Congo,Country Code,Y,Y,CG,CG,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Cook Island,Country Code,Y,Y,CK,CK,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Costa Rica,Country Code,Y,Y,CR,CR,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Cote D'Ivoire,Country Code,Y,Y,CI,CI,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Croatia,Country Code,Y,Y,HR,HR,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Cuba,Country Code,Y,Y,CU,CU,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Cyprus,Country Code,Y,Y,CY,CY,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Czech Republic,Country Code,Y,Y,CZ,CZ,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Denmark,Country Code,Y,Y,DK,DK,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Djibouti,Country Code,Y,Y,DJ,DJ,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Dominica,Country Code,Y,Y,DM,DM,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Dominican Republic,Country Code,Y,Y,DO,DO,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,East Timor,Country Code,Y,Y,TP,TP,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Ecuador,Country Code,Y,Y,EC,EC,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Egypt,Country Code,Y,Y,EG,EG,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,El Salvador,Country Code,Y,Y,SV,SV,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Equatorial Guinea,Country Code,Y,Y,GQ,GQ,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Eritrea,Country Code,Y,Y,ER,ER,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Estonia,Country Code,Y,Y,EE,EE,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Ethiopia,Country Code,Y,Y,ET,ET,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Falkland Islands,Country Code,Y,Y,FK,FK,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Faroe Islands,Country Code,Y,Y,FO,FO,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Fiji,Country Code,Y,Y,FJ,FJ,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Finland,Country Code,Y,Y,FI,FI,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,France,Country Code,Y,Y,FR,FR,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,France,Country Code,Y,Y,FX,FX,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,French Guiana,Country Code,Y,Y,GF,GF,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,French Polynesia,Country Code,Y,Y,PF,PF,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,French Souther Territories,Country Code,Y,Y,TF,TF,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,GAZOZ,Country Code,Y,Y,GAZ,GAZ,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Gabon,Country Code,Y,Y,GA,GA,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Gambia,Country Code,Y,Y,GM,GM,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Georgia,Country Code,Y,Y,GE,GE,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Germany,Country Code,Y,Y,DE,DE,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Ghana,Country Code,Y,Y,GH,GH,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Gibraltar,Country Code,Y,Y,GI,GI,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Great Britain,Country Code,Y,Y,GB,GB,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Greece,Country Code,Y,Y,GR,GR,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Greenland,Country Code,Y,Y,GL,GL,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Grenada,Country Code,Y,Y,GD,GD,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Guadeloupe/St Martin,Country Code,Y,Y,GP,GP,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Guam,Country Code,Y,Y,GU,GU,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Guatemala,Country Code,Y,Y,GT,GT,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Guinea Bissau,Country Code,Y,Y,GW,GW,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Guinea,Country Code,Y,Y,GN,GN,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Guyana,Country Code,Y,Y,GY,GY,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Haiti,Country Code,Y,Y,HT,HT,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Heard and McDonald Islands,Country Code,Y,Y,HM,HM,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Honduras,Country Code,Y,Y,HN,HN,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Hong Kong,Country Code,Y,Y,HK,HK,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Hungary,Country Code,Y,Y,HU,HU,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Iceland,Country Code,Y,Y,IS,IS,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,India,Country Code,Y,Y,IN,IN,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Indonesia,Country Code,Y,Y,ID,ID,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Iran,Country Code,Y,Y,IR,IR,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Iraq,Country Code,Y,Y,IQ,IQ,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Ireland,Country Code,Y,Y,IE,IE,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Isle Of Man,Country Code,Y,Y,IM,IM,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Israel,Country Code,Y,Y,IL,IL,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Italy,Country Code,Y,Y,IT,IT,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Jamaica,Country Code,Y,Y,JM,JM,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Japan,Country Code,Y,Y,JP,JP,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Jordan,Country Code,Y,Y,JO,JO,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,KAZOZ,Country Code,Y,Y,KAZ,KAZ,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Kazakhstan,Country Code,Y,Y,KZ,KZ,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Kenya,Country Code,Y,Y,KE,KE,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Kiribati,Country Code,Y,Y,KI,KI,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Korea  Republic Of,Country Code,Y,Y,KR,KR,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Korea Democratic People's Republic of,Country Code,Y,Y,KP,KP,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Kuwait,Country Code,Y,Y,KW,KW,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Kyrgzstan,Country Code,Y,Y,KG,KG,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Laos,Country Code,Y,Y,LA,LA,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Latvia,Country Code,Y,Y,LV,LV,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Lebanon,Country Code,Y,Y,LB,LB,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Lesotho,Country Code,Y,Y,LS,LS,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Liberia,Country Code,Y,Y,LR,LR,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Libyan Arab Jamahiriya,Country Code,Y,Y,LY,LY,Y,Y,,,,
SID-RESORT,OXI- OPERA,COUNTRY_CODE,Liechtenstein,Country Code,Y,Y,LI,LI,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Lithuania,Country Code,Y,Y,LT,LT,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Luxembourg,Country Code,Y,Y,LU,LU,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Macau,Country Code,Y,Y,MO,MO,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Macedonia,Country Code,Y,Y,MK,MK,Y,Y,,,,
SID-RESORT,OXI- OPERA,COUNTRY_CODE,Madagascar,Country Code,Y,Y,MG,MG,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Malawi,Country Code,Y,Y,MW,MW,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Malaysia,Country Code,Y,Y,MY,MY,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Maldives,Country Code,Y,Y,MV,MV,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Mali,Country Code,Y,Y,ML,ML,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Malta,Country Code,Y,Y,MT,MT,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Marshall Islands,Country Code,Y,Y,MH,MH,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Martinique,Country Code,Y,Y,MQ,MQ,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Mauritania,Country Code,Y,Y,MR,MR,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Mauritius,Country Code,Y,Y,MU,MU,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Mayotte,Country Code,Y,Y,YT,YT,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Mexico,Country Code,Y,Y,MX,MX,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Micronesia Federated States of,Country Code,Y,Y,FM,FM,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Midway Islands,Country Code,Y,Y,MI,MI,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Moldova,Country Code,Y,Y,MD,MD,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Monaco,Country Code,Y,Y,MC,MC,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Mongolia,Country Code,Y,Y,MN,MN,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Montserrat,Country Code,Y,Y,MS,MS,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Morocco,Country Code,Y,Y,MA,MA,Y,Y,,,,
SID-RESORT,OXI- OPERA,COUNTRY_CODE,Mozambique,Country Code,Y,Y,MZ,MZ,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Myanmar,Country Code,Y,Y,MM,MM,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Namibia,Country Code,Y,Y,NA,NA,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Nauru,Country Code,Y,Y,NR,NR,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Nepal,Country Code,Y,Y,NP,NP,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Netherlands Antilles,Country Code,Y,Y,AN,AN,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Netherlands,Country Code,Y,Y,NL,NL,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,New Caledonia,Country Code,Y,Y,NC,NC,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,New Zealand,Country Code,Y,Y,NZ,NZ,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Nicaragua,Country Code,Y,Y,NI,NI,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Niger,Country Code,Y,Y,NE,NE,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Nigeria,Country Code,Y,Y,NG,NG,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Niue,Country Code,Y,Y,NU,NU,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Norfolk Island,Country Code,Y,Y,NF,NF,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Northern Ireland,Country Code,Y,Y,NIE,NIE,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Northern Mariana Islands,Country Code,Y,Y,MP,MP,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Norway,Country Code,Y,Y,NO,NO,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Oman,Country Code,Y,Y,OM,OM,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Pakistan,Country Code,Y,Y,PK,PK,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Palau,Country Code,Y,Y,PW,PW,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Panama,Country Code,Y,Y,PA,PA,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Papua New Guinea,Country Code,Y,Y,PG,PG,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Paraguay,Country Code,Y,Y,PY,PY,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Peru,Country Code,Y,Y,PE,PE,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Philippines,Country Code,Y,Y,PH,PH,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Pitcairn,Country Code,Y,Y,PN,PN,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Poland,Country Code,Y,Y,PL,PL,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Portugal,Country Code,Y,Y,PT,PT,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Puerto Rico,Country Code,Y,Y,PR,PR,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Qatar,Country Code,Y,Y,QA,QA,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Question Mark,Country Code,Y,Y,?,?,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Reunion,Country Code,Y,Y,RE,RE,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Romania,Country Code,Y,Y,RO,RO,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Russia,Country Code,Y,Y,RU,RU,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Russian Federation,Country Code,Y,Y,RQ,RQ,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Rwanda,Country Code,Y,Y,RW,RW,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Saint Helena,Country Code,Y,Y,SH,SH,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Saint Kitts and Nevis,Country Code,Y,Y,KN,KN,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Saint Lucia,Country Code,Y,Y,LC,LC,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Saint Pierre And Miquelon,Country Code,Y,Y,PM,PM,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Saint Vincent And The Grenadines,Country Code,Y,Y,VC,VC,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Samoa,Country Code,Y,Y,WS,WS,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,San Marino,Country Code,Y,Y,SM,SM,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Sao Tome and Principe,Country Code,Y,Y,ST,ST,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Saudi Arabia,Country Code,Y,Y,SA,SA,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Senegal,Country Code,Y,Y,SN,SN,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Serbia and Montenegro,Country Code,Y,Y,CS,CS,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Seychelles,Country Code,Y,Y,SC,SC,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Sierra Leone,Country Code,Y,Y,SL,SL,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Singapore,Country Code,Y,Y,SG,SG,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Slovakia,Country Code,Y,Y,SK,SK,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Slovenia,Country Code,Y,Y,SI,SI,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Solomon Islands,Country Code,Y,Y,SB,SB,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Somalia,Country Code,Y,Y,SO,SO,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,South Africa,Country Code,Y,Y,ZA,ZA,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,South Georgia and the South Sandwich Islands,Country Code,Y,Y,GS,GS,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Spain,Country Code,Y,Y,ES,ES,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Sri Lanka,Country Code,Y,Y,LK,LK,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Sudan,Country Code,Y,Y,SD,SD,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Suriname,Country Code,Y,Y,SR,SR,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Svalbard and Jan Mayen Islands,Country Code,Y,Y,SJ,SJ,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Swaziland,Country Code,Y,Y,SZ,SZ,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Sweden,Country Code,Y,Y,SE,SE,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Sweden,Country Code,Y,Y,SW,SW,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Switzerland,Country Code,Y,Y,CH,CH,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Syria,Country Code,Y,Y,SY,SY,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Taiwan,Country Code,Y,Y,TW,TW,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Tajikistan,Country Code,Y,Y,TJ,TJ,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Tanzania,Country Code,Y,Y,TZ,TZ,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Thailand,Country Code,Y,Y,TH,TH,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Togo,Country Code,Y,Y,TG,TG,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Tokelau,Country Code,Y,Y,TK,TK,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Tonga,Country Code,Y,Y,TO,TO,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Trinidad And Tobago,Country Code,Y,Y,TT,TT,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Tunisia,Country Code,Y,Y,TN,TN,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Turkey,Country Code,Y,Y,TR,TR,Y,Y,,,,
SID-RESORT,OXI- OPERA,COUNTRY_CODE,Turkmenistan,Country Code,Y,Y,TM,TM,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Turks and Caicos Islands,Country Code,Y,Y,TC,TC,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Tuvalu,Country Code,Y,Y,TV,TV,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,USA,Country Code,Y,Y,USA,USA,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Uganda,Country Code,Y,Y,UG,UG,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Ukraine,Country Code,Y,Y,UA,UA,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,United Arab Emirates,Country Code,Y,Y,AE,AE,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,United States Minor Outlying Islands,Country Code,Y,Y,UM,UM,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,United States,Country Code,Y,Y,US,US,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Uruguay,Country Code,Y,Y,UY,UY,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Uzbekistan,Country Code,Y,Y,UZ,UZ,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Vanuatu,Country Code,Y,Y,VU,VU,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Vatican City State,Country Code,Y,Y,VA,VA,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Venezuela,Country Code,Y,Y,VE,VE,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Vietnam,Country Code,Y,Y,VN,VN,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Virgin Islands British,Country Code,Y,Y,VG,VG,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Virgin Islands US,Country Code,Y,Y,VI,VI,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Wallis and Futuna Islands,Country Code,Y,Y,WF,WF,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Western Sahara,Country Code,Y,Y,EH,EH,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,YAZ,Country Code,Y,Y,YAZ,YAZ,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Yemen,Country Code,Y,Y,YE,YE,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Yugoslavia,Country Code,Y,Y,YU,YU,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,ZEON,Country Code,Y,Y,ZEO,ZEO,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Zaire,Country Code,Y,Y,ZR,ZR,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Zambia,Country Code,Y,Y,ZM,ZM,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,Zimbabwe,Country Code,Y,Y,ZW,ZW,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,hrv,Country Code,Y,Y,HRV,HRV,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,max length test,Country Code,Y,Y,012,012,Y,Y,,,,
SID-RESORT,OXI-OPERA,COUNTRY_CODE,test country,Country Code,Y,Y,ZZZ,ZZZ,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,Akdeniz Currency Code,Currency Code,Y,Y,AKD,AKD,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,Albania Leke,Currency Code,Y,Y,ALL,ALL,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,Algeria Algeria Dinars,Currency Code,Y,Y,DZD,DZD,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,Another Mexican Currency,Currency Code,Y,Y,MEXC,MEXC,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,Argentinian Peso,Currency Code,Y,Y,ARS,ARS,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,Australian Dollar,Currency Code,Y,Y,AUD,AUD,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,Azerbaijan Manats,Currency Code,Y,Y,AZM,AZM,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,Bahrain Dinar,Currency Code,Y,Y,BHD,BHD,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,Belarus Rubles,Currency Code,Y,Y,BYR,BYR,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,Bosnia and Herzegovina Convertible arka,Currency Code,Y,Y,BAM,BAM,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,Botswana Pulas,Currency Code,Y,Y,BWP,BWP,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,Brunei Dollar,Currency Code,Y,Y,BND,BND,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,Bulgaria Leva,Currency Code,Y,Y,BGN,BGN,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,CATS,Currency Code,Y,Y,CAT,CAT,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,CNY,Currency Code,Y,Y,CNY,CNY,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,Canadian Dollar,Currency Code,Y,Y,CAD,CAD,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,Cayman Island Dollar,Currency Code,Y,Y,KYD,KYD,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,Chilean Pesos,Currency Code,Y,Y,CLP,CLP,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,Colombian Peso,Currency Code,Y,Y,COP,COP,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,Columbian Peso,Currency Code,Y,Y,COL,COL,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,Communaute Financi?re Africaine BCEAO Francs,Currency Code,Y,Y,XOF,XOF,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,Communaute Financi?re Africaine BEAC Francs,Currency Code,Y,Y,XAF,XAF,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,Congo/Kinshasa Congolese Francs,Currency Code,Y,Y,CDF,CDF,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,Convertible Cuban Peso,Currency Code,Y,Y,CUP,CUP,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,Croatia Kuna,Currency Code,Y,Y,HRK,HRK,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,Cyprus Pound,Currency Code,Y,Y,CYP,CYP,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,Czech Republic Koruny,Currency Code,Y,Y,CZK,CZK,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,DOG,Currency Code,Y,Y,DOG,DOG,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,Danish Krone,Currency Code,Y,Y,DKK,DKK,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,Djibouti Francs,Currency Code,Y,Y,DJF,DJF,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,Duetsch Mark,Currency Code,Y,Y,DEM,DEM,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,Egyptian Pound,Currency Code,Y,Y,EGP,EGP,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,Eritrea Nakfa,Currency Code,Y,Y,ERN,ERN,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,Estonia Krooni,Currency Code,Y,Y,EEK,EEK,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,Ethiopia Birr,Currency Code,Y,Y,ETB,ETB,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,Euro Currency Check,Currency Code,Y,Y,EUX,EUX,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,Euro Currency,Currency Code,Y,Y,EUR,EUR,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,Funny Money,Currency Code,Y,Y,LOL,LOL,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,Gambia Dalasi,Currency Code,Y,Y,GMD,GMD,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,Georgia Lari,Currency Code,Y,Y,GEL,GEL,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,Ghana Cedis,Currency Code,Y,Y,GHC,GHC,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,Gibraltar Pounds,Currency Code,Y,Y,GIP,GIP,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,Guatemala Quetzal,Currency Code,Y,Y,GTQ,GTQ,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,Guernsey Pounds,Currency Code,Y,Y,GGP,GGP,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,Guinea Francs,Currency Code,Y,Y,GNF,GNF,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,Guyana Dollars,Currency Code,Y,Y,GYD,GYD,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,Hong Kong Dollar,Currency Code,Y,Y,HK,HK,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,Hong Kong Dollar,Currency Code,Y,Y,HKD,HKD,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,Hungarian Forint,Currency Code,Y,Y,HUF,HUF,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,Iceland Kronur,Currency Code,Y,Y,ISK,ISK,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,Indian Rupees,Currency Code,Y,Y,INR,INR,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,Indonesian Rupiah,Currency Code,Y,Y,IDR,IDR,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,Iran Rials,Currency Code,Y,Y,IRR,IRR,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,Irish Punt,Currency Code,Y,Y,IRP,IRP,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,Isle of Man Pounds,Currency Code,Y,Y,IMP,IMP,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,Israel New Shekels,Currency Code,Y,Y,ILS,ILS,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,Japanese Yen,Currency Code,Y,Y,JPY,JPY,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,Jersey Pounds,Currency Code,Y,Y,JEP,JEP,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,Jordan Dinars,Currency Code,Y,Y,JOD,JOD,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,KEVIN,Currency Code,Y,Y,KEVIN,KEVIN,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,KIM,Currency Code,Y,Y,KIM,KIM,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,Kazakhstan Tenge,Currency Code,Y,Y,KZT,KZT,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,Kenya Shilling,Currency Code,Y,Y,KES,KES,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,Kuwait Dinar,Currency Code,Y,Y,KWD,KWD,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,Kyrgyzstan Soms,Currency Code,Y,Y,KGS,KGS,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,Latvia Lati,Currency Code,Y,Y,LVL,LVL,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,Lebanon Pounds,Currency Code,Y,Y,LBP,LBP,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,Liberia Dollars,Currency Code,Y,Y,LRD,LRD,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,Libya Dinars,Currency Code,Y,Y,LYD,LYD,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,Lithuania Litai,Currency Code,Y,Y,LTL,LTL,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,MEXICAN PESO,Currency Code,Y,Y,MEX,MEX,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,Macedonia Denars,Currency Code,Y,Y,MKD,MKD,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,Malawi Kwachas,Currency Code,Y,Y,MWK,MWK,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,Malaysian Ringgit,Currency Code,Y,Y,MYR,MYR,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,Malta Liri,Currency Code,Y,Y,MTL,MTL,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,Mauritius Rupees,Currency Code,Y,Y,MUR,MUR,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,Mexican Peso,Currency Code,Y,Y,MXN,MXN,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,Moldova Lei,Currency Code,Y,Y,MDL,MDL,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,Morocco Dirhams,Currency Code,Y,Y,MAD,MAD,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,Mozambique Meticais,Currency Code,Y,Y,MZM,MZM,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,Namibia Dollars,Currency Code,Y,Y,NAD,NAD,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,Nepal Nepal Rupees,Currency Code,Y,Y,NPR,NPR,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,New Zealand Dollar,Currency Code,Y,Y,NZD,NZD,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,Nigeria Nairas,Currency Code,Y,Y,NGN,NGN,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,Norwegian Krone,Currency Code,Y,Y,NOK,NOK,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,Oman Rial,Currency Code,Y,Y,OMR,OMR,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,Pakistan Rupees,Currency Code,Y,Y,PKR,PKR,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,Paraguay Guarani,Currency Code,Y,Y,PYG,PYG,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,Peruvian Nuevo Sol,Currency Code,Y,Y,PEN,PEN,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,Peruvian Nuevo Sol,Currency Code,Y,Y,PER,PER,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,Poland Zloty,Currency Code,Y,Y,PLN,PLN,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,Portuguese Escudo,Currency Code,Y,Y,PTE,PTE,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,Qatar Rials,Currency Code,Y,Y,QAR,QAR,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,Romania Lei,Currency Code,Y,Y,ROL,ROL,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,Rouble,Currency Code,Y,Y,RUR,RUR,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,Russia Rubles,Currency Code,Y,Y,RUB,RUB,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,Rwanda Rwanda Francs,Currency Code,Y,Y,RWF,RWF,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,Saudia Arabia Riyal,Currency Code,Y,Y,SAR,SAR,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,Serbia Dinars,Currency Code,Y,Y,CSD,CSD,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,Seychelles Rupees,Currency Code,Y,Y,SCR,SCR,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,Singapore Dollar,Currency Code,Y,Y,SGD,SGD,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,Slovakia Koruny,Currency Code,Y,Y,SKK,SKK,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,Slovenia Tolars,Currency Code,Y,Y,SIT,SIT,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,Somalia Shillings,Currency Code,Y,Y,SOS,SOS,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,South Africa Rand,Currency Code,Y,Y,ZAR,ZAR,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,Sudan Dinars,Currency Code,Y,Y,SDD,SDD,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,Swedish Krona,Currency Code,Y,Y,SEK,SEK,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,Swiss Franc,Currency Code,Y,Y,CHF,CHF,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,Syria Pounds,Currency Code,Y,Y,SYP,SYP,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,Taiwan Dollar,Currency Code,Y,Y,TWD,TWD,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,Tajikistan Somoni,Currency Code,Y,Y,TJS,TJS,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,Tanzania Shillings,Currency Code,Y,Y,TZS,TZS,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,Thailand Baht,Currency Code,Y,Y,THB,THB,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,Tunisia Dinars,Currency Code,Y,Y,TND,TND,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,Turkey Lira,Currency Code,Y,Y,TRL,TRL,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,Turkey Lira,Currency Code,Y,Y,YTL,YTL,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,Turkmenistan Manats,Currency Code,Y,Y,TMM,TMM,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,US Dollar,Currency Code,Y,Y,USD,USD,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,Uganda Shillings,Currency Code,Y,Y,UGX,UGX,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,Ukraine Hryvnia,Currency Code,Y,Y,UAH,UAH,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,United Arab Emirates Dirham,Currency Code,Y,Y,AED,AED,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,United Kingdom Pound,Currency Code,Y,Y,GBP,GBP,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,Uruguay Peso,Currency Code,Y,Y,UYU,UYU,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,Uzbekistan Sums,Currency Code,Y,Y,UZS,UZS,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,Yemen Rials,Currency Code,Y,Y,YER,YER,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,Zambia Kwacha,Currency Code,Y,Y,ZMK,ZMK,Y,Y,,,,
SID-RESORT,OXI-OPERA,CURRENCY_CODE,Zimbabwe Zimbabwe Dollars,Currency Code,Y,Y,ZWD,ZWD,Y,Y,,,,
SID-RESORT,OXI- OPERA,DISCOUNT_REASON,012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678,Discount Reason,Y,Y,0123456789,0123456789,Y,Y,,,,
SID-RESORT,OXI-OPERA,DISCOUNT_REASON,35 test,Discount Reason,Y,Y,35,35,Y,Y,,,,
SID-RESORT,OXI-OPERA,DISCOUNT_REASON,Adhoc/Special Ratre,Discount Reason,Y,Y,ADH,ADH,Y,Y,,,,
SID-RESORT,OXI-OPERA,DISCOUNT_REASON,Asst Manager on Duty,Discount Reason,Y,Y,ADM,ADM,Y,Y,,,,
SID-RESORT,OXI-OPERA,DISCOUNT_REASON,Asst. Manager on Duty,Discount Reason,Y,Y,AMD,AMD,Y,Y,,,,
SID-RESORT,OXI- OPERA,DISCOUNT_REASON,Coupon,Discount Reason,Y,Y,CPN,CPN,Y,Y,,,,
SID-RESORT,OXI-OPERA,DISCOUNT_REASON,Did not meet Guest Expectations,Discount Reason,Y,Y,GST,GST,Y,Y,,,,
SID-RESORT,OXI-OPERA,DISCOUNT_REASON,Discount Voucher Presented,Discount Reason,Y,Y,DISC,DISC,Y,Y,,,,
SID-RESORT,OXI-OPERA,DISCOUNT_REASON,Employee Discount,Discount Reason,Y,Y,EMP,EMP,Y,Y,,,,
SID-RESORT,OXI-OPERA,DISCOUNT_REASON,Extended due to complaint,Discount Reason,Y,Y,CPL,CPL,Y,Y,,,,
SID-RESORT,OXI-OPERA,DISCOUNT_REASON,Family Plan,Discount Reason,Y,Y,FAM,FAM,Y,Y,,,,
SID-RESORT,OXI-OPERA,DISCOUNT_REASON,Front Office Manager,Discount Reason,Y,Y,FOM,FOM,Y,Y,,,,
SID-RESORT,OXI-OPERA,DISCOUNT_REASON,Golden Circle Benfit,Discount Reason,Y,Y,GC,GC,Y,Y,,,,
SID-RESORT,OXI-OPERA,DISCOUNT_REASON,Guest Dissastified with Service,Discount Reason,Y,Y,GSV,GSV,Y,Y,,,,
SID-RESORT,OXI-OPERA,DISCOUNT_REASON,Guest Dissatisfied with Hotel,Discount Reason,Y,Y,GDS,GDS,Y,Y,,,,
SID-RESORT,OXI-OPERA,DISCOUNT_REASON,Half Twin Rate,Discount Reason,Y,Y,HTC,HTC,Y,Y,,,,
SID-RESORT,OXI-OPERA,DISCOUNT_REASON,Honor Old Rate,Discount Reason,Y,Y,OLD,OLD,Y,Y,,,,
SID-RESORT,OXI-OPERA,DISCOUNT_REASON,Long discount code V3 test 1,Discount Reason,Y,Y,LONGDISCOUSEEIFTHEFORMCANHANDLETHIS,LONGDISCOUSEEIFTHEFORMCANHANDLETHIS,Y,Y,,,,
SID-RESORT,OXI-OPERA,DISCOUNT_REASON,Manager's Discretion,Discount Reason,Y,Y,MGR,MGR,Y,Y,,,,
SID-RESORT,OXI-OPERA,DISCOUNT_REASON,Per GM,Discount Reason,Y,Y,PGM,PGM,Y,Y,,,,
SID-RESORT,OXI-OPERA,DISCOUNT_REASON,Rate incl ABF,Discount Reason,Y,Y,RIB,RIB,Y,Y,,,,
SID-RESORT,OXI-OPERA,DISCOUNT_REASON,Reservation Office Discount 2,Discount Reason,Y,Y,RESR,RESR,Y,Y,,,,
SID-RESORT,OXI-OPERA,DISCOUNT_REASON,Reservation Office Discount,Discount Reason,Y,Y,RES,RES,Y,Y,,,,
SID-RESORT,OXI-OPERA,DISCOUNT_REASON,Sales Department,Discount Reason,Y,Y,SLS,SLS,Y,Y,,,,
SID-RESORT,OXI-OPERA,DISCOUNT_REASON,Sharer,Discount Reason,Y,Y,SSR,SSR,Y,Y,,,,
SID-RESORT,OXI-OPERA,DISCOUNT_REASON,Spouce single rate,Discount Reason,Y,Y,GCS,GCS,Y,Y,,,,
SID-RESORT,OXI- OPERA,DISCOUNT_REASON,modifier/Supplement,Discount Reason,Y,Y,MOD,MOD,Y,Y,,,,
SID-RESORT,OXI- OPERA,GENDER_MF,Female,Gender,Y,Y,F,F,Y,N,,,,
SID-RESORT,OXI- OPERA,GENDER_MF,Male,Gender,Y,Y,M,M,Y,N,,,,
SID-RESORT,OXI- OPERA,GENDER_MF,Unknown,Gender,Y,Y,U,U,Y,N,,,,
SID-RESORT,OXI-OPERA,LANGUAGE_CODES,Akdeniz Language,Language Code,Y,Y,AL,AL,Y,Y,,,,
SID-RESORT,OXI- OPERA,LANGUAGE_CODES,Arabic,Language Code,Y,Y,AR,AR,Y,Y,,,,
SID-RESORT,OXI- OPERA,LANGUAGE_CODES,Bulgarian,Language Code,Y,Y,BG,BG,Y,Y,,,,
SID-RESORT,OXI-OPERA,LANGUAGE_CODES,Chili,Language Code,Y,Y,HABANERO,HABANERO,Y,Y,,,,
SID-RESORT,OXI-OPERA,LANGUAGE_CODES,Chinese Traditional,Language Code,Y,Y,ZH-T,ZH-T,Y,Y,,,,
SID-RESORT,OXI- OPERA,LANGUAGE_CODES,Chinese,Language Code,Y,Y,C,C,Y,Y,,,,
SID-RESORT,OXI- OPERA,LANGUAGE_CODES,Chinese,Language Code,Y,Y,CH,CH,Y,Y,,,,
SID-RESORT,OXI- OPERA,LANGUAGE_CODES,Chinese,Language Code,Y,Y,ZH,ZH,Y,Y,,,,
SID-RESORT,OXI- OPERA,LANGUAGE_CODES,Croatian,Language Code,Y,Y,HR,HR,Y,Y,,,,
SID-RESORT,OXI- OPERA,LANGUAGE_CODES,Czechoslovakian,Language Code,Y,Y,CS,CS,Y,Y,,,,
SID-RESORT,OXI- OPERA,LANGUAGE_CODES,Danish,Language Code,Y,Y,DA,DA,Y,Y,,,,
SID-RESORT,OXI- OPERA,LANGUAGE_CODES,Danish,Language Code,Y,Y,DN,DN,Y,Y,,,,
SID-RESORT,OXI- OPERA,LANGUAGE_CODES,English,Language Code,Y,Y,E,E,Y,Y,,,,
SID-RESORT,OXI- OPERA,LANGUAGE_CODES,Finnish,Language Code,Y,Y,FI,FI,Y,Y,,,,
SID-RESORT,OXI- OPERA,LANGUAGE_CODES,French,Language Code,Y,Y,F,F,Y,Y,,,,
SID-RESORT,OXI- OPERA,LANGUAGE_CODES,French,Language Code,Y,Y,FR,FR,Y,Y,,,,
SID-RESORT,OXI- OPERA,LANGUAGE_CODES,German,Language Code,Y,Y,DE,DE,Y,Y,,,,
SID-RESORT,OXI- OPERA,LANGUAGE_CODES,German,Language Code,Y,Y,G,G,Y,Y,,,,
SID-RESORT,OXI-OPERA,LANGUAGE_CODES,Greek,Language Code,Y,Y,EL,EL,Y,Y,,,,
SID-RESORT,OXI-OPERA,LANGUAGE_CODES,Greek,Language Code,Y,Y,GRK,GRK,Y,Y,,,,
SID-RESORT,OXI- OPERA,LANGUAGE_CODES,Hungarian,Language Code,Y,Y,HU,HU,Y,Y,,,,
SID-RESORT,OXI-OPERA,LANGUAGE_CODES,Italian,Language Code,Y,Y,IT,IT,Y,Y,,,,
SID-RESORT,OXI- OPERA,LANGUAGE_CODES,Japanese,Language Code,Y,Y,J,J,Y,Y,,,,
SID-RESORT,OXI- OPERA,LANGUAGE_CODES,Japanese,Language Code,Y,Y,JA,JA,Y,Y,,,,
SID-RESORT,OXI- OPERA,LANGUAGE_CODES,Japanese,Language Code,Y,Y,JPN,JPN,Y,Y,,,,
SID-RESORT,OXI- OPERA,LANGUAGE_CODES,Korean,Language Code,Y,Y,K,K,Y,Y,,,,
SID-RESORT,OXI- OPERA,LANGUAGE_CODES,Korean,Language Code,Y,Y,KO,KO,Y,Y,,,,
SID-RESORT,OXI- OPERA,LANGUAGE_CODES,Korean,Language Code,Y,Y,NLS,NLS,Y,Y,,,,
SID-RESORT,OXI- OPERA,LANGUAGE_CODES,Macedonian,Language Code,Y,Y,MK,MK,Y,Y,,,,
SID-RESORT,OXI-OPERA,LANGUAGE_CODES,Mandarian Chinese,Language Code,Y,Y,MD,MD,Y,Y,,,,
SID-RESORT,OXI-OPERA,LANGUAGE_CODES,Netherland Dutch,Language Code,Y,Y,NL,NL,Y,Y,,,,
SID-RESORT,OXI- OPERA,LANGUAGE_CODES,Norwegian,Language Code,Y,Y,NO,NO,Y,Y,,,,
SID-RESORT,OXI- OPERA,LANGUAGE_CODES,Persian,Language Code,Y,Y,FA,FA,Y,Y,,,,
SID-RESORT,OXI-OPERA,LANGUAGE_CODES,Polish,Language Code,Y,Y,PL,PL,Y,Y,,,,
SID-RESORT,OXI- OPERA,LANGUAGE_CODES,Portugese,Language Code,Y,Y,PT,PT,Y,Y,,,,
SID-RESORT,OXI- OPERA,LANGUAGE_CODES,Russian,Language Code,Y,Y,RU,RU,Y,Y,,,,
SID-RESORT,OXI- OPERA,LANGUAGE_CODES,Spanish,Language Code,Y,Y,ES,ES,Y,Y,,,,
SID-RESORT,OXI- OPERA,LANGUAGE_CODES,Spanish,Language Code,Y,Y,ESP,ESP,Y,Y,,,,
SID-RESORT,OXI- OPERA,LANGUAGE_CODES,Spanish,Language Code,Y,Y,S,S,Y,Y,,,,
SID-RESORT,OXI- OPERA,LANGUAGE_CODES,Swedish,Language Code,Y,Y,SV,SV,Y,Y,,,,
SID-RESORT,OXI- OPERA,LANGUAGE_CODES,Thaiwainese,Language Code,Y,Y,TH,TH,Y,Y,,,,
SID-RESORT,OXI- OPERA,LANGUAGE_CODES,Turkish,Language Code,Y,Y,TR,TR,Y,Y,,,,
SID-RESORT,OXI- OPERA,MEMBERSHIP_LEVEL,04,Membership Level,Y,Y,04,04,Y,Y,,,,
SID-RESORT,OXI- OPERA,MEMBERSHIP_LEVEL,Bronz,Membership Level,Y,Y,BRZ,BRZ,Y,Y,,,,
SID-RESORT,OXI- OPERA,MEMBERSHIP_LEVEL,Classic,Membership Level,Y,Y,CLASSIC,CLASSIC,Y,Y,,,,
SID-RESORT,OXI- OPERA,MEMBERSHIP_LEVEL,Elite,Membership Level,Y,Y,ELITE,ELITE,Y,Y,,,,
SID-RESORT,OXI-OPERA,MEMBERSHIP_LEVEL,Entry level,Membership Level,Y,Y,SILVER,SILVER,Y,Y,,,,
SID-RESORT,OXI- OPERA,MEMBERSHIP_LEVEL,Executive,Membership Level,Y,Y,EXECUTIVE,EXECUTIVE,Y,Y,,,,
SID-RESORT,OXI- OPERA,MEMBERSHIP_LEVEL,Gold,Membership Level,Y,Y,1,1,Y,Y,,,,
SID-RESORT,OXI- OPERA,MEMBERSHIP_LEVEL,Gold,Membership Level,Y,Y,GLD,GLD,Y,Y,,,,
SID-RESORT,OXI- OPERA,MEMBERSHIP_LEVEL,Gold,Membership Level,Y,Y,GOLD,GOLD,Y,Y,,,,
SID-RESORT,OXI-OPERA,MEMBERSHIP_LEVEL,Kempinski Privat Concierge Card,Membership Level,Y,Y,KP,KP,Y,Y,,,,
SID-RESORT,OXI-OPERA,MEMBERSHIP_LEVEL,Lufthansa Frequent Traveler,Membership Level,Y,Y,LT,LT,Y,Y,,,,
SID-RESORT,OXI-OPERA,MEMBERSHIP_LEVEL,Lufthansa Miles & More,Membership Level,Y,Y,MM,MM,Y,Y,,,,
SID-RESORT,OXI-OPERA,MEMBERSHIP_LEVEL,Lufthansa Senator Card,Membership Level,Y,Y,LH,LH,Y,Y,,,,
SID-RESORT,OXI- OPERA,MEMBERSHIP_LEVEL,Platinum,Membership Level,Y,Y,PLATINUM,PLATINUM,Y,Y,,,,
SID-RESORT,OXI- OPERA,MEMBERSHIP_LEVEL,Platinum,Membership Level,Y,Y,PLT,PLT,Y,Y,,,,
SID-RESORT,OXI- OPERA,MEMBERSHIP_LEVEL,Silver,Membership Level,Y,Y,SLV,SLV,Y,Y,,,,
SID-RESORT,OXI- OPERA,MEMBERSHIP_LEVEL,Temporary,Membership Level,Y,Y,TEMPORARY,TEMPORARY,Y,Y,,,,
SID-RESORT,OXI-OPERA,MEMBERSHIP_LEVEL,a,Membership Level,Y,Y,A,A,Y,Y,,,,
SID-RESORT,OXI-OPERA,MEMBERSHIP_LEVEL,b,Membership Level,Y,Y,B,B,Y,Y,,,,
SID-RESORT,OXI-OPERA,MEMBERSHIP_LEVEL,level 1,Membership Level,Y,Y,01,01,Y,Y,,,,
SID-RESORT,OXI-OPERA,MEMBERSHIP_TYPE,123 Membership,Membership Type,Y,Y,123,123,Y,Y,,,,
SID-RESORT,OXI- OPERA,MEMBERSHIP_TYPE,AKDENIZ,Membership Type,Y,Y,AKDENIZ,AKDENIZ,Y,Y,,,,
SID-RESORT,OXI-OPERA,MEMBERSHIP_TYPE,Air Canadian,Membership Type,Y,Y,AC,AC,Y,Y,,,,
SID-RESORT,OXI-OPERA,MEMBERSHIP_TYPE,Air China,Membership Type,Y,Y,ACH,ACH,Y,Y,,,,
SID-RESORT,OXI-OPERA,MEMBERSHIP_TYPE,Air France,Membership Type,Y,Y,ARF,ARF,Y,Y,,,,
SID-RESORT,OXI-OPERA,MEMBERSHIP_TYPE,Air Miles,Membership Type,Y,Y,AI,AI,Y,Y,,,,
SID-RESORT,OXI- OPERA,MEMBERSHIP_TYPE,Airmiles,Membership Type,Y,Y,AIM,AIM,Y,Y,,,,
SID-RESORT,OXI-OPERA,MEMBERSHIP_TYPE,Alaska Airlines,Membership Type,Y,Y,AS,AS,Y,Y,,,,
SID-RESORT,OXI- OPERA,MEMBERSHIP_TYPE,Alitalia,Membership Type,Y,Y,AZ,AZ,Y,Y,,,,
SID-RESORT,OXI- OPERA,MEMBERSHIP_TYPE,Alitalia,Membership Type,Y,Y,AZL,AZL,Y,Y,,,,
SID-RESORT,OXI-OPERA,MEMBERSHIP_TYPE,Allow Duplicate,Membership Type,Y,Y,ALLOW,ALLOW,Y,Y,,,,
SID-RESORT,OXI- OPERA,MEMBERSHIP_TYPE,Ambassador,Membership Type,Y,Y,AMB,AMB,Y,Y,,,,
SID-RESORT,OXI-OPERA,MEMBERSHIP_TYPE,American Airlines,Membership Type,Y,Y,AA,AA,Y,Y,,,,
SID-RESORT,OXI- OPERA,MEMBERSHIP_TYPE,Another,Membership Type,Y,Y,ANOTHER,ANOTHER,Y,Y,,,,
SID-RESORT,OXI- OPERA,MEMBERSHIP_TYPE,Aviateca,Membership Type,Y,Y,AVI,AV,Y,Y,,,,
SID-RESORT,OXI-OPERA,MEMBERSHIP_TYPE,BORA MEMBERSHIP,Membership Type,Y,Y,BOMEM,BOMEM,Y,Y,,,,
SID-RESORT,OXI-OPERA,MEMBERSHIP_TYPE,Booker Program,Membership Type,Y,Y,BOOK,BOOK,Y,Y,,,,
SID-RESORT,OXI-OPERA,MEMBERSHIP_TYPE,British Airways,Membership Type,Y,Y,BA,BA,Y,Y,,,,
SID-RESORT,OXI-OPERA,MEMBERSHIP_TYPE,Cathay Pac,Membership Type,Y,Y,CXA,CXA,Y,Y,,,,
SID-RESORT,OXI-OPERA,MEMBERSHIP_TYPE,Cathy Pacific Airlines,Membership Type,Y,Y,CX,CX,Y,Y,,,,
SID-RESORT,OXI-OPERA,MEMBERSHIP_TYPE,Central Managed,Membership Type,Y,Y,CENTRAL,CENTRAL,Y,Y,,,,
SID-RESORT,OXI-OPERA,MEMBERSHIP_TYPE,China Airlines,Membership Type,Y,Y,CA,CA,Y,Y,,,,
SID-RESORT,OXI-OPERA,MEMBERSHIP_TYPE,China Airlines,Membership Type,Y,Y,CI,CI,Y,Y,,,,
SID-RESORT,OXI-OPERA,MEMBERSHIP_TYPE,China Southern Airlines,Membership Type,Y,Y,CZA,CZA,Y,Y,,,,
SID-RESORT,OXI-OPERA,MEMBERSHIP_TYPE,Continental Airlines,Membership Type,Y,Y,CO,CO,Y,Y,,,,
SID-RESORT,OXI-OPERA,MEMBERSHIP_TYPE,Delta Air Lines,Membership Type,Y,Y,DL,DL,Y,Y,,,,
SID-RESORT,OXI-OPERA,MEMBERSHIP_TYPE,Delta Skymiles,Membership Type,Y,Y,DELTA,DELTA,Y,Y,,,,
SID-RESORT,OXI-OPERA,MEMBERSHIP_TYPE,EVA Airlines,Membership Type,Y,Y,EVA,EVA,Y,Y,,,,
SID-RESORT,OXI-OPERA,MEMBERSHIP_TYPE,Eager Beaver,Membership Type,Y,Y,EB,EB,Y,Y,,,,
SID-RESORT,OXI-OPERA,MEMBERSHIP_TYPE,Emirates Airline,Membership Type,Y,Y,EK,EK,Y,Y,,,,
SID-RESORT,OXI- OPERA,MEMBERSHIP_TYPE,FinnAir,Membership Type,Y,Y,AYA,AYA,Y,Y,,,,
SID-RESORT,OXI-OPERA,MEMBERSHIP_TYPE,Flyer program,Membership Type,Y,Y,WEEEE,WEEEE,Y,Y,,,,
SID-RESORT,OXI-OPERA,MEMBERSHIP_TYPE,Frequence Plus,Membership Type,Y,Y,AF,AF,Y,Y,,,,
SID-RESORT,OXI-OPERA,MEMBERSHIP_TYPE,G3,Membership Type,Y,Y,G3,G3,Y,Y,,,,
SID-RESORT,OXI- OPERA,MEMBERSHIP_TYPE,GCA,Membership Type,Y,Y,GCA,GCA,Y,Y,,,,
SID-RESORT,OXI- OPERA,MEMBERSHIP_TYPE,GCB,Membership Type,Y,Y,GCB,GCB,Y,Y,,,,
SID-RESORT,OXI-OPERA,MEMBERSHIP_TYPE,Golden Circle!,Membership Type,Y,Y,GC,GC,Y,Y,,,,
SID-RESORT,OXI-OPERA,MEMBERSHIP_TYPE,Gulf Airlines,Membership Type,Y,Y,GFA,GFA,Y,Y,,,,
SID-RESORT,OXI-OPERA,MEMBERSHIP_TYPE,Hermosa Beach Rewards,Membership Type,Y,Y,HBR,HBR,Y,Y,,,,
SID-RESORT,OXI-OPERA,MEMBERSHIP_TYPE,Hilton Loyalty Program,Membership Type,Y,Y,HHONORS,HHONORS,Y,Y,,,,
SID-RESORT,OXI-OPERA,MEMBERSHIP_TYPE,Hinan Airlines,Membership Type,Y,Y,HUA,HUA,Y,Y,,,,
SID-RESORT,OXI-OPERA,MEMBERSHIP_TYPE,Hyatt International's Gold Passport,Membership Type,Y,Y,GP,GP,Y,Y,,,,
SID-RESORT,OXI-OPERA,MEMBERSHIP_TYPE,IHG Loyalty Program,Membership Type,Y,Y,HIRO,HIRO,Y,Y,,,,
SID-RESORT,OXI- OPERA,MEMBERSHIP_TYPE,Iberia,Membership Type,Y,Y,IBA,IBA,Y,Y,,,,
SID-RESORT,OXI-OPERA,MEMBERSHIP_TYPE,Japan Airlines,Membership Type,Y,Y,JAL,JAL,Y,Y,,,,
SID-RESORT,OXI-OPERA,MEMBERSHIP_TYPE,KLM Airlines,Membership Type,Y,Y,KL,KL,Y,Y,,,,
SID-RESORT,OXI- OPERA,MEMBERSHIP_TYPE,KLM,Membership Type,Y,Y,KLM,KLM,Y,Y,,,,
SID-RESORT,OXI-OPERA,MEMBERSHIP_TYPE,Kempinski Private Concierge,Membership Type,Y,Y,KPC,KPC,Y,Y,,,,
SID-RESORT,OXI-OPERA,MEMBERSHIP_TYPE,Korean Airlines,Membership Type,Y,Y,KE,KE,Y,Y,,,,
SID-RESORT,OXI-OPERA,MEMBERSHIP_TYPE,Lufthansa Cards,Membership Type,Y,Y,LH,LH,Y,Y,,,,
SID-RESORT,OXI-OPERA,MEMBERSHIP_TYPE,MRK frequent flyer,Membership Type,Y,Y,MRK1,MRK1,Y,Y,,,,
SID-RESORT,OXI-OPERA,MEMBERSHIP_TYPE,Marlin Kaeding Frequent Flyer Program,Membership Type,Y,Y,MRK,MRK,Y,Y,,,,
SID-RESORT,OXI-OPERA,MEMBERSHIP_TYPE,Marriott Loyalty,Membership Type,Y,Y,MQ,MQ,Y,Y,,,,
SID-RESORT,OXI-OPERA,MEMBERSHIP_TYPE,Marriott Rewards,Membership Type,Y,Y,MR,MR,Y,Y,,,,
SID-RESORT,OXI-OPERA,MEMBERSHIP_TYPE,New membership pgm,Membership Type,Y,Y,NMRK,NMRK,Y,Y,,,,
SID-RESORT,OXI-OPERA,MEMBERSHIP_TYPE,Nippon Airlines,Membership Type,Y,Y,NH,NH,Y,Y,,,,
SID-RESORT,OXI-OPERA,MEMBERSHIP_TYPE,Northwest Airlines,Membership Type,Y,Y,NW,NW,Y,Y,,,,
SID-RESORT,OXI-OPERA,MEMBERSHIP_TYPE,OCIS IN PMS,Membership Type,Y,Y,OCIS,OCIS,Y,Y,,,,
SID-RESORT,OXI-OPERA,MEMBERSHIP_TYPE,ORS Primary for Separa,Membership Type,Y,Y,OP,OP,Y,Y,,,,
SID-RESORT,OXI-OPERA,MEMBERSHIP_TYPE,PC Points,Membership Type,Y,Y,HPC,HPC,Y,Y,,,,
SID-RESORT,OXI- OPERA,MEMBERSHIP_TYPE,PTS,Membership Type,Y,Y,PTS,PTS,Y,Y,,,,
SID-RESORT,OXI-OPERA,MEMBERSHIP_TYPE,Priority Club,Membership Type,Y,Y,PC,PC,Y,Y,,,,
SID-RESORT,OXI- OPERA,MEMBERSHIP_TYPE,Qantas,Membership Type,Y,Y,QA,QA,Y,Y,,,,
SID-RESORT,OXI- OPERA,MEMBERSHIP_TYPE,Qualiflyer,Membership Type,Y,Y,QG,QG,Y,Y,,,,
SID-RESORT,OXI-OPERA,MEMBERSHIP_TYPE,Rac,Membership Type,Y,Y,RAC,RAC,Y,Y,,,,
SID-RESORT,OXI-OPERA,MEMBERSHIP_TYPE,Ritz Carlton Membership,Membership Type,Y,Y,RZ,RZ,Y,Y,,,,
SID-RESORT,OXI-OPERA,MEMBERSHIP_TYPE,SN Brussels,Membership Type,Y,Y,SN,SN,Y,Y,,,,
SID-RESORT,OXI- OPERA,MEMBERSHIP_TYPE,SPA,Membership Type,Y,Y,SPA,SPA,Y,Y,,,,
SID-RESORT,OXI- OPERA,MEMBERSHIP_TYPE,SPG,Membership Type,Y,Y,SPG,SPG,Y,Y,,,,
SID-RESORT,OXI-OPERA,MEMBERSHIP_TYPE,South West Airlines,Membership Type,Y,Y,WN,WN,Y,Y,,,,
SID-RESORT,OXI-OPERA,MEMBERSHIP_TYPE,Stag's Membership,Membership Type,Y,Y,SAC,SAC,Y,Y,,,,
SID-RESORT,OXI-OPERA,MEMBERSHIP_TYPE,Swiss Travel Club,Membership Type,Y,Y,LX,LX,Y,Y,,,,
SID-RESORT,OXI-OPERA,MEMBERSHIP_TYPE,TAP Air Portugal,Membership Type,Y,Y,TP,TP,Y,Y,,,,
SID-RESORT,OXI-OPERA,MEMBERSHIP_TYPE,TESCO Frequent Flyer Miles,Membership Type,Y,Y,TX,TX,Y,Y,,,,
SID-RESORT,OXI-OPERA,MEMBERSHIP_TYPE,US Air,Membership Type,Y,Y,US,US,Y,Y,,,,
SID-RESORT,OXI- OPERA,MEMBERSHIP_TYPE,Varig,Membership Type,Y,Y,RG,RG,Y,Y,,,,
SID-RESORT,OXI- OPERA,MEMBERSHIP_TYPE,WYNN,Membership Type,Y,Y,WYNN,WYNN,Y,Y,,,,
SID-RESORT,OXI-OPERA,MEMBERSHIP_TYPE,a car rental loyalty program,Membership Type,Y,Y,CAR,CAR,Y,Y,,,,
SID-RESORT,OXI- OPERA,MEMBERSHIP_TYPE,agfdg,Membership Type,Y,Y,DFGSAD,DFGSAD,Y,Y,,,,
SID-RESORT,OXI- OPERA,MEMBERSHIP_TYPE,dawnsmembership,Membership Type,Y,Y,DAWN,DAWN,Y,Y,,,,
SID-RESORT,OXI-OPERA,MEMBERSHIP_TYPE,deenas SCR,Membership Type,Y,Y,DEENA,DEENA,Y,Y,,,,
SID-RESORT,OXI- OPERA,MEMBERSHIP_TYPE,elisa,Membership Type,Y,Y,ELISATYPE,ELISATYPE,Y,Y,,,,
SID-RESORT,OXI-OPERA,MEMBERSHIP_TYPE,mi,Membership Type,Y,Y,MI,MI,Y,Y,,,,
SID-RESORT,OXI- OPERA,MEMBERSHIP_TYPE,quantas,Membership Type,Y,Y,QF,QF,Y,Y,,,,
SID-RESORT,OXI-OPERA,MEMBERSHIP_TYPE,w,Membership Type,Y,Y,W,W,Y,Y,,,,
SID-RESORT,OXI-OPERA,NATIONALITY,Akdeniz Nationality,Nationality Code,Y,Y,AN,AN,Y,Y,,,,
SID-RESORT,OXI-OPERA,NATIONALITY,American,Nationality Code,Y,Y,A,A,Y,Y,,,,
SID-RESORT,OXI-OPERA,NATIONALITY,American,Nationality Code,Y,Y,AM,A,Y,Y,,,,
SID-RESORT,OXI-OPERA,NATIONALITY,Argentinian,Nationality Code,Y,Y,AR,AR,Y,Y,,,,
SID-RESORT,OXI-OPERA,NATIONALITY,Australian,Nationality Code,Y,Y,AU,AU,Y,Y,,,,
SID-RESORT,OXI-OPERA,NATIONALITY,Belgium,Nationality Code,Y,Y,BE,BE,Y,Y,,,,
SID-RESORT,OXI-OPERA,NATIONALITY,CUBA,Nationality Code,Y,Y,CUB,CUB,Y,Y,,,,
SID-RESORT,OXI-OPERA,NATIONALITY,Canadian,Nationality Code,Y,Y,CA,CA,Y,Y,,,,
SID-RESORT,OXI-OPERA,NATIONALITY,Chilean,Nationality Code,Y,Y,CL,CL,Y,Y,,,,
SID-RESORT,OXI-OPERA,NATIONALITY,China,Nationality Code,Y,Y,CH,C,Y,Y,,,,
SID-RESORT,OXI-OPERA,NATIONALITY,China,Nationality Code,Y,Y,CN,CN,Y,Y,,,,
SID-RESORT,OXI-OPERA,NATIONALITY,Croatia,Nationality Code,Y,Y,HR,HR,Y,Y,,,,
SID-RESORT,OXI-OPERA,NATIONALITY,Denmark,Nationality Code,Y,Y,DA,DA,Y,Y,,,,
SID-RESORT,OXI-OPERA,NATIONALITY,Domestic Croatia vs Foreign Croatia which is HR,Nationality Code,Y,Y,HRV,HRV,Y,Y,,,,
SID-RESORT,OXI-OPERA,NATIONALITY,Dutch,Nationality Code,Y,Y,NL,NL,Y,Y,,,,
SID-RESORT,OXI-OPERA,NATIONALITY,Egyptian,Nationality Code,Y,Y,EY,EY,Y,Y,,,,
SID-RESORT,OXI-OPERA,NATIONALITY,French,Nationality Code,Y,Y,F,F,Y,Y,,,,
SID-RESORT,OXI-OPERA,NATIONALITY,German,Nationality Code,Y,Y,DE,G,Y,Y,,,,
SID-RESORT,OXI-OPERA,NATIONALITY,Great Britain,Nationality Code,Y,Y,GB,E,Y,Y,,,,
SID-RESORT,OXI-OPERA,NATIONALITY,Greek,Nationality Code,Y,Y,GR,GR,Y,Y,,,,
SID-RESORT,OXI-OPERA,NATIONALITY,India,Nationality Code,Y,Y,IN,IN,Y,Y,,,,
SID-RESORT,OXI-OPERA,NATIONALITY,Italian,Nationality Code,Y,Y,IT,IT,Y,Y,,,,
SID-RESORT,OXI-OPERA,NATIONALITY,J NATIONALITY,Nationality Code,Y,Y,J,J,Y,Y,,,,
SID-RESORT,OXI-OPERA,NATIONALITY,Japanese,Nationality Code,Y,Y,JA,JA,Y,Y,,,,
SID-RESORT,OXI-OPERA,NATIONALITY,Japanese,Nationality Code,Y,Y,JAP,JAP,Y,Y,,,,
SID-RESORT,OXI-OPERA,NATIONALITY,Macedonian,Nationality Code,Y,Y,MK,MK,Y,Y,,,,
SID-RESORT,OXI-OPERA,NATIONALITY,New Zealand,Nationality Code,Y,Y,NZ,NZ,Y,Y,,,,
SID-RESORT,OXI-OPERA,NATIONALITY,North African,Nationality Code,Y,Y,NA,NA,Y,Y,,,,
SID-RESORT,OXI-OPERA,NATIONALITY,Northern Ireland,Nationality Code,Y,Y,NI,NI,Y,Y,,,,
SID-RESORT,OXI-OPERA,NATIONALITY,PUERTO RICO,Nationality Code,Y,Y,PR,PR,Y,Y,,,,
SID-RESORT,OXI-OPERA,NATIONALITY,Philippines,Nationality Code,Y,Y,PH,PH,Y,Y,,,,
SID-RESORT,OXI-OPERA,NATIONALITY,Polish,Nationality Code,Y,Y,PL,PL,Y,Y,,,,
SID-RESORT,OXI-OPERA,NATIONALITY,Polynesian,Nationality Code,Y,Y,PO,PO,Y,Y,,,,
SID-RESORT,OXI-OPERA,NATIONALITY,Republic of Ireland,Nationality Code,Y,Y,SI,SI,Y,Y,,,,
SID-RESORT,OXI-OPERA,NATIONALITY,Russia,Nationality Code,Y,Y,RU,RU,Y,Y,,,,
SID-RESORT,OXI-OPERA,NATIONALITY,South African,Nationality Code,Y,Y,SA,SA,Y,Y,,,,
SID-RESORT,OXI-OPERA,NATIONALITY,Spanish,Nationality Code,Y,Y,S,S,Y,Y,,,,
SID-RESORT,OXI-OPERA,NATIONALITY,Susie,Nationality Code,Y,Y,HG,HG,Y,Y,,,,
SID-RESORT,OXI-OPERA,NATIONALITY,Swedish,Nationality Code,Y,Y,SW,SW,Y,Y,,,,
SID-RESORT,OXI-OPERA,NATIONALITY,Turkish,Nationality Code,Y,Y,T,T,Y,Y,,,,
SID-RESORT,OXI-OPERA,NATIONALITY,Turkish,Nationality Code,Y,Y,TR,TR,Y,Y,,,,
SID-RESORT,OXI-OPERA,NATIONALITY,long,Nationality Code,Y,Y,LONGNATIONALITYIJYIU,LONGNATIONALITYIJYIU,Y,Y,,,,
SID-RESORT,OXI-OPERA,PHONE_TYPE,AKDENIZ,Phone Type,Y,Y,AKDENIZ,AKDENIZ,Y,Y,,,,
SID-RESORT,OXI-OPERA,PHONE_TYPE,Alternate Email,Phone Type,Y,Y,ALT_EMAIL,ALT_EMAIL,Y,Y,,,,
SID-RESORT,OXI-OPERA,PHONE_TYPE,Alternate Fax Number,Phone Type,Y,Y,ALT_FAX,ALT_FAX,Y,Y,,,,
SID-RESORT,OXI-OPERA,PHONE_TYPE,BUSINESSFAX,Phone Type,Y,Y,BUSINESSFAX,FAX1,Y,Y,,,,
SID-RESORT,OXI-OPERA,PHONE_TYPE,Business Phone Number,Phone Type,Y,Y,BUSINESS,BUSINESS,Y,Y,,,,
SID-RESORT,OXI-OPERA,PHONE_TYPE,Corporate Website,Phone Type,Y,Y,CORPWEB,CORPWEB,Y,Y,,,,
SID-RESORT,OXI-OPERA,PHONE_TYPE,Direct Business Phone Number,Phone Type,Y,Y,DBUSINESS,DBUSINESS,Y,Y,,,,
SID-RESORT,OXI-OPERA,PHONE_TYPE,Do nOt use,Phone Type,Y,Y,PEMAIL,PEMAIL,Y,Y,,,,
SID-RESORT,OXI-OPERA,PHONE_TYPE,EMAIL BUSINESS,Phone Type,Y,Y,EMAIL BUSINESS,EMAIL BUSINESS,Y,Y,,,,
SID-RESORT,OXI-OPERA,PHONE_TYPE,EMAIL OTHER,Phone Type,Y,Y,EMAIL OTHER,EMAIL OTHER,Y,Y,,,,
SID-RESORT,OXI-OPERA,PHONE_TYPE,Email Address,Phone Type,Y,Y,EMAIL,EMAIL,Y,Y,,,,
SID-RESORT,OXI-OPERA,PHONE_TYPE,Email for Request,Phone Type,Y,Y,REQUEST,REQUEST,Y,Y,,,,
SID-RESORT,OXI-OPERA,PHONE_TYPE,Fax Number,Phone Type,Y,Y,FAX,FAX,Y,Y,,,,
SID-RESORT,OXI-OPERA,PHONE_TYPE,Home Phone Number,Phone Type,Y,Y,HOME,HOME,Y,Y,,,,
SID-RESORT,OXI-OPERA,PHONE_TYPE,Mobile Fax,Phone Type,Y,Y,FAXTEST,FAXTEST,Y,Y,,,,
SID-RESORT,OXI-OPERA,PHONE_TYPE,Mobile Phone Number,Phone Type,Y,Y,MOBILE,MOBILE,Y,Y,,,,
SID-RESORT,OXI-OPERA,PHONE_TYPE,NEWSLETTER SUBSCRIPTION,Phone Type,Y,Y,REQUEST EMAIL,REQUEST EMAIL,Y,Y,,,,
SID-RESORT,OXI-OPERA,PHONE_TYPE,ORDER BY TEST,Phone Type,Y,Y,AAAAA,AAAAA,Y,Y,,,,
SID-RESORT,OXI-OPERA,PHONE_TYPE,ORDER BY TEST,Phone Type,Y,Y,PIPPO,PIPPO,Y,Y,,,,
SID-RESORT,OXI-OPERA,PHONE_TYPE,Pager number,Phone Type,Y,Y,PAGER,PAGER,Y,Y,,,,
SID-RESORT,OXI-OPERA,PHONE_TYPE,Pesonal Email,Phone Type,Y,Y,PERSONAL EMAIL,PERSONAL EMAIL,Y,Y,,,,
SID-RESORT,OXI-OPERA,PHONE_TYPE,TELEX,Phone Type,Y,Y,TELEX,FAX,Y,N,,,,
SID-RESORT,OXI-OPERA,PHONE_TYPE,Test Type,Phone Type,Y,Y,TELEX,XXX,Y,N,,,,
SID-RESORT,OXI-OPERA,PHONE_TYPE,Web Page,Phone Type,Y,Y,WEB,WEB,Y,Y,,,,
SID-RESORT,OXI-OPERA,PHONE_TYPE,fax,Phone Type,Y,Y,FAX2,FAX2,Y,Y,,,,
SID-RESORT,OXI-OPERA,PHONE_TYPE,personla home email,Phone Type,Y,Y,EMAIL HOME,PERSONNAL EMAIL,Y,Y,,,,
SID-RESORT,OXI-OPERA,PROFILE_TYPE,Company,Profile Type,Y,Y,COMPANY,CORPORATE,Y,Y,,,,
SID-RESORT,OXI-OPERA,PROFILE_TYPE,Contact,Profile Type,Y,Y,CONTACT,CONTACT,Y,Y,,,,
SID-RESORT,OXI-OPERA,PROFILE_TYPE,Group,Profile Type,Y,Y,G,GROUP,Y,Y,,,,
SID-RESORT,OXI-OPERA,PROFILE_TYPE,Individual,Profile Type,Y,Y,D,GUEST,Y,Y,,,,
SID-RESORT,OXI-OPERA,PROFILE_TYPE,Source,Profile Type,Y,Y,S,WHOLESALER,Y,Y,,,,
SID-RESORT,OXI-OPERA,PROFILE_TYPE,Travel Agent,Profile Type,Y,Y,TRAVEL_AGENT,TRAVEL,Y,Y,,,,
SID-RESORT,OXI-OPERA,RELATIONSHIP,(source) Client of,Profile Relationships,Y,Y,S-CLIENT OF,S-CLIENT OF,Y,Y,,,,
SID-RESORT,OXI-OPERA,RELATIONSHIP,,Profile Relationships,Y,Y,,,Y,Y,,,,
SID-RESORT,OXI-OPERA,RELATIONSHIP,,Profile Relationships,Y,Y,AGENT,AGENT,Y,Y,,,,
SID-RESORT,OXI-OPERA,RELATIONSHIP,,Profile Relationships,Y,Y,BROTHER,BROTHER,Y,Y,,,,
SID-RESORT,OXI-OPERA,RELATIONSHIP,,Profile Relationships,Y,Y,DI,DI,Y,Y,,,,
SID-RESORT,OXI-OPERA,RELATIONSHIP,,Profile Relationships,Y,Y,ELISA D,ELISA D,Y,Y,,,,
SID-RESORT,OXI-OPERA,RELATIONSHIP,,Profile Relationships,Y,Y,MICROS S,MICROS S,Y,Y,,,,
SID-RESORT,OXI-OPERA,RELATIONSHIP,,Profile Relationships,Y,Y,SI,SI,Y,Y,,,,
SID-RESORT,OXI-OPERA,RELATIONSHIP,,Profile Relationships,Y,Y,SPONSOR,SPONSOR,Y,Y,,,,
SID-RESORT,OXI-OPERA,RELATIONSHIP,ACTIVITY,Profile Relationships,Y,Y,ACTIVITY,ACTIVITY,Y,Y,,,,
SID-RESORT,OXI-OPERA,RELATIONSHIP,AKDENIZ,Profile Relationships,Y,Y,AKDENIZ,AKDENIZ,Y,Y,,,,
SID-RESORT,OXI-OPERA,RELATIONSHIP,AKDENIZ1,Profile Relationships,Y,Y,AKDENIZ1,AKDENIZ1,Y,Y,,,,
SID-RESORT,OXI-OPERA,RELATIONSHIP,Agent Master,Profile Relationships,Y,Y,T-MASTER,T-MASTER,Y,Y,,,,
SID-RESORT,OXI-OPERA,RELATIONSHIP,Agent Subsidiary,Profile Relationships,Y,Y,T-SUB,T-SUB,Y,Y,,,,
SID-RESORT,OXI-OPERA,RELATIONSHIP,Agent YYY,Profile Relationships,Y,Y,AGENTYYY,AGENTYYY,Y,Y,,,,
SID-RESORT,OXI-OPERA,RELATIONSHIP,Associated from,Profile Relationships,Y,Y,ASSOCIATEDF,ASSOCIATEDF,Y,Y,,,,
SID-RESORT,OXI-OPERA,RELATIONSHIP,Associated to,Profile Relationships,Y,Y,ASSOCIATEDT,ASSOCIATEDT,Y,Y,,,,
SID-RESORT,OXI-OPERA,RELATIONSHIP,BB,Profile Relationships,Y,Y,BB,BB,Y,Y,,,,
SID-RESORT,OXI- OPERA,RELATIONSHIP,BUSINESS_HEADER,Profile Relationships,Y,Y,BUSINESS_HEADER,BUSINESS_HEADER,Y,Y,,,,
SID-RESORT,OXI-OPERA,RELATIONSHIP,Billing,Profile Relationships,Y,Y,BILLING TO,BILLING TO,Y,Y,,,,
SID-RESORT,OXI-OPERA,RELATIONSHIP,Billing,Profile Relationships,Y,Y,BILLING,BILLING,Y,Y,,,,
SID-RESORT,OXI-OPERA,RELATIONSHIP,Booker Too,Profile Relationships,Y,Y,BOOKERTOO,BOOKERTOO,Y,Y,,,,
SID-RESORT,OXI-OPERA,RELATIONSHIP,Booker,Profile Relationships,Y,Y,BOOKER,BOOKER,Y,Y,,,,
SID-RESORT,OXI-OPERA,RELATIONSHIP,Booker,Profile Relationships,Y,Y,BOOKERTO,BOOKERTO,Y,Y,,,,
SID-RESORT,OXI-OPERA,RELATIONSHIP,Booking,Profile Relationships,Y,Y,BOOKING,BOOKING,Y,Y,,,,
SID-RESORT,OXI-OPERA,RELATIONSHIP,Branch or subsidiary,Profile Relationships,Y,Y,SUBSIDIARY,SUBSIDIARY,Y,Y,,,,
SID-RESORT,OXI-OPERA,RELATIONSHIP,COMPANY,Profile Relationships,Y,Y,COMPANY,COMPANY,Y,Y,,,,
SID-RESORT,OXI-OPERA,RELATIONSHIP,COMPANY,Profile Relationships,Y,Y,OWNER,OWNER,Y,Y,,,,
SID-RESORT,OXI-OPERA,RELATIONSHIP,COMPANY2,Profile Relationships,Y,Y,COMPANY2,COMPANY2,Y,Y,,,,
SID-RESORT,OXI-OPERA,RELATIONSHIP,Chap Mem of,Profile Relationships,Y,Y,CHAP MEM,CHAP MEM,Y,Y,,,,
SID-RESORT,OXI-OPERA,RELATIONSHIP,Clan Member,Profile Relationships,Y,Y,FAMILY MEMBER,FAMILY MEMBER,Y,Y,,,,
SID-RESORT,OXI-OPERA,RELATIONSHIP,Clan,Profile Relationships,Y,Y,CLAN,CLAN,Y,Y,,,,
SID-RESORT,OXI-OPERA,RELATIONSHIP,Client Vendor of,Profile Relationships,Y,Y,VENDOR OF,VENDOR OF,Y,Y,,,,
SID-RESORT,OXI-OPERA,RELATIONSHIP,Client of,Profile Relationships,Y,Y,CLIENT OF,CLIENT OF,Y,Y,,,,
SID-RESORT,OXI-OPERA,RELATIONSHIP,Client of,Profile Relationships,Y,Y,CLIENT,CLIENT,Y,Y,,,,
SID-RESORT,OXI-OPERA,RELATIONSHIP,Company Master,Profile Relationships,Y,Y,C-MASTER,C-MASTER,Y,Y,,,,
SID-RESORT,OXI-OPERA,RELATIONSHIP,Company Subsid,Profile Relationships,Y,Y,C-SUB,C-SUB,Y,Y,,,,
SID-RESORT,OXI-OPERA,RELATIONSHIP,Company XXX,Profile Relationships,Y,Y,COMPANYXXX,COMPANYXXX,Y,Y,,,,
SID-RESORT,OXI-OPERA,RELATIONSHIP,Company of Booker1,Profile Relationships,Y,Y,COMPANY OF BOOKER,COMPANY OF BOOKER,Y,Y,,,,
SID-RESORT,OXI-OPERA,RELATIONSHIP,Company,Profile Relationships,Y,Y,ACCOUNT,ACCOUNT,Y,Y,,,,
SID-RESORT,OXI-OPERA,RELATIONSHIP,Company,Profile Relationships,Y,Y,COMPANY,COMPANY,Y,Y,,,,
SID-RESORT,OXI-OPERA,RELATIONSHIP,Company,Profile Relationships,Y,Y,COMPANY1,COMPANY1,Y,Y,,,,
SID-RESORT,OXI-OPERA,RELATIONSHIP,Contact,Profile Relationships,Y,Y,D,D,Y,Y,,,,
SID-RESORT,OXI-OPERA,RELATIONSHIP,Corp Contrib to,Profile Relationships,Y,Y,CORP CONTRIBUTOR,CORP CONTRIBUTOR,Y,Y,,,,
SID-RESORT,OXI-OPERA,RELATIONSHIP,Corporate Member,Profile Relationships,Y,Y,CORPORATE MEMBER,CORPORATE MEMBER,Y,Y,,,,
SID-RESORT,OXI-OPERA,RELATIONSHIP,EMPLOYEE,Profile Relationships,Y,Y,EMPLOYEE,EMPLOYEE,Y,Y,,,,
SID-RESORT,OXI-OPERA,RELATIONSHIP,EMPLOYER,Profile Relationships,Y,Y,EMPLOYER,EMPLOYER,Y,Y,,,,
SID-RESORT,OXI-OPERA,RELATIONSHIP,Employee of,Profile Relationships,Y,Y,EMPLOYEE OF,EMPLOYEE OF,Y,Y,,,,
SID-RESORT,OXI-OPERA,RELATIONSHIP,Employee,Profile Relationships,Y,Y,CONTACT,CONTACT,Y,Y,,,,
SID-RESORT,OXI-OPERA,RELATIONSHIP,Employee,Profile Relationships,Y,Y,FROM EMPLOYEE,FROM EMPLOYEE,Y,Y,,,,
SID-RESORT,OXI-OPERA,RELATIONSHIP,Employer,Profile Relationships,Y,Y,ACCOUNT,ACCOUNT,Y,Y,,,,
SID-RESORT,OXI-OPERA,RELATIONSHIP,FAMILY,Profile Relationships,Y,Y,FAMILY,FAMILY,Y,Y,,,,
SID-RESORT,OXI-OPERA,RELATIONSHIP,From Company,Profile Relationships,Y,Y,FROMCOMPANY,FROMCOMPANY,Y,Y,,,,
SID-RESORT,OXI-OPERA,RELATIONSHIP,General Manager,Profile Relationships,Y,Y,MARLIN,MARLIN,Y,Y,,,,
SID-RESORT,OXI-OPERA,RELATIONSHIP,Group,Profile Relationships,Y,Y,GROUP,GROUP,Y,Y,,,,
SID-RESORT,OXI-OPERA,RELATIONSHIP,HARIKA,Profile Relationships,Y,Y,HARIKA,HARIKA,Y,Y,,,,
SID-RESORT,OXI-OPERA,RELATIONSHIP,Home Office,Profile Relationships,Y,Y,HOME OFFICE,HOME OFFICE,Y,Y,,,,
SID-RESORT,OXI-OPERA,RELATIONSHIP,Implant for,Profile Relationships,Y,Y,IMPLANT,IMPLANT,Y,Y,,,,
SID-RESORT,OXI-OPERA,RELATIONSHIP,Indiv Contrib to,Profile Relationships,Y,Y,INDIV CONTRIBUTOR,INDIV CONTRIBUTOR,Y,Y,,,,
SID-RESORT,OXI-OPERA,RELATIONSHIP,Individual Member of Natl Assoc,Profile Relationships,Y,Y,MEMBER OF NATL ASSOC,MEMBER OF NATL ASSOC,Y,Y,,,,
SID-RESORT,OXI-OPERA,RELATIONSHIP,Individual,Profile Relationships,Y,Y,CONTACT,CONTACT,Y,Y,,,,
SID-RESORT,OXI-OPERA,RELATIONSHIP,Individual,Profile Relationships,Y,Y,INDIVIDUAL,INDIVIDUAL,Y,Y,,,,
SID-RESORT,OXI-OPERA,RELATIONSHIP,Individual,Profile Relationships,Y,Y,TO INDIVIDUAL,TO INDIVIDUAL,Y,Y,,,,
SID-RESORT,OXI-OPERA,RELATIONSHIP,Master,Profile Relationships,Y,Y,MASTER,MASTER,Y,Y,,,,
SID-RESORT,OXI-OPERA,RELATIONSHIP,NASILSIN,Profile Relationships,Y,Y,NASILSIN,NASILSIN,Y,Y,,,,
SID-RESORT,OXI-OPERA,RELATIONSHIP,Nat Org for,Profile Relationships,Y,Y,NATL ORG,NATL ORG,Y,Y,,,,
SID-RESORT,OXI-OPERA,RELATIONSHIP,National Association,Profile Relationships,Y,Y,NATIONAL ASSOCIATION,NATIONAL ASSOCIATION,Y,Y,,,,
SID-RESORT,OXI-OPERA,RELATIONSHIP,Natl Charity of,Profile Relationships,Y,Y,NATIONAL CHARITY,NATIONAL CHARITY,Y,Y,,,,
SID-RESORT,OXI-OPERA,RELATIONSHIP,Owner's Hotel,Profile Relationships,Y,Y,MRK HOTEL,MRK HOTEL,Y,Y,,,,
SID-RESORT,OXI-OPERA,RELATIONSHIP,Parent company,Profile Relationships,Y,Y,PARENT COMPANY,PARENT COMPANY,Y,Y,,,,
SID-RESORT,OXI-OPERA,RELATIONSHIP,SOURCE,Profile Relationships,Y,Y,SOURCE,SOURCE,Y,Y,,,,
SID-RESORT,OXI-OPERA,RELATIONSHIP,SOURCE,Profile Relationships,Y,Y,SUPPLIER,SUPPLIER,Y,Y,,,,
SID-RESORT,OXI-OPERA,RELATIONSHIP,Satellite Office,Profile Relationships,Y,Y,SATELLITE OFFICE,SATELLITE OFFICE,Y,Y,,,,
SID-RESORT,OXI-OPERA,RELATIONSHIP,Sibling,Profile Relationships,Y,Y,SIBLING,SIBLING,Y,Y,,,,
SID-RESORT,OXI-OPERA,RELATIONSHIP,Source Employer of,Profile Relationships,Y,Y,S-MASTER,S-MASTER,Y,Y,,,,
SID-RESORT,OXI-OPERA,RELATIONSHIP,Source Subsidiary,Profile Relationships,Y,Y,S-SUB,S-SUB,Y,Y,,,,
SID-RESORT,OXI-OPERA,RELATIONSHIP,Spouse,Profile Relationships,Y,Y,SPOUSE,SPOUSE,Y,Y,,,,
SID-RESORT,OXI-OPERA,RELATIONSHIP,Spouse,Profile Relationships,Y,Y,SPOUSE1,SPOUSE1,Y,Y,,,,
SID-RESORT,OXI-OPERA,RELATIONSHIP,Stef From,Profile Relationships,Y,Y,STEFFROM,STEFFROM,Y,Y,,,,
SID-RESORT,OXI-OPERA,RELATIONSHIP,Stef To,Profile Relationships,Y,Y,STEFTO,STEFTO,Y,Y,,,,
SID-RESORT,OXI-OPERA,RELATIONSHIP,Sub,Profile Relationships,Y,Y,SUB,SUB,Y,Y,,,,
SID-RESORT,OXI-OPERA,RELATIONSHIP,TA of Booker,Profile Relationships,Y,Y,TA OF BOOKER,TA OF BOOKER,Y,Y,,,,
SID-RESORT,OXI-OPERA,RELATIONSHIP,Team Leader,Profile Relationships,Y,Y,OWNER,OWNER,Y,Y,,,,
SID-RESORT,OXI-OPERA,RELATIONSHIP,To Booking,Profile Relationships,Y,Y,TOBOOKING,TOBOOKING,Y,Y,,,,
SID-RESORT,OXI-OPERA,RELATIONSHIP,Travel Agent Of,Profile Relationships,Y,Y,TRAVEL AGENT OF,TRAVEL AGENT OF,Y,Y,,,,
SID-RESORT,OXI-OPERA,RELATIONSHIP,Travel Agent of,Profile Relationships,Y,Y,TRAVEL AGENT OF,TRAVEL AGENT OF,Y,Y,,,,
SID-RESORT,OXI-OPERA,RELATIONSHIP,Travel Agent,Profile Relationships,Y,Y,TRAVEL AGENT,TRAVEL AGENT,Y,Y,,,,
SID-RESORT,OXI-OPERA,RELATIONSHIP,Travel Wholesaler,Profile Relationships,Y,Y,TRAVEL WHOLESALER,TRAVEL WHOLESALER,Y,Y,,,,
SID-RESORT,OXI- OPERA,RELATIONSHIP,TravelAgentToTest,Profile Relationships,Y,Y,TRAVEL AGENT TO TEST,TRAVEL AGENT TO TEST,Y,Y,,,,
SID-RESORT,OXI-OPERA,RELATIONSHIP,Vendor of,Profile Relationships,Y,Y,VENDOR OF,VENDOR OF,Y,Y,,,,
SID-RESORT,OXI- OPERA,RELATIONSHIP,VendorFromTest,Profile Relationships,Y,Y,VENDOR FROM TEST,VENDOR FROM TEST,Y,Y,,,,
SID-RESORT,OXI-OPERA,RELATIONSHIP,XXXX--Child Company of,Profile Relationships,Y,Y,C-COMP,C-COMP,Y,Y,,,,
SID-RESORT,OXI-OPERA,RELATIONSHIP,cc,Profile Relationships,Y,Y,CC,CC,Y,Y,,,,
SID-RESORT,OXI-OPERA,RELATIONSHIP,emp,Profile Relationships,Y,Y,EMP,EMP,Y,Y,,,,
SID-RESORT,OXI-OPERA,RELATIONSHIP,employer,Profile Relationships,Y,Y,C,C,Y,Y,,,,
SID-RESORT,OXI-OPERA,RELATIONSHIP,from.source.test,Profile Relationships,Y,Y,FROM SOURCE,FROM SOURCE,Y,Y,,,,
SID-RESORT,OXI- OPERA,RELATIONSHIP,fromCompanyTest,Profile Relationships,Y,Y,FROM COMPANY TEST,FROM COMPANY TEST,Y,Y,,,,
SID-RESORT,OXI-OPERA,RELATIONSHIP,individual,Profile Relationships,Y,Y,IND,IND,Y,Y,,,,
SID-RESORT,OXI-OPERA,RELATIONSHIP,individual,Profile Relationships,Y,Y,INDI,INDI,Y,Y,,,,
SID-RESORT,OXI-OPERA,RELATIONSHIP,parent node,Profile Relationships,Y,Y,ITSELF,ITSELF,Y,Y,,,,
SID-RESORT,OXI-OPERA,RELATIONSHIP,parent nodes,Profile Relationships,Y,Y,PARENT,PARENT,Y,Y,,,,
SID-RESORT,OXI-OPERA,RELATIONSHIP,sales rep descrip,Profile Relationships,Y,Y,SALES REP PERSON,SALES REP PERSON,Y,Y,,,,
SID-RESORT,OXI-OPERA,RELATIONSHIP,sales rep man descrip,Profile Relationships,Y,Y,SALES REP MANAGER,SALES REP MANAGER,Y,Y,,,,
SID-RESORT,OXI-OPERA,RELATIONSHIP,sibling,Profile Relationships,Y,Y,SIBLING1,SIBLING1,Y,Y,,,,
SID-RESORT,OXI-OPERA,RELATIONSHIP,ta,Profile Relationships,Y,Y,TA,TA,Y,Y,,,,
SID-RESORT,OXI-OPERA,RELATIONSHIP,to.source.test,Profile Relationships,Y,Y,TO SOURCE,TO SOURCE,Y,Y,,,,
SID-RESORT,OXI-OPERA,RELATIONSHIP,toVendorTest,Profile Relationships,Y,Y,TO VENDOR TEST,TO VENDOR TEST,Y,Y,,,,
SID-RESORT,OXI- OPERA,RESERVATION_STATUS,Cancelled,Reservation Status,Y,Y,CANCELLED,CANCELED,Y,Y,,,,
SID-RESORT,OXI-OPERA,RESERVATION_STATUS,Checked In,Reservation Status,Y,Y,CHECKED IN,CHECKED IN,Y,Y,,,,
SID-RESORT,OXI-OPERA,RESERVATION_STATUS,Checked Out,Reservation Status,Y,Y,CHECKED OUT,CHECKED OUT,Y,Y,,,,
SID-RESORT,OXI-OPERA,RESERVATION_STATUS,No Show,Reservation Status,Y,Y,NO SHOW,NO SHOW,Y,Y,,,,
SID-RESORT,OXI- OPERA,RESERVATION_STATUS,Prospect,Reservation Status,Y,Y,PROSPECT,REQUESTED,Y,Y,,,,
SID-RESORT,OXI- OPERA,RESERVATION_STATUS,Reserved,Reservation Status,Y,Y,RESERVED,RESERVED,Y,Y,,,,
SID-RESORT,OXI- OPERA,RESERVATION_STATUS,Waitlist,Reservation Status,Y,Y,WAITLIST,WAITLIST,Y,Y,,,,
SID-RESORT,OXI-OPERA,REVENUE_TYPE,Banquet,Revenue Type,Y,Y,007,007,Y,Y,,,,
SID-RESORT,OXI-OPERA,REVENUE_TYPE,Beverage outlets,Revenue Type,Y,Y,006,006,Y,Y,,,,
SID-RESORT,OXI-OPERA,REVENUE_TYPE,Business Centre,Revenue Type,Y,Y,015,015,Y,Y,,,,
SID-RESORT,OXI-OPERA,REVENUE_TYPE,Cash Payments,Revenue Type,Y,Y,018,018,Y,Y,,,,
SID-RESORT,OXI-OPERA,REVENUE_TYPE,Credit Card Payments,Revenue Type,Y,Y,019,019,Y,Y,,,,
SID-RESORT,OXI-OPERA,REVENUE_TYPE,Dry Cleaning / Laundry,Revenue Type,Y,Y,008,008,Y,Y,,,,
SID-RESORT,OXI-OPERA,REVENUE_TYPE,Food Outlet: Breakfast,Revenue Type,Y,Y,003,003,Y,Y,,,,
SID-RESORT,OXI-OPERA,REVENUE_TYPE,Food Outlet: Fine Dining,Revenue Type,Y,Y,004,OTHER,Y,Y,,,,
SID-RESORT,OXI-OPERA,REVENUE_TYPE,Food Outlet: Lunch & Dinner (Non fine Dining),Revenue Type,Y,Y,005,005,Y,Y,,,,
SID-RESORT,OXI-OPERA,REVENUE_TYPE,Food Tax,Revenue Type,Y,Y,8000,8000,Y,Y,,,,
SID-RESORT,OXI-OPERA,REVENUE_TYPE,Long Distance,Revenue Type,Y,Y,4010,4010,Y,Y,,,,
SID-RESORT,OXI-OPERA,REVENUE_TYPE,Minibar,Revenue Type,Y,Y,012,012,Y,Y,,,,
SID-RESORT,OXI-OPERA,REVENUE_TYPE,Other Payments,Revenue Type,Y,Y,020,020,Y,Y,,,,
SID-RESORT,OXI-OPERA,REVENUE_TYPE,Others / Miscellaneous,Revenue Type,Y,Y,010,010,Y,Y,,,,
SID-RESORT,OXI-OPERA,REVENUE_TYPE,Paid Outs,Revenue Type,Y,Y,009,009,Y,Y,,,,
SID-RESORT,OXI-OPERA,REVENUE_TYPE,Parking / Garage,Revenue Type,Y,Y,014,014,Y,Y,,,,
SID-RESORT,OXI-OPERA,REVENUE_TYPE,Pay TV,Revenue Type,Y,Y,016,016,Y,Y,,,,
SID-RESORT,OXI-OPERA,REVENUE_TYPE,Room Revenue,Revenue Type,Y,Y,001,ROOM,Y,Y,,,,
SID-RESORT,OXI-OPERA,REVENUE_TYPE,Room Service,Revenue Type,Y,Y,011,011,Y,Y,,,,
SID-RESORT,OXI-OPERA,REVENUE_TYPE,Room Tax,Revenue Type,Y,Y,8300,8300,Y,Y,,,,
SID-RESORT,OXI-OPERA,REVENUE_TYPE,Sales Tax,Revenue Type,Y,Y,8210,8210,Y,Y,,,,
SID-RESORT,OXI-OPERA,REVENUE_TYPE,Service Charge,Revenue Type,Y,Y,082,082,Y,Y,,,,
SID-RESORT,OXI-OPERA,REVENUE_TYPE,Spa / Wellness / Recreation,Revenue Type,Y,Y,013,013,Y,Y,,,,
SID-RESORT,OXI-OPERA,REVENUE_TYPE,Special Tracking,Revenue Type,Y,Y,017,017,Y,Y,,,,
SID-RESORT,OXI-OPERA,REVENUE_TYPE,Tax,Revenue Type,Y,Y,081,081,Y,Y,,,,
SID-RESORT,OXI- OPERA,REVENUE_TYPE,Telecommunication,Revenue Type,Y,Y,002,FOOD,Y,Y,,,,
SID-RESORT,OXI-OPERA,REVENUE_TYPE,Undefined Miscellaneous Revenue,Revenue Type,Y,Y,080,080,Y,Y,,,,
SID-RESORT,OXI-OPERA,TITLE,AKDENIZ TITLE,Title,Y,Y,AKDT,AKDT,Y,Y,,,,
SID-RESORT,OXI-OPERA,TITLE,Bay,Title,Y,Y,Bay,Bay,Y,Y,,,,
SID-RESORT,OXI-OPERA,TITLE,Captain <FIRSTNAME> <LASTNAME>,Title,Y,Y,Capt,Capt,Y,Y,,,,
SID-RESORT,OXI-OPERA,TITLE,Dear Doctor,Title,Y,Y,Dr,Dr,Y,Y,,,,
SID-RESORT,OXI-OPERA,TITLE,Dear Mr <LASTNAME>,Title,Y,Y,Mr,Mr,Y,Y,,,,
SID-RESORT,OXI-OPERA,TITLE,Dear Mr. & Mrs. <LASTNAME>,Title,Y,Y,Mr. & Mrs.,Mr. & Mrs.,Y,Y,,,,
SID-RESORT,OXI-OPERA,TITLE,Dear Mrs. <LASTNAME>,Title,Y,Y,Mrs,Mrs,Y,Y,,,,
SID-RESORT,OXI-OPERA,TITLE,Dear Ms <LASTNAME>,Title,Y,Y,Ms.,Ms.,Y,Y,,,,
SID-RESORT,OXI-OPERA,TITLE,Dr. <FIRSTNAME> <LASTNAME>,Title,Y,Y,Dr.,Dr.,Y,Y,,,,
SID-RESORT,OXI-OPERA,TITLE,Misses,Title,Y,Y,MRS,MRS,Y,Y,,,,
SID-RESORT,OXI-OPERA,TITLE,Mistress <FIRSTNAME>,Title,Y,Y,Mistress,Mistress,Y,Y,,,,
SID-RESORT,OXI-OPERA,TITLE,Mr. <LASTNAME>,Title,Y,Y,Mr.,Mr.,Y,Y,,,,
SID-RESORT,OXI-OPERA,TITLE,Mrs. <LASTNAME>,Title,Y,Y,Mrs.,Mrs.,Y,Y,,,,
SID-RESORT,OXI-OPERA,TITLE,Ms. <FIRSTNAME> <LASTNAME>,Title,Y,Y,Ms,Ms,Y,Y,,,,
SID-RESORT,OXI-OPERA,TITLE,Princess <FIRSTNAME>,Title,Y,Y,Princess,Princess,Y,Y,,,,
SID-RESORT,OXI-OPERA,TITLE,Professor <LASTNAME>,Title,Y,Y,Professor,Professor,Y,Y,,,,
SID-RESORT,OXI- OPERA,TITLE,Royalty,Title,Y,Y,Excellence,Excellence,Y,Y,,,,
SID-RESORT,OXI-OPERA,TITLE,S.E. Madame l'Ambassadeur <FIRSTNAME> <LASTNAME>,Title,Y,Y,S.E Mme Amb.,S.E Mme Amb.,Y,Y,,,,
SID-RESORT,OXI-OPERA,TITLE,S.E. Monsieur l'Ambassadeur  & Madame <FIRSTNAME> <LASTNAME>,Title,Y,Y,S.E. Amb & Mme,S.E. Amb & Mme,Y,Y,,,,
SID-RESORT,OXI-OPERA,TITLE,S.E. Monsieur le Ministre & Madame <FIRSTNAME> <LASTNAME>,Title,Y,Y,S.E. Min & Mme,S.E. Min & Mme,Y,Y,,,,
SID-RESORT,OXI-OPERA,TITLE,Sister <FIRSTNAME>,Title,Y,Y,SIS,SIS,Y,Y,,,,
SID-RESORT,OXI-OPERA,TITLE,aaaa,Title,Y,Y,Barr,Barr,Y,Y,,,,
SID-RESORT,OXI-OPERA,TITLE,admiral & Misses with a very large description to see if error appears,Title,Y,Y,Admiral,Admiral,Y,Y,,,,
SID-RESORT,OXI-OPERA,TRACE_DEPARTMENT,Action Trace,Trace Departments,Y,Y,ACT,RES,N,Y,,,,
SID-RESORT,OXI-OPERA,TRACE_DEPARTMENT,Blago's Group,Trace Departments,Y,Y,BLA,BLA,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRACE_DEPARTMENT,CARDINALS,Trace Departments,Y,Y,CARD,CARD,Y,Y,,,,
SID-RESORT,OXI-OPERA,TRACE_DEPARTMENT,CUSTOMER TEST,Trace Departments,Y,Y,CUS,CUS,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRACE_DEPARTMENT,Executive,Trace Departments,Y,Y,EXE,EXE,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRACE_DEPARTMENT,Francisco,Trace Departments,Y,Y,FCO,FCO,Y,Y,,,,
SID-RESORT,OXI-OPERA,TRACE_DEPARTMENT,IQ CHAIN,Trace Departments,Y,Y,IQ,IQ,Y,Y,,,,
SID-RESORT,OXI-OPERA,TRACE_DEPARTMENT,Kelly Chain,Trace Departments,Y,Y,KRA,KRA,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRACE_DEPARTMENT,Kempinski,Trace Departments,Y,Y,KEMP,KEMP,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRACE_DEPARTMENT,MYFIDELIO.NET,Trace Departments,Y,Y,MYF,MYF,Y,Y,,,,
SID-RESORT,OXI-OPERA,TRACE_DEPARTMENT,OPERA Remote - Wireless User,Trace Departments,Y,Y,REM,REM,Y,Y,,,,
SID-RESORT,OXI-OPERA,TRACE_DEPARTMENT,Oracle On Behalf,Trace Departments,Y,Y,ORA,ORA,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRACE_DEPARTMENT,Popcorn,Trace Departments,Y,Y,POPCO,POPCO,Y,Y,,,,
SID-RESORT,OXI-OPERA,TRACE_DEPARTMENT,Property 71,Trace Departments,Y,Y,071,071,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRACE_DEPARTMENT,Reservation,Trace Departments,Y,Y,ACT,RES,N,Y,,,,
SID-RESORT,OXI-OPERA,TRACE_DEPARTMENT,Rydges,Trace Departments,Y,Y,RYG,RYG,Y,Y,,,,
SID-RESORT,OXI-OPERA,TRACE_DEPARTMENT,SEFIVE,Trace Departments,Y,Y,SE5,SE5,Y,Y,,,,
SID-RESORT,OXI-OPERA,TRACE_DEPARTMENT,ST1 CHAIN,Trace Departments,Y,Y,ST1,ST1,Y,Y,,,,
SID-RESORT,OXI-OPERA,TRACE_DEPARTMENT,Siemens group,Trace Departments,Y,Y,SIE,SIE,Y,Y,,,,
SID-RESORT,OXI-OPERA,TRACE_DEPARTMENT,Super King,Trace Departments,Y,Y,SK,SK,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRACE_DEPARTMENT,WORLD,Trace Departments,Y,Y,WOR,WOR,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRACE_DEPARTMENT,WestCoast,Trace Departments,Y,Y,WC,WC,Y,Y,,,,
SID-RESORT,OXI-OPERA,TRACE_DEPARTMENT,blago 2,Trace Departments,Y,Y,BLA2,BLA2,Y,Y,,,,
SID-RESORT,OXI-OPERA,TRACE_DEPARTMENT,hotel 1,Trace Departments,Y,Y,H1,H1,Y,Y,,,,
SID-RESORT,OXI-OPERA,TRACE_DEPARTMENT,hotel 2,Trace Departments,Y,Y,H2,H2,Y,Y,,,,
SID-RESORT,OXI-OPERA,TRACE_DEPARTMENT,hotel 3,Trace Departments,Y,Y,H3,H3,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,ABC Test,TA Currency Code,Y,Y,ABC,ABC,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Akdeniz Currency Code,TA Currency Code,Y,Y,AKD,AKD,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Albania Leke,TA Currency Code,Y,Y,ALL,ALL,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Algeria Algeria Dinars,TA Currency Code,Y,Y,DZD,DZD,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Another Mexican Currency,TA Currency Code,Y,Y,MEXC,MEXC,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Argentinian Peso,TA Currency Code,Y,Y,ARS,ARS,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Australian Dollar,TA Currency Code,Y,Y,AUD,AUD,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Azerbaijan Manats,TA Currency Code,Y,Y,AZM,AZM,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Bahrain Dinar,TA Currency Code,Y,Y,BHD,BHD,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Belarus Rubles,TA Currency Code,Y,Y,BYR,BYR,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Bosnia and Herzegovina Convertible arka,TA Currency Code,Y,Y,BAM,BAM,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Botswana Pulas,TA Currency Code,Y,Y,BWP,BWP,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Brunei Dollar,TA Currency Code,Y,Y,BND,BND,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Bulgaria Leva,TA Currency Code,Y,Y,BGN,BGN,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,CATS,TA Currency Code,Y,Y,CAT,CAT,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,CNY,TA Currency Code,Y,Y,CNY,CNY,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Canadian Dollar,TA Currency Code,Y,Y,CAD,CAD,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Cayman Island Dollar,TA Currency Code,Y,Y,KYD,KYD,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Chilean Pesos,TA Currency Code,Y,Y,CLP,CLP,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Colombian Peso,TA Currency Code,Y,Y,COP,COP,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Columbian Peso,TA Currency Code,Y,Y,COL,COL,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Communaute Financi?re Africaine BCEAO Francs,TA Currency Code,Y,Y,XOF,XOF,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Communaute Financi?re Africaine BEAC Francs,TA Currency Code,Y,Y,XAF,XAF,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Congo/Kinshasa Congolese Francs,TA Currency Code,Y,Y,CDF,CDF,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Convertible Cuban Peso,TA Currency Code,Y,Y,CUP,CUP,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Croatia Kuna,TA Currency Code,Y,Y,HRK,HRK,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Cyprus Pound,TA Currency Code,Y,Y,CYP,CYP,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Czech Republic Koruny,TA Currency Code,Y,Y,CZK,CZK,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,DOG,TA Currency Code,Y,Y,DOG,DOG,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Danish Krone,TA Currency Code,Y,Y,DKK,DKK,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Djibouti Francs,TA Currency Code,Y,Y,DJF,DJF,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Duetsch Mark,TA Currency Code,Y,Y,DEM,DEM,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Egyptian Pound,TA Currency Code,Y,Y,EGP,EGP,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Eritrea Nakfa,TA Currency Code,Y,Y,ERN,ERN,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Estonia Krooni,TA Currency Code,Y,Y,EEK,EEK,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Ethiopia Birr,TA Currency Code,Y,Y,ETB,ETB,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Euro Currency Check,TA Currency Code,Y,Y,EUX,EUX,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Euro Currency,TA Currency Code,Y,Y,EUR,EUR,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Fred Test,TA Currency Code,Y,Y,FRE,FRE,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Funny Money,TA Currency Code,Y,Y,LOL,LOL,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Gambia Dalasi,TA Currency Code,Y,Y,GMD,GMD,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Georgia Lari,TA Currency Code,Y,Y,GEL,GEL,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Ghana Cedis,TA Currency Code,Y,Y,GHC,GHC,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Gibraltar Pounds,TA Currency Code,Y,Y,GIP,GIP,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Guatemala Quetzal,TA Currency Code,Y,Y,GTQ,GTQ,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Guernsey Pounds,TA Currency Code,Y,Y,GGP,GGP,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Guinea Francs,TA Currency Code,Y,Y,GNF,GNF,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Guyana Dollars,TA Currency Code,Y,Y,GYD,GYD,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Hong Kong Dollar,TA Currency Code,Y,Y,HK,HK,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Hong Kong Dollar,TA Currency Code,Y,Y,HKD,HKD,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Hungarian Forint,TA Currency Code,Y,Y,HUF,HUF,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Iceland Kronur,TA Currency Code,Y,Y,ISK,ISK,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Indian Rupees,TA Currency Code,Y,Y,INR,INR,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Indonesian Rupiah,TA Currency Code,Y,Y,IDR,IDR,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Iran Rials,TA Currency Code,Y,Y,IRR,IRR,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Irish Punt,TA Currency Code,Y,Y,IRP,IRP,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Isle of Man Pounds,TA Currency Code,Y,Y,IMP,IMP,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Israel New Shekels,TA Currency Code,Y,Y,ILS,ILS,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Japanese Yen,TA Currency Code,Y,Y,JPY,JPY,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Jersey Pounds,TA Currency Code,Y,Y,JEP,JEP,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Jordan Dinars,TA Currency Code,Y,Y,JOD,JOD,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,KEVIN,TA Currency Code,Y,Y,KEVIN,KEVIN,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,KIM,TA Currency Code,Y,Y,KIM,KIM,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Kazakhstan Tenge,TA Currency Code,Y,Y,KZT,KZT,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Kenya Shilling,TA Currency Code,Y,Y,KES,KES,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Kuwait Dinar,TA Currency Code,Y,Y,KWD,KWD,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Kyrgyzstan Soms,TA Currency Code,Y,Y,KGS,KGS,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Latvia Lati,TA Currency Code,Y,Y,LVL,LVL,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Lebanon Pounds,TA Currency Code,Y,Y,LBP,LBP,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Liberia Dollars,TA Currency Code,Y,Y,LRD,LRD,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Libya Dinars,TA Currency Code,Y,Y,LYD,LYD,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Lithuania Litai,TA Currency Code,Y,Y,LTL,LTL,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,MEXICAN PESO,TA Currency Code,Y,Y,MEX,MEX,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Macedonia Denars,TA Currency Code,Y,Y,MKD,MKD,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Malawi Kwachas,TA Currency Code,Y,Y,MWK,MWK,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Malaysian Ringgit,TA Currency Code,Y,Y,MYR,MYR,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Malta Liri,TA Currency Code,Y,Y,MTL,MTL,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Mauritius Rupees,TA Currency Code,Y,Y,MUR,MUR,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Mexican Peso,TA Currency Code,Y,Y,MXN,MXN,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Moldova Lei,TA Currency Code,Y,Y,MDL,MDL,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Morocco Dirhams,TA Currency Code,Y,Y,MAD,MAD,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Mozambique Meticais,TA Currency Code,Y,Y,MZM,MZM,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Namibia Dollars,TA Currency Code,Y,Y,NAD,NAD,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Nepal Nepal Rupees,TA Currency Code,Y,Y,NPR,NPR,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,New Test Currency,TA Currency Code,Y,Y,NEW,NEW,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,New Zealand Dollar,TA Currency Code,Y,Y,NZD,NZD,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Nigeria Nairas,TA Currency Code,Y,Y,NGN,NGN,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Norwegian Krone,TA Currency Code,Y,Y,NOK,NOK,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Oman Rial,TA Currency Code,Y,Y,OMR,OMR,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Pakistan Rupees,TA Currency Code,Y,Y,PKR,PKR,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Paraguay Guarani,TA Currency Code,Y,Y,PYG,PYG,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Peruvian Nuevo Sol,TA Currency Code,Y,Y,PEN,PEN,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Peruvian Nuevo Sol,TA Currency Code,Y,Y,PER,PER,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Poland Zloty,TA Currency Code,Y,Y,PLN,PLN,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Portuguese Escudo,TA Currency Code,Y,Y,PTE,PTE,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Qatar Rials,TA Currency Code,Y,Y,QAR,QAR,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Romania Lei,TA Currency Code,Y,Y,ROL,ROL,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Rouble,TA Currency Code,Y,Y,RUR,RUR,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Russia Rubles,TA Currency Code,Y,Y,RUB,RUB,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Rwanda Rwanda Francs,TA Currency Code,Y,Y,RWF,RWF,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Saudia Arabia Riyal,TA Currency Code,Y,Y,SAR,SAR,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Serbia Dinars,TA Currency Code,Y,Y,CSD,CSD,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Seychelles Rupees,TA Currency Code,Y,Y,SCR,SCR,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Singapore Dollar,TA Currency Code,Y,Y,SGD,SGD,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Slovakia Koruny,TA Currency Code,Y,Y,SKK,SKK,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Slovenia Tolars,TA Currency Code,Y,Y,SIT,SIT,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Somalia Shillings,TA Currency Code,Y,Y,SOS,SOS,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,South Africa Rand,TA Currency Code,Y,Y,ZAR,ZAR,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Stef's Test Currency,TA Currency Code,Y,Y,STP,STP,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Sudan Dinars,TA Currency Code,Y,Y,SDD,SDD,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Swedish Krona,TA Currency Code,Y,Y,SEK,SEK,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Swiss Franc,TA Currency Code,Y,Y,CHF,CHF,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Syria Pounds,TA Currency Code,Y,Y,SYP,SYP,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,TEST,TA Currency Code,Y,Y,TEST,TEST,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Taiwan Dollar,TA Currency Code,Y,Y,TWD,TWD,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Tajikistan Somoni,TA Currency Code,Y,Y,TJS,TJS,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Tanzania Shillings,TA Currency Code,Y,Y,TZS,TZS,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Thailand Baht,TA Currency Code,Y,Y,THB,THB,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Tunisia Dinars,TA Currency Code,Y,Y,TND,TND,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Turkey Lira,TA Currency Code,Y,Y,TRL,TRL,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Turkey Lira,TA Currency Code,Y,Y,YTL,YTL,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Turkmenistan Manats,TA Currency Code,Y,Y,TMM,TMM,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,US Dollar,TA Currency Code,Y,Y,USD,USD,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Uganda Shillings,TA Currency Code,Y,Y,UGX,UGX,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Ukraine Hryvnia,TA Currency Code,Y,Y,UAH,UAH,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,United Arab Emirates Dirham,TA Currency Code,Y,Y,AED,AED,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,United Kingdom Pound,TA Currency Code,Y,Y,GBP,GBP,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Uruguay Peso,TA Currency Code,Y,Y,UYU,UYU,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Uzbekistan Sums,TA Currency Code,Y,Y,UZS,UZS,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Yemen Rials,TA Currency Code,Y,Y,YER,YER,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Zambia Kwacha,TA Currency Code,Y,Y,ZMK,ZMK,Y,Y,,,,
SID-RESORT,OXI- OPERA,TRAVEL_AGENT_CURRENCY_CODES,Zimbabwe Zimbabwe Dollars,TA Currency Code,Y,Y,ZWD,ZWD,Y,Y,,,,
SID-RESORT,OXI-OPERA,VIP_LEVEL,0123456789,VIP Level,Y,Y,0123456789,0123456789,Y,Y,,,,
SID-RESORT,OXI-OPERA,VIP_LEVEL,2000 Character Limit Test2000 Character Limit Test2000 Character Limit Test2000 Character Limit Tes,VIP Level,Y,Y,2,2,Y,Y,,,,
SID-RESORT,OXI-OPERA,VIP_LEVEL,AKDENIZ2,VIP Level,Y,Y,AKD,AKD,Y,Y,,,,
SID-RESORT,OXI-OPERA,VIP_LEVEL,Black listed guest,VIP Level,Y,Y,BLACK,BLACK,Y,Y,,,,
SID-RESORT,OXI-OPERA,VIP_LEVEL,CIP: Corporate Important Person,VIP Level,Y,Y,002,002,Y,Y,,,,
SID-RESORT,OXI-OPERA,VIP_LEVEL,Celebrity,VIP Level,Y,Y,CEL,CEL,Y,Y,,,,
SID-RESORT,OXI-OPERA,VIP_LEVEL,Disabled Traveler,VIP Level,Y,Y,D,D,Y,Y,,,,
SID-RESORT,OXI-OPERA,VIP_LEVEL,Fitness,VIP Level,Y,Y,7,7,Y,Y,,,,
SID-RESORT,OXI-OPERA,VIP_LEVEL,GHA Cardholder (Global Hotel Alliance),VIP Level,Y,Y,008,008,Y,Y,,,,
SID-RESORT,OXI-OPERA,VIP_LEVEL,Gold WestAward Member,VIP Level,Y,Y,G,G,Y,Y,,,,
SID-RESORT,OXI-OPERA,VIP_LEVEL,Guest traveling with Pet,VIP Level,Y,Y,T,T,Y,Y,,,,
SID-RESORT,OXI-OPERA,VIP_LEVEL,Handicap Traveler,VIP Level,Y,Y,H,H,Y,Y,,,,
SID-RESORT,OXI-OPERA,VIP_LEVEL,KPC: Kempinski Private Concierge,VIP Level,Y,Y,005,005,Y,Y,,,,
SID-RESORT,OXI-OPERA,VIP_LEVEL,LIP: Loyalty Important Person,VIP Level,Y,Y,003,003,Y,Y,,,,
SID-RESORT,OXI-OPERA,VIP_LEVEL,LONGVIP,VIP Level,Y,Y,LONGVIPKJH,LONGVIPKJH,Y,Y,,,,
SID-RESORT,OXI-OPERA,VIP_LEVEL,Leisure,VIP Level,Y,Y,6,6,Y,Y,,,,
SID-RESORT,OXI-OPERA,VIP_LEVEL,Local calls free,VIP Level,Y,Y,VPM,VPM,Y,Y,,,,
SID-RESORT,OXI-OPERA,VIP_LEVEL,Medioker,VIP Level,Y,Y,8,8,Y,Y,,,,
SID-RESORT,OXI-OPERA,VIP_LEVEL,Mgr Repeat Guest,VIP Level,Y,Y,3,3,Y,Y,,,,
SID-RESORT,OXI-OPERA,VIP_LEVEL,Normal guest,VIP Level,Y,Y,000,000,Y,Y,,,,
SID-RESORT,OXI-OPERA,VIP_LEVEL,Owner's Club Cardholder,VIP Level,Y,Y,006,006,Y,Y,,,,
SID-RESORT,OXI-OPERA,VIP_LEVEL,PMS Only  do not add it in ORS,VIP Level,Y,Y,PMS,PMS,Y,Y,,,,
SID-RESORT,OXI-OPERA,VIP_LEVEL,Platinum WestAwards Member,VIP Level,Y,Y,P,P,Y,Y,,,,
SID-RESORT,OXI-OPERA,VIP_LEVEL,Rack,VIP Level,Y,Y,5,5,Y,Y,,,,
SID-RESORT,OXI-OPERA,VIP_LEVEL,Repeat Guest,VIP Level,Y,Y,0,0,Y,Y,,,,
SID-RESORT,OXI-OPERA,VIP_LEVEL,Sales Repeat Guest,VIP Level,Y,Y,4,4,Y,Y,,,,
SID-RESORT,OXI-OPERA,VIP_LEVEL,Special Attention,VIP Level,Y,Y,001,001,Y,Y,,,,
SID-RESORT,OXI-OPERA,VIP_LEVEL,VIP,VIP Level,Y,Y,1,1,Y,Y,,,,
SID-RESORT,OXI-OPERA,VIP_LEVEL,VIP: Very Important Person,VIP Level,Y,Y,004,004,Y,Y,,,,
SID-RESORT,OXI-OPERA,VIP_LEVEL,VVIP: Very  very important person (Corporate office only),VIP Level,Y,Y,007,007,Y,Y,,,,
SID-RESORT,OXI-OPERA,VIP_LEVEL,WestAwards Member,VIP Level,Y,Y,Q,Q,Y,Y,,,,
SID-RESORT,OXI-OPERA,VIP_LEVEL,WestAwards Redemption Member,VIP Level,Y,Y,W,W,Y,Y,,,,
SID-RESORT,OXI-OPERA,WAITLIST_CODES,AKDENIZ 2,Waitlist Code,Y,Y,002,002,Y,Y,,,,
SID-RESORT,OXI-OPERA,WAITLIST_CODES,Full House,Waitlist Code,Y,Y,FUL,FUL,Y,Y,,,,
SID-RESORT,OXI-OPERA,WAITLIST_CODES,Global Signature/Major Account,Waitlist Code,Y,Y,GSA,GSA,Y,Y,,,,
SID-RESORT,OXI-OPERA,WAITLIST_CODES,Golden Circle Member,Waitlist Code,Y,Y,GCM,GCM,Y,Y,,,,
SID-RESORT,OXI-OPERA,WAITLIST_CODES,Group/Allotment not available,Waitlist Code,Y,Y,BLOCK,BLOCK,Y,Y,,,,
SID-RESORT,OXI-OPERA,WAITLIST_CODES,High Occupancy,Waitlist Code,Y,Y,HO,HIGH,Y,N,,,,
SID-RESORT,OXI-OPERA,WAITLIST_CODES,No Rates Defined For This Date,Waitlist Code,Y,Y,NR,NR,Y,Y,,,,
SID-RESORT,OXI-OPERA,WAITLIST_CODES,Per Guest's Request,Waitlist Code,Y,Y,GST,GST,Y,Y,,,,
SID-RESORT,OXI-OPERA,WAITLIST_CODES,Room Type not available,Waitlist Code,Y,Y,RM,RM,Y,Y,,,,
SID-RESORT,OXI-OPERA,WAITLIST_CODES,Room not available all nights,Waitlist Code,Y,Y,LOS,LOS,Y,Y,,,,
SID-RESORT,OXI-OPERA,WAITLIST_CODES,Smoking Preference Unavailable,Waitlist Code,Y,Y,SP,SP,Y,Y,,,,
SID-RESORT,OXI-OPERA,WAITLIST_CODES,Specific Rate Not Available,Waitlist Code,Y,Y,SRT,SRT,Y,Y,,,,
SID-RESORT,OXI-OPERA,WAITLIST_CODES,Specific Room Not Available,Waitlist Code,Y,Y,SRM,SRM,Y,Y,,,,
SID-RESORT,OXI-OPERA,WAITLIST_CODES,WAITLIST 1,Waitlist Code,Y,Y,001,001,Y,Y,,,,
SID-RESORT,OXI-OPERA,WAITLIST_CODES,max length test,Waitlist Code,Y,Y,0123456789,0123456789,Y,Y,,,,
