previous
REGENERATE LEADS FOR ROOMNIGHT DIFFERENCE Application Setting
Group.  Lead
Type. Setting
Application. S&C
                     ORS (Global)
Description.  Leads will be regenerated if the total number of room nights gets changed by the percentage value
Property Determination.
Activation / Inactivation Rules.
OPX_SFA active
OPR_XXX and or SFA active
Available Values.
<none>
Add On Licenses/Country Specifics.
<none>
Other Application Settings.
<none>
Affected Areas
Menus / Screens / Fields.
<none>
Reports & Report Forms.
<none>
Permissions.
<none>
Other Areas.
<none>
