sipShield Plug-in
The sipShield SPL Plug-in enables the Oracle Communications Session Border Controller to drop SIP messages containing the identifying characteristics of known malicious tools. Common attack types include information collection, denial-of-service, and toll fraud.
This version of the sipShield SPL Plug-in, 1.9, may be run on an SBC that supports SPL Engine C2.0.1. A list of supported SPL Engines may be found in the SBC Release Notes.
- SIPVicious
- SIPScan
- SMap
- Sipsak
- Sipcli
- Sivus
- Protos
- Gulp
- Sipv
- Sundayddr Worm
- Spoofed eyeBeam Client
- VaxIPUserAgent
- sipArmyKnife
- Viproy
How It Works
test
The plug-in scans SIP message fields (User-Agent, From, To, Subject, etc.) for identifying characteristics of known attack tools. Once a SIP message is flagged as a threat, the message is dropped and all processing of the message ceases.
The administrator can also specify a regex to match an expected User-Agent value to aid in identifying potentially fraudulent traffic quickly. This strategy is called “whitelisting”. If the whitelist passes, sipShield will continue processing, looking for other indicators of abuse.
The system creates a log entry for each drop event that includes the source IP address and the flagged portion of the message.
You must still configure proper SBC security settings such as registration policies, ACL, and signaling thresholds for attacks that may randomize their identifying fields.
Enabling the Plug-in
- Access the plug-in via My Oracle Support.
- Upload the SPL plug-in to a SBC.
- Add the SPL plug-in to the SBC configuration.
- Execute the SPL plug-in on the SBC.
- Synchronize the plug-in accross HA pairs.
Messages Dropped Counter
The sipShield plug-in comes with a counter to track the number of SIP attack messages dropped. The counter is enabled automatically when using the block-attack-tools spl option.
Executing SPL Files
- Perform a save-config and activate-config after exiting the configuration menu.
Oracle recommends that scripts are only refreshed during planned maintenance windows.If an SPL file exists in the /code/spl directory,
but is not configured in the
spl-files parameter, it will be ignored when the
ACLI User Interface is booting.
Synchronizing SPL Files Across HA Pairs
When running in an HA configuration, both the active and the
standby systems must have the same version of the SPL plug-in installed. To
facilitate configuring the standby system, execute the
synchronize
spl command (with no arguments) to copy all files in the
/code/spl directory
from the active system to the same directory on the standby, overwriting any
existing files with the same name.
ACMEPACKET#synchronize spl /code/spl/sipShield.1.9.spl Waiting for request to finish Request to 'SYNCHRONIZE' has Finished, Synchronization Complete
For the synchronize spl command to work properly, you must include the full path of the plugin.- In Superuser mode, type
synchronize
spl and press <Enter>.
ACMEPACKET# synchronize spl
Configuring the Plug-in Options
When the plug-in is enabled on both the sip-interface and realm-config, the sip-interface takes precedence.Maintenance and Troubleshooting
This section provides information about how to troubleshoot and collect information about your SPL plug-in. You must save and activate your configuration changes to display SPL show command output.
show SPL
The acli show spl command displays:
- The version of the SPL engine
- The filenames and version of the SPL plug-ins currently loaded on the SBC
- The signature state of each plug-in
- The system tasks that each loaded plug-in interacts with, enclosed in brackets.
ACMEPACKET# show spl SPL Version: C3.1.10 [sipd] File: sipShield.1.9.spl (plugin) version: 1.9 timestamp: release signature: signed and valid ACMEPACKET# show spl sipd SPL Version: C3.1.10 [sipd] File: sipShield.1.9.spl (plugin), version: 1.9, timestamp: release, signature: signed and valid
show running-config spl-config
spl-config spl-options plug-ins name sipShield.1.1.spl last-modified-by admin@10.0.221.127 last-modified-date 2013-03-01 08:36:29
show directory /code/spl
/code/spl directory.
ACMEPACKET# show directory /code/spl Listing Directory /code/spl: drwxrwxrwx 1 0 0 4096 Aug 13 10:07 ./ drwxrwxrwx 1 0 0 4096 Aug 19 22:25 ../ -rwxrwxrwx 1 0 0 3163 Aug 13 10:07 sipShield.1.1.spl
show spl-options
ACMEPACKET# show spl-options 1. block-attack-tools: Directs the sip-interface or realm to drop common SIP attacks [config,sipShield.1.3.spl,sipShield.1.4.spl] 2. whitelist: Directs the sip-interface or realm to drop user agents that do not match the whitelist regex value [config,sipShield.1.4.spl]
Deleting SPL Plug-ins
Deleting files from /code/spl must be performed via FTP/SFTP; there is no means to delete files from the ACLI.
SPL Log Types
SPL log messages can often be found in the log file for the system task to which the SPL applies when that task is set to DEBUG level. You can find the output specific to SPL by the identifying prefix [SPL].
sysmand.log
sysmand.log:11:[sipShield] Scanner or attack field detected! Src IP: 192.168.69.44, User-Agent: friendly-scanner, received on 192.168.69.57:5060 realm: access sysmand.log:23:[sipShield] Scanner or attack field detected! Src IP: 192.168.69.44, User-Agent: friendly-scanner, received on 192.168.69.57:5060 realm: access
log.sipd
Jun 11 11:48:47.223 [SIP] (1) INVITE 1 parse_via: reply=192.168.69.44:5060 from-Realm=access Jun 11 11:48:47.223 [SIP] (1) from-SA=192.168.69.44 Jun 11 11:48:47.223 [SIP] (1) gwcon=<none> Jun 11 11:48:47.223 [SPC] (1) Executing 1 callbacks at CL_SIP_MSG_RECV Jun 11 11:48:47.223 [SPC] (1) Executing SPL callback from file: sipShield.1.9.spl Jun 11 11:48:47.223 [SPL] (1) SIP <false> regex <nil> Realm <false> regex <nil> Jun 11 11:48:47.223 [SPL] (1) ** sipShield data ** Jun 11 11:48:47.223 [SPL] (1) Agent: User-Agent: friendly-scanner Jun 11 11:48:47.223 [SPL] (1) From: From: "sipvicious"<sip:100@1.1.1.1>;tag=34323432343230323133633401363536393938313331 Jun 11 11:48:47.223 [SPL] (1) Subject: <nil> Jun 11 11:48:47.223 [WARNING] (1) [sipShield] Scanner or attack field detected! Src IP: 192.168.69.44, User-Agent: friendly-scanner, received on 192.168.69.57:5060 realm: access
