Studio Environment Editor Activation Connection Details Area
Use the Connection Details area, in the Connection Information tab on the Studio Environment editor, to provide details to connect to ASAP. See "Studio Environment Editor" for more information.
Field Use
Environment ID Specify the ASAP environment ID, of an ASAP instance, specified during ASAP installation.
Activation Version Select an ASAP version to which you will connect.
Server Address Specify the IP address or the host name of the computer on which the Oracle WebLogic Server is installed. If ASAP is installed on the administration server, use the IP address or the host name of the administration server. If ASAP is installed on a managed server, use the IP address or the host name of the managed server.
Server Port Number Specify the port number of the computer on which the WebLogic Server is installed. If ASAP is installed on the administration server, use the port of the administration server. If ASAP is installed on a managed server, use the port of the managed server.
JNDI Context Displays the JNDI context that appears based on the selected Activation version. WebLogic Server uses JNDI context and the queues mentioned in this tab to communicate to ASAP.
Order Submission Queue Displays the name of the queue in the WebLogic Server where the orders are submitted to ASAP.
Order Event Queue Displays the name of the queue in the WebLogic Server where events from ASAP are received.
Order Response Queue Displays the name of the queue in the WebLogic Server where a work order response is received.
Related Topics
Packaging and Deploying Activation Cartridges
Studio Environment Editor Cartridge Management Variables Tab
