FATCA is the acronym for Foreign Account Tax Compliance Act enacted by the US Government as part of the Hiring Incentives to Restore Employment (HIRE) Act, in 2010.The purpose of FATCA is to help Internal Revenue Service (IRS) to identify and collect tax from US Persons (USP) holding financial assets outside US.
This chapter deals with Foreign Account Tax Compliance regulation. It includes the description about functions that would help FCIS to support FATCA.
The below mentioned table describe the system parameters for the related fields:
Field |
System Parameter |
Maximum Length |
FATCA Classification –Individual |
FATCACATIND |
10 |
FATCA Classification –Corporate |
FATCACATCOR |
10 |
FATCA Classification Reasons |
FATCACATREASON |
10 |
FATCA Effective Date |
FATCAEFFDATE |
10 |
FATCA Individual UH Reporting |
FATCAINDUHLIMIT |
10 |
FATCA Corporate UH Reporting |
FATCACORPUHLIMIT |
10 |
FATCA Verification Time Limit in days |
FATCAVERTMLIMIT |
4 |
FATCA Due Diligence Date |
FATCADUEDELIGENCEDATE |
10 |
FATCA Country Code |
FATCACNTRYCD |
3 |
FATCA Amount Limit |
FATCAAMOUNTLIMIT |
10 |
FATCA WHT Applicable |
FATCAWHTAPPLICABLE |
3 |
FATCA WHT Effective Date |
FATCAWHTEFFDT |
10 |
FATCA WHT Percentage |
FATCAWHTPERCENTAGE |
3 |
Document for individuals |
MASTERDOCIND |
Max |
Document for corporate |
MASTERDOCCORP |
Max |
Category of the documents |
MASTERDOCCAT |
3,2 |
Max % of holding for Corporate UH for the defined directors |
FATCAMINPCNTHLDG |
Max |
The international dialling country code |
INTDIALCODE |
You can maintain the list of FATCA Document details in the ‘FATCA Document Maintenance-Detail’ screen. To invoke this screen type ‘UTDFATDT’ in the field at the top right corner of the Application tool bar and click on the adjoining arrow button.
You can capture the following in this screen:
FATCA Entity Type
Alphanumeric; Mandatory
Select the FATCA entity type from the adjoining option list.
Entity Category Type
Select the entity category type from the adjoining drop-down list. The options available are:
Select the FATCA Classification from the adjoining option list.
FATCA Classification Description
Display
The system will display the description based on the selected FATCA Classification.
FATCA Reportable
Optional
FATCA Reportable gets defaulted from the FATCA document maintenance for the entity selected. You can change the value from ‘Yes’ to ‘No’, but vice versa is not allowed.
System defaults FATCA Reportable as ‘No’.
FATCA With holdable
Optional
FATCA With holdable gets defaulted from the FATCA document maintenance for the entity selected. You can change the value from ‘Yes’ to ‘No’, but vice versa is not allowed.
System defaults FATCA With holdable as ‘No’.
Document Category
Select the category of the document from the adjoining option list.
Document Category Description
Display
The system displays the document category description based on the selected document category.
Document Type
Select the type of document from the adjoining option list.
Document Type Description
Display
The system displays the document type based on the selected document type.
Mandatory
You need to indicate whether the document is mandatory or optional. The drop-down list displays the following options:
Select the appropriate option.
Document Category
Select the document category from the adjoining option list.
Display
Minimum Number Reqd
Numeric; Mandatory
Specify the minimum number of the standard documents that is required.
You can view FATCA Maintenance details in the ‘FATCA Document Maintenance Summary’ screen. You can invoke this screen by typing ‘UTSFATDT’ in the field at the top right corner of the Application tool bar and clicking on the adjoining arrow button.
You can perform the following actions using this screen
You can view previously entered details of FATCA Maintenance in the ‘FATCA Maintenance Summary’ screen, as follows:
Click ‘Search’ button to view the records. All records with the specified details are retrieved and displayed in the lower portion of the screen.
You can also search the record by using combination of % and alphanumeric value.
You can delete only unauthorized records in the system. To delete a record that you have previously entered:
You can modify only unauthorized records in the system. To modify a record that you have previously entered:
You can authorize records in the system. To authorize a record that you have previously entered:
You can maintain FATCA Classification and record document details in the ‘Entity FATCA Classification Maintenance Detail’ screen. To invoke this screen type ‘UTDFATMT’ in the field at the top right corner of the Application tool bar and click on the adjoining arrow button.
You can capture the following details in this screen:
Reference Number
Optional
Specify the reference number.
FATCA Entity Type
Select the FATCA entity type from the adjoining drop-down list. The options available are:
Entity ID
Select the Entity identification from the adjoining option list.
Entity Name
Display
The system defaults the entity name from the entity record.
Display
The system displays the entity category type.
Alphanumeric; Optional
Description
Give a brief description on FATCA classification.
Select the reason for FATCA classification from the adjoining option list.
Description
Give a brief description on the FATCA classification reason.
FATCA Reportable
Optional
FATCA With holdable
Optional
Document Category
Document Type
Select the type of the document from the adjoining option list.
Mandatory
Document ID
Specify the document identification.
Issue Date
Date Format; Mandatory
Specify the issue date of the received document.
Expiry Date
Date Format; Optional
Specify the expiry date of the received document.
Copy Received
Check this box to indicate that the copy is received.
Original Received
Check this box to indicate that the original is received.
Received Date
Specify the document received date.
Document Reference Number
Specify the document tracking reference number.
Remarks
Specify remarks, if any.
Chasing Date
Specify the document chasing date.
Document Upload
Click this button to upload or view the documents.
FATCA Compliant
Display
The system displays whether you are FATCA compliant.
Remarks
Click on Linked Entity to maintain linked entity details.
You can maintain the following here:
Auth Status
Specify the Authorization status.
Linked Entity Type
Select the linked entity type from the adjoining option list.
Entity ID
Optional
Specify the entity identification.
Entity Name
Specify the entity name.
US Indicia Available
Display
The system defaults the US Indicia as Yes or No.
Display
The system displays the FATCA classification type.
FATCA Compliant
Display
The system defaults whether the linked entity is FATCA Complaint.
View
Click on ‘View’ to view the details of FATCA Maintenance of a linked entity.
Note
During UT Transaction capture for US Indicia Available Funds, if the FATCA Status of the unit holder or linked entity of a unit holder is:
During LEP Transaction capture for US Indicia Available Funds, if the FATCA Status of the unit holder or linked entity of a unit holder is:
If the US Indicia is available for one of the customer during the CIF merge, then the customer account to which this account is being merged will also be US Indicia.
You can view, modify, delete and authorize Entity FATCA Classification Maintenance details in the ‘Entity FATCA Classification Maintenance Summary’ screen. You can invoke this screen by typing ‘UTSFATMT’ in the field at the top right corner of the Application tool bar and clicking on the adjoining arrow button.
You can view previously entered details of Entity FATCA Classification Maintenance Detail in the ‘Entity FATCA Classification Maintenance Summary’ screen, as follows:
