9. Maintaining Time Zones
9.1 Time Zone
9.1.1 Maintaining Time Zones
Oracle FLEXCUBE Investor Servicing (FCIS) enables you to capture time zones for a particular module. This feature is particularly applicable if you are using Oracle FLEXCUBE Investor Servicing for your Financial Services across the globe.
The ‘Time Zone Maintenance Detail’ screen allows you to capture time zones for various modules. You can invoke this screen by typing ‘UTDTIMEZ’ in the field at the top right corner of the Application tool bar and clicking on the adjoining arrow button. Select ‘New’ from the Actions menu in the Application tool bar or click new icon to enter the time zone details.
You can specify the following fields in this screen:
Time Zone
Mandatory
Enter the Time Zone. This can be captured for a particular entity.
Description
Character
Enter a brief description of the Time Zone specified.
Rule Effective Date
Mandatory, DD/MM/YYYY
Enter the date from when the Time Zone has to be considered for any particular entity.
Daylight Start Date
Specify the date from when the Daylight Saving Time or Summer Time starts.
Daylight End Date
Specify the date from when the Daylight Saving Time or Summer Time ends.
Offset From GMT
Mandatory, HH24 : MM : SS
Enter the time difference between the Time Zone and Greenwich Meridian Time.
Server Time Zone
Check this option in order to specify if the time zone code is where the server would be located.
Behind GMT
Check this option to denote that the Time Zone being maintained is behind GMT.
Click ‘Ok’ button to save the Time Zone captured in the system.
Note
9.2 Time Zone Maintenance Summary Screen
9.2.1 Invoking the Time Zone Maintenance Summary Screen
To perform any operation on Fund-ISIN association, you must first retrieve the record from the database in the Summary screen. You can invoke the ‘Time Zone Maintenance Summary’ screen by typing ‘UTSTIMEZ’ in the field at the top right corner of the Application tool bar and clicking on the adjoining arrow button.
9.2.2 Retrieving Record in Time Zone Summary Screen
You can retrieve a previously entered record in the Summary Screen, as follows:
Invoke the summary screen and specify any or all of the following details in the corresponding fields:
Note
You can also retrieve the individual record detail from the detail screen by querying in the following manner:
You can perform Edit, Delete, Amend, Authorize, Reverse, Confirm operations by selecting the operation from the Action list. You can also search a record by using a combination of % and alphanumeric value.
Example
You can search the record for Time Zone by using the combination of % and alphanumeric value as follows:-
9.2.3 Editing Time Zone Maintenance
You can modify the details of a Time Zone Maintenance that you have already entered into the system, provided it has not been subsequently authorized. You can perform this operation as follows:
9.2.4 Viewing Time Zone Maintenance
To view a record that you have previously input, you must retrieve the same in the Time Zone Summary screen as follows:
9.2.5 Deleting Time Zone Maintenance
You can delete only unauthorized records in the system. To delete a record that you have previously entered:
9.2.6 Authorizing Time Zone Maintenance
An unauthorized Time Zone Maintenance must be authorized in the system for it to be processed. To authorize a record:
When a checker authorizes a record, details of validation, if any, that were overridden by the maker of the record, during the Save operation are displayed. If any of these overrides results in an error, the checker must reject the record.
9.2.7 Amending Time Zone Maintenance
After a Time Zone Maintenance is authorized, it can be modified using the Unlock operation from the Action List. To make changes to a record after authorization:
9.2.8 Authorizing Amended Time Zone Maintenance
An amended Time Zone Maintenance must be authorized for the amendment to be made effective in the system. The authorization of amended records can be done only from Fund Manager Module and Agency Branch module.
The subsequent process of authorization is the same as that for normal transactions.
9.2.9 Copying Attributes
If you want to create a new Time Zone Maintenance with the same attributes of an existing maintenance, you can copy the attributes of an existing Time Zone Maintenance to a new one.
To copy the attributes:
9.2.10 Database and Web Server Time
The Agency Branch is the entity for which a Time Zone is associated. The Agency Branch module time is used instead of the Database server time as the transaction save and authorization time. The Agency Branch time is arrived by the time zone set for it with respect to the module from which the transaction is being captured.
During handoff of Fund Rule, the cut off time is not changed as per the local time, but Fund Amendment is allowed from distributor. The fund cut off time must be amended manually to reflect the local time by the Distributor. This Fund local time is used to arrive into transaction cut off time at the time of transaction capturing from distributor and if the fund local time exceeds the fund cut off time the transaction date is captured as next working date.
9.3 Default Time Zones and Scheduler Changes Mainte­nance
Each Agency Branch is associated with a time zone. This time zone is used in case a country has multiple time zones.
While setting up the job for scheduler, you can schedule a job based on the client time. This time has to be the web server time for that module.
The Defaults Maintenance screen allows you to capture the default time zone.
Refer to the chapter ‘Maintaining System Parameters’ in this User Manual for further information on the Defaults Maintenance screen.
