| Siebel CRM Siebel Mobile Guide: Connected Siebel Innovation Pack 2014 Rev. A E52426-01 |
![]() Previous |
![]() Next |
View PDF |
The following procedures related to using the home page for Siebel Pharma are included in this topic:
Note: You must complete the relevant setup tasks detailed in Siebel Life Sciences Guide and Siebel Applications Administration Guide before using the Siebel Mobile application for Siebel Pharma. |
On the home page for Siebel Pharma, you can view the call planning information for contacts and accounts in the calendar.
Note: Viewing calls in the calendar is similar to viewing activities in the calendar. For more information about using the calendar to view activities, see Siebel Fundamentals for Siebel Open UI. |
To view the call planning information
Tap the Side Menu icon on the application banner, and then tap Calls to display the following:
The calendar showing the call planning information in the right pane or work area.
The Contacts and Accounts list in the left pane. Tap Contacts or Accounts to expand the corresponding contacts or accounts list.
On the calendar in the right pane, view the call planning information as follows:
Tap the left and right arrows to navigate across dates and view the calls scheduled on different dates.
Tap the daily or weekly calendar icon to switch between the daily and weekly view of calls scheduled.
Tap Today to see the calls scheduled for today's date.
On the calendar in the right pane, you can perform the following tasks:
Extend the duration of a call by tapping the border of the call and dragging it out.
Move a call by tapping the call, and then dragging and dropping it on a different time or date.
Tap a call on the calendar to drilldown and open the call details. For more information, see "Displaying Call Details".
Schedule a call for a contact or an account. For more information, see "Scheduling Calls For Contacts and Accounts".
On the home page for Siebel Pharma, you can schedule calls for contacts and accounts in the calendar.
Note: Scheduling calls in the calendar is similar to scheduling activities in the calendar. For more information about using the calendar to schedule activities, see Siebel Fundamentals for Siebel Open UI. |
To schedule calls for contacts and accounts
Schedule a new contact call as follows:
Tap Contacts in the left pane to expand the contacts list, and then select a contact from the list.
Drag and drop the selected contact onto the calendar in the right pane to schedule the new call.
Drilldown on the new call to open it.
Modify the call details as required. For more information, see "Modifying Call Information",
Modify the related items for the call as required. For more information, see Step 0 in "Displaying Call Details".
Schedule a new account call as follows:
Tap Accounts in the left pane to expand the accounts list, and then select a contact from the list.
Drag and drop the selected account onto the calendar in the right pane to schedule the new call.
Modify the call details as required. For more information, see "Modifying Call Information".
