| Siebel CRM Siebel Mobile Guide: Connected Siebel Innovation Pack 2014 Rev. A E52426-01 |
![]() Previous |
![]() Next |
View PDF |
You can print from Siebel Mobile, using the print option from your browser's Settings menu, provided that you have access to one of the following:
A printer that is set up on the wireless network to which your mobile device is connected or a Bluetooth-enabled mobile printer.
A wireless printer that is compatible with and supports Apple's AirPrint™ technology.
To print from Siebel Mobile
With the page that you want to print displayed, tap Settings on the browser navigation bar.
The following options are available from the browser's Settings menu:
Add Bookmark
Add to Reading List
Add to Home Screen
Mail Link to this Page
Tweet
Tap Print, Select Printer, and then the name of your wireless printer.
Tap plus or minus to indicate the number of copies that you want to print.
Tap Print to start printing.
If you do not have an AirPrint-compatible wireless printer, then email a link of the page to yourself, open the link on your desktop computer, and then print the page.
