| Siebel CRM Siebel Mobile Guide: Disconnected Siebel Innovation Pack 2014 Rev. A E52427-01 |
![]() Previous |
![]() Next |
View PDF |
Siebel Mobile uses Siebel Open UI. Before you can use Siebel Mobile, you must meet the following requirements:
You must have a mobile device with an internet connection.
The browser on your mobile device must support the following: HTML5, CSS 3.0 or higher, and JavaScript 1.5 or higher.
For Siebel Mobile applications in offline mode, you must have a minimum of 50 megabytes (MB) of available storage on your mobile device.
You have reviewed the topics about Siebel Open UI and Siebel Mobile applications in the applicable Siebel Installation Guide for the operating system you are using.
