| Siebel CRM Siebel Mobile Guide: Disconnected Siebel Innovation Pack 2014 Rev. A E52427-01 |
![]() Previous |
![]() Next |
View PDF |
This chapter describes how to administer Siebel Mobile disconnected applications. It includes the following topics:
Setting Up Users for Siebel Mobile Disconnected Applications
Configuring Access to Views for Siebel Mobile Disconnected Applications
Administration Screen Settings for Siebel Mobile Disconnected Applications
Configuring Application Settings for Siebel Mobile Disconnected Applications
Configuring Component-Level Settings for Siebel Mobile Disconnected Applications
Thread Throttling for Siebel Mobile Disconnected Applications
Configuring Synchronization for Siebel Mobile Disconnected Applications
Monitoring Synchronization Sessions for Siebel Mobile Disconnected Applications
Troubleshooting Synchronization Failures Due to Business Component Filters
Note: By default, most of the parameters referenced in this chapter are not automatically available as options in the menus of your Siebel Mobile disconnected application, and as a result they are not set in the default configuration. If you want to make these and any other new parameters available, then you must add them to your Siebel Mobile disconnected application by creating a new parameter record for each parameter that you want to make available. |
