| Siebel CRM Siebel Mobile Guide: Disconnected Siebel Innovation Pack 2014 Rev. A E52427-01 |
![]() Previous |
![]() Next |
View PDF |
This task is a step in "Roadmap for Setting Up Siebel Mobile Disconnected Applications". The components that are required for Siebel Mobile disconnected applications are installed when you install the Siebel Server. This topic includes the following information:
"Siebel Server Component Parameters for Siebel Mobile Disconnected Application Synchronization"
Add the remote installation for Siebel Mobile disconnected applications
For information about enabling the component groups for Siebel Mobile, see "Enabling the Handheld Component Groups for Siebel Mobile Disconnected Applications" and "Setting Up the Disconnected Mobile Synchronization Component Group".
For information about installing and configuring Siebel Server, see Siebel Installation Guide for the operating system you are using for the operating system you are using.
Install the Siebel Server, following the instructions in the Siebel Server installation guide for the operating system you are using. When you reach the Setup Type screen in the Installer wizard, you are presented with three installation options:
Typical. This setup option installs all Siebel Server components.
Compact. This setup option installs only those components necessary to run the Siebel Server but no additional components or help.
Custom. This setup option lets you customize your installation by choosing the specific components that you want to install.
To install the components for Siebel Mobile disconnected application synchronization with your Siebel Server installation
During the Siebel Server installation, when the Setup Type screen appears, choose the Custom setting, and then click Next.
Note: At this screen, you can also choose a different directory for your Siebel Server installation. |
From the following components, choose Handheld Synchronization:
Siebel Application Object Manager Component
Siebel Data Quality Connector
Remote Search Support
Siebel Java Integrator
Click Next.
Continue with the installation in the Siebel Installation Guide for the operating system you are using. The installation wizard automatically installs and configures the components for server synchronization.
Some common mobile applications, such as Siebel Pharma, are preconfigured by default. If you want to configure additional applications, see "Configuring Siebel Server for Siebel Mobile Disconnected Application Synchronization" for more information. You must add the synchronization server components that you installed and configured to reflect your company's environment. See Table 6-1 for a list of the required parameters. For information on adding server components for server synchronization, see Siebel System Administration Guide.
Table 6-1 Siebel Server Component Parameters for Server Synchronization
| Parameter | Default Value | Description |
ApplicationName |
This value can be, for example, the following: Siebel ePharma Mobile. |
The Siebel Mobile disconnected application. This value must match the name of the mobile application as it is specified in Siebel Tools. |
ApplicationTitle |
The name of the Siebel Mobile disconnected application as shown on the title bar on the browser. This parameter is used only if the Siebel application developed for the mobile application is running on the Siebel Mobile Web Client. |
ApplicationSplashText |
The Siebel Mobile disconnected application name as shown on the splash screen. This parameter is used only if the application developed (in Siebel Tools) for the Siebel Mobile disconnected application is running on the Siebel Mobile Web Client. |
