| Siebel Customer Relationship Management Siebel Fundamentals for Siebel Open UI Siebel Innovation Pack 2014 E52425-01 |
![]() Previous |
![]() Next |
View PDF |
Click the box next to (or below) an option to select or clear the check box. When you click an empty box, a check mark or an X appears in the box. If you click a box that is selected, then the check mark or X disappears. Figure 4-4 shows an example of check boxes.
In query mode, check boxes have a third possible state. For more information about using check boxes in query mode, see "Tips for Queries."
You can press the space bar to select and deselect check boxes.
