| Siebel Customer Relationship Management Siebel Fundamentals for Siebel Open UI Siebel Innovation Pack 2014 E52425-01 |
![]() Previous |
![]() Next |
View PDF |
You access the currency calculator by clicking the calculator button that appears in a field for an amount and a currency. Figure 4-7 shows an example of the currency calculator. You use the currency calculator to specify financial transaction information in foreign currencies.
Figure 4-7 Example of the Currency Calculator
Table 4-2 describes each field control in the currency calculator.
Table 4-2 Description of Currency Calculator Fields
| Field | Field Control | Description |
Currency Code |
Single select button |
Launches a dialog box where you can select the country and currency code. |
Exchange Date |
Calendar select button |
Launches the calendar control where you can select the exchange date. The field does not appear in all currency calculators. For more information about the calendar control, see "About the Calendar Control". |
Amount |
Calculator button |
Launches the calculator where you can enter the amount. You can also type the amount directly into the field. |
You access the calculator by clicking the calculator button that appears in a field for an amount. Figure 4-8 shows an example of the calculator.
