| Siebel Customer Relationship Management Siebel Fundamentals for Siebel Open UI Siebel Innovation Pack 2014 E52425-01 |
![]() Previous |
![]() Next |
View PDF |
Your organization determines the screens appear in the application window. These screens might be only a subset of the available screens. You access a screen by clicking the Side Menu icon, then selecting the related screen from the list screens, or by using the Site Map.
If the screen tab you require does not appear in the screen tabs, then you can show that screen tab with the other screen tabs so that you can easily access it. For more information about how to show screen tabs, see "Showing, Hiding, and Reordering Screens or Views".
To see a list of all the screens available to you, use the Site Map.
To navigate to a screen using the Site Map
Do one of the following:
From the application-level menu, choose Navigate, then Site Map.
Click the Site Map button on the application toolbar.
(Optional) To restrict the hyperlinks that appear in the Site Map, enter appropriate text in the field for searching.
In the Site Map, click the hyperlink for the screen you want to navigate to.
The Site Map displays the screen name and all the view names available in that screen.
Click a hyperlink to navigate to the screen or view.
