| Siebel Customer Relationship Management Siebel Fundamentals for Siebel Open UI Siebel Innovation Pack 2014 E52425-01 |
![]() Previous |
![]() Next |
View PDF |
Table 14-3 lists the keyboard shortcuts you can use to navigate in the Siebel application.
Table 14-3 General Navigation Keyboard Shortcuts
| Action | Keyboard Shortcut | Context |
Go to the Site Map. |
CTRL+SHIFT+A |
Application |
Go to the application-level menu. |
CTRL+ALT+M |
Application |
Go back. |
ALT+LEFT ARROW |
Application |
Go forward. |
ALT+RIGHT ARROW |
Application |
Go to the screen tabs. |
CTRL+SHIFT+T |
Application |
Go to the view tabs. |
CTRL+ALT+T |
Application |
Go to the subtabs. |
CTRL+ALT+V |
Application |
Open the menu button window on a list or form. |
CTRL+SHIFT+M CTRL+SHIFT+G |
List, form |
Go to the next list or form. |
CTRL+SHIFT+] CTRL+ALT+] |
Application |
Go to the previous list or form. |
CTRL+SHIFT+[ CTRL+ALT+[ |
Application |
Open the Tasks pane. |
CTRL+SHIFT+Y |
Application |
Go to the Computer Telephony Integration (CTI) toolbar. |
SHIFT+F2 |
Application |
Go to a tree applet. |
CTRL+SHIFT+4 |
Application |
Go to the previous tree applet node. |
UP ARROW |
Application |
Go to the next tree applet node. |
DOWN ARROW |
Application |
Go to the field for the visibility filter. |
CTRL+SHIFT+V |
Application |
