| Siebel Customer Relationship Management Siebel Fundamentals for Siebel Open UI Siebel Innovation Pack 2014 E52425-01 |
![]() Previous |
![]() Next |
View PDF |
You can specify the time zone that your Siebel application uses to display date and time fields during your session.
To set a default time zone
From the application-level menu, choose Tools, then User Preferences.
The User Preferences screen appears.
On the link bar, click Profile.
The Profile form appears.
In the Time Zone field, click the select button.
The Pick Time Zone dialog box appears.
Select the time zone, and click OK.
