| Siebel Customer Relationship Management Siebel Fundamentals for Siebel Open UI Siebel Innovation Pack 2014 E52425-01 |
![]() Previous |
![]() Next |
View PDF |
A shortcut allows you or another user to click a link to navigate directly to a record. If the Siebel application is not running when you click the link for a shortcut, then you must first log in to the Siebel application.
To create a shortcut to a Siebel record
In the Siebel application, locate and select the Siebel record for which you want to create a shortcut.
Select the URL content in the address field of the browser.
Copy and paste the URL content to another location, such as an email message or a document.
The link for the shortcut is created at the location.
