| Siebel Customer Relationship Management Siebel Fundamentals for Siebel Open UI Siebel Innovation Pack 2014 E52425-01 |
![]() Previous |
![]() Next |
View PDF |
The To Do list appears in the Calendar screen to the right of the calendar format.
To Do activities have the following characteristics:
They are activities that have a Type field value of To Do.
They carry forward every day until they are marked complete.
They do not appear in the Calendar itself.
Note: Alternatively, you can add a new To Do activity in the Activities screen and select To Do and Activities from the drop-down list for the Display In field. |
To add a To Do activity
Navigate to the Calendar screen.
In the To Do list, click New.
A blank row appears.
Enter values in the Description and Due fields.
(Optional) To add more information to the activity, drill down on the Description field hyperlink of the activity.
