| Siebel Customer Relationship Management Siebel Fundamentals for Siebel Open UI Siebel Innovation Pack 2014 E52425-01 |
![]() Previous |
![]() Next |
View PDF |
You can create your own queries, execute them, and save them for later use. Queries that you create are called user-defined queries. In these queries, you can enter your own criteria to locate a specific set of records.
To create a query for records
Navigate to the screen.
Do one of the following:
In the list or form, click Query.
In the list or form, click the menu button, and then click New Query.
From the application-level menu, choose Query, then New Query.
Use the appropriate keyboard shortcut.
When you invoke the new query command, a blank form or a blank row in a list appears.
Enter the query criteria in the appropriate fields.
For more information about entering query criteria, see "Simple Query Operators".
A wildcard is automatically assumed at the end of text you enter in the query fields. If you search for Siebe, then all words beginning with the letters Siebe are found.
In the list or form, click Go.
In the list or form, click the menu button, and then click Run Query.
From the application-level menu, choose Query, then Run Query.
The query executes, and the records that match the query criteria appear.
If you want to save the query, then do the following:
From the application-level menu, choose Query, then Save Query As.
The Save Query As dialog box appears.
In the Query Name field, enter a name for the query, and click OK.
The saved query appears in the drop-down list for the Saved Queries field.
