| Siebel Customer Relationship Management Siebel Fundamentals for Siebel Open UI Siebel Innovation Pack 2014 E52425-01 |
![]() Previous |
![]() Next |
View PDF |
You can query in a selection dialog box just as you query in a list or form. Consequently, you can search for specific information from one field or from several fields at one time.
To query for records in a selection dialog box
In the selection dialog box, click Query.
A blank row appears in the selection dialog box.
Enter your query criteria in the appropriate fields.
For more information about entering query criteria, see "Simple Query Operators".
A wildcard is automatically assumed at the end of text you enter in the query fields. If you search for Siebe, then all words beginning with the letters Siebe are found.
Click Go.
The records matching your query criteria appear.
