| Siebel Customer Relationship Management Siebel Fundamentals for Siebel Open UI Siebel Innovation Pack 2014 E52425-01 |
![]() Previous |
![]() Next |
View PDF |
Table 8-1 shows the navigational buttons for the Task UI wizard. Many of these buttons can appear at the bottom of the Task UI wizard. Your Siebel application might contain additional buttons.
Table 8-1 Navigational Buttons in Task Wizard
| Button | Description |
Previous |
Navigates to the previous step in the task. This button is disabled for the first step. This button might also be disabled for the steps that follow the step in which data is committed to the database. |
Next |
Navigates to the next step in the task. This button also validates your actions and prevents you from proceeding to the next step until the required criteria are met. This button is relabeled Finish when you reach the final step of the task. |
Pause |
Saves the task in its current stage and sends the task to your Inbox. You can launch the task later and resume the task from where you left off. You can set this option from your user preferences. For more information, see "Setting Pause Behavior for Task UI". |
Cancel |
Deletes the task without saving any data, but if a task is previously saved, then restores the task to its previous state. The Pause and Cancel buttons are enabled for all steps. However, when the data is already committed, the Cancel button is disabled for the last step. |
Submit |
Writes data while in the middle of a task. Some data is posted to the database rather than queued until the end of the task. |
